Organ Filter
Controllers for Moog format systems - official discussion & support.
Moderators: Kent, infradead, trouby
trouby
Organ Filter
Post by trouby » Fri Nov 18, 2011 12:38 pm
This filter is the formant filter from the vermona organ ET3-2 MR.
4 mixable sounds: flute (strong lowpass), bass clarinet (weak lowpass), clarinet (mid presence & treble cutoff), strings (highpass).
The humbucker coil pasting the origin and not available coil of the origin device.
trouby
Post by trouby » Tue Sep 04, 2012 4:53 pm
made a spectralic datasheet - hope you can see the font (OCR-B)
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Tue Sep 04, 2012 5:51 pm
Cool! Nice work, trouby. So, what waveform would you feed into it to get the sounds close to the instruments listed. I'm guessing square, since that's probably what the organ generates, no? Do they sound like what they say?
For every bullshit job, you need a bullshit education -- Brian Eno
trouby
Post by trouby » Wed Sep 05, 2012 7:49 am
yes, the organ input wave is square. its the filter of the lower manual and only 8' octave.
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Wed Sep 05, 2012 1:56 pm
"The humbucker coil pasting the origin and not available coil of the origin device. " :despair: :despair: :despair:
you got me??? :hmm:
Just me
Has enough VCA's
Post by Just me » Wed Sep 05, 2012 7:24 pm
Trouby is not a native Engwlizh speaker.I take it to mean he cannot source the original coil in the organ circuit and used a humbucking pickup as a substitute. Clever!
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Wed Sep 05, 2012 9:26 pm
ah!! yes.
thanx. :tu:
trouby
Post by trouby » Thu Sep 06, 2012 3:53 am
you got it ;)
i did it similar for the forthcoming ionika filter - clone of the 50s GDR tube organ...
thevegasnerve
Post by thevegasnerve » Tue Sep 18, 2012 8:47 am
Love the organ filter. demos sound wonderful. so if I have all 5u MOTM modules with the 4-pin connectors, do I need a different power supply for the Trouby? Is it a 5-pin connection. :hmm:
tuanuibi
Post by tuanuibi » Tue Sep 18, 2012 10:02 am
This sounds GREAT with my crumar performer and a few other polys that I've tried with it!
ourdia.bandcamp.com
dearplastic.bandcamp.com
buriedfeather.bandcamp.com
trouby
Post by trouby » Thu Sep 20, 2012 12:49 pm
great thats sounds good on the crumar ;)
the connector is curetronic or a short doepfer - bottom -12V, 3x mid ground, top +12V - or +-15V for sure.
i can do a 3-pin motm connector - or its modcan? ^^
thevegasnerve
Post by thevegasnerve » Thu Sep 20, 2012 3:35 pm
would need the 4-pin MOTM. That would be great if thats possible. I will PM you to discuss further. Thanks
acealive
voltage controlled mind
Post by acealive » Fri Jan 25, 2013 2:34 pm
I bought the STicker version of this some days ago. It's still says 'Vermona', btw.
I run my Microkorg through it, makes the sound a little better. A good module for this kind of purpose.
sloth713
Post by sloth713 » Sat May 04, 2013 10:45 pm
what is the hp size and power needs for the eurorack organ filter?
trouby
Post by trouby » Sun May 05, 2013 4:19 pm
its 8 ue wide & comes w/ doepfer cable.
module disabled cos problems with the humbucker coil.
trouby
Post by trouby » Thu Mar 16, 2017 2:39 pm
just replaced the coil by a gyrator. means, filter will be available soon a bit cheaper - 99 euros :)
panel in 6 ue like similar to the 8 ue ones - writings left.
both modules - moog & eurorack - working fine. maybe a tiles (4) version...
Footkerchief
Post by Footkerchief » Tue Feb 27, 2018 4:51 pm
What's the depth of this version of the module, and how much current does it draw? https://www.modulargrid.net/e/trouby-mo ... n-filter--
falseeye
Is this module still available ?
Post by falseeye » Wed Jan 16, 2019 12:38 pm
Is this module still available ? if so where do i purchase it from? there is no email link on there site
Return to “Trouby Modular ”
