ADDAC 602 ring mod ?
Moderators: Kent, infradead, __ag
mousegarden
Post by mousegarden » Thu Aug 13, 2015 1:24 am
Had this for a few weeks now, and still don't know if it's working properly or not, I seem to get a lot of bleed through of the original signal, in relation to the mod output, my Doepfer has a more "modulated" sound, with hardly any of the original signal present. Just wondering if the ADDAC is meant to be like this ?
C14ru5
Post by C14ru5 » Fri Aug 14, 2015 2:24 pm
I'm pretty sure that it's normal to have some bleedthrough of the original signal. But how much is "normal"? That's hard to say.
Both my ADDAC602 and my ASys RS-20 behave like this, but it's more pronounced in the ADDAC602 than in the ASys RS-20. I've also noticed that it depends very much on where your signals originate from (probably due to differences in impedance). I often route my two inputs into the WMD SSM before they go into the ring mod, as that makes sure that both signals have similar impedance, as well as making it easy to toggle which signal is the carrier and which is the modulator and if I should use the top or bottom ring mod on the ADDAC602.
My bottom ring modulator on the ADDAC602 is also significantly louder than the top one, and its output is asymmetrical and distorts much easier. I have no idea if it's supposed to be like that, if it's a happy accident, or if the tolerance between units is so high that no two units sound alike. But I like it nevertheless.
mousegarden
Post by mousegarden » Fri Aug 14, 2015 3:56 pm
C14ru5 wrote:I'm pretty sure that it's normal to have some bleedthrough of the original signal. But how much is "normal"? That's hard to say.
:tu:
I seem to have all the symptoms you have, I'm not worried about it, but
ADDAC are seen as a high end company, just wondered about quality control?
But I bought the ADDAC RM for variety, so........job done !
mousegarden
Post by mousegarden » Mon Aug 17, 2015 3:10 am
C14ru5 wrote:My bottom ring modulator on the ADDAC602 is also significantly louder than the top one,
Well well, guess what ? So is mine !
:hihi:
Return to “ADDAC System”
