DAY 3: VCA Quintet Mixing Console
Moderators: Kent, infradead, __ag
DickMarker
Post by DickMarker » Thu Mar 05, 2015 12:49 pm
Cheers for the response - I just noticed you've kindly answered that question twice now in this thread!
flo
Space Jack
Post by flo » Thu Mar 05, 2015 1:07 pm
My pleasure :tu: :guinness:
MATSmile
Post by MATSmile » Sat Apr 25, 2015 5:46 pm
Does anyone know who deep is the module? It says 50mm deep on site, but does it include pin attached to it? I have exactly 50mm deep case, want to try to fit it in. :help:
kla4spieler
Post by kla4spieler » Wed Nov 25, 2015 7:15 pm
Are the 802 pots bolted on the panel?
Summa
Post by Summa » Thu Nov 26, 2015 3:55 pm
MATSmile wrote:Does anyone know who deep is the module? It says 50mm deep on site, but does it include pin attached to it? I have exactly 50mm deep case, want to try to fit it in. :help:
saw this now, it's 53mm deep so sorry it won't fit (I updated the MG spec's a couple of years ago due to this.
Summa
Post by Summa » Thu Nov 26, 2015 3:57 pm
kla4spieler wrote:Are the 802 pots bolted on the panel?
nope, but they're stiff and nice..
Bark
Post by Bark » Sun Apr 03, 2016 4:23 am
Hi guys!
I just bought a 802, and saw this reversed panel on MG. Any of you guys using this? How did you obtain it? I can't seem to find it on the Addac site...
Would be nice to have this, mounting the module in a lower row in my case...
Cheers!
cloudleft
Post by cloudleft » Wed Aug 08, 2018 10:30 pm
The ADDAC site lists the depth as 55mm... so how deep is it actually? My case is exactly 56mm but I'm wondering if maybe just maybe I can sneak the ribbon cable under that last millimeter?
I know this is an old thread, but this seemed the best place to ask! Thanks.
Paranormal Patroler
Post by Paranormal Patroler » Thu Aug 09, 2018 3:57 pm
I'd go with what the ADDAC site says.
cloudleft
Post by cloudleft » Mon Aug 20, 2018 2:31 pm
Just racked my new 802 from Analogue Haven, and there's plenty of room beneath. Luckily, I was mis-measuring my case dimensions.
Man this thing sounds good!
disquiet
Re: DAY 3: VCA Quintet Mixing Console
Post by disquiet » Fri Sep 21, 2018 11:55 am
__ag wrote:The Solo line is also intended for Pre Listening purposes, using this output to connect your headphones through some headphone amplifier module.
My naive question of the moment: is it a problem to plug a headphone directly into the solo out (either by channel or the Solos Out jack)? I imagine it would be, even with the volume on the low end.
Summa
Post by Summa » Fri Sep 21, 2018 3:10 pm
You mean plugging a Hot Eurorack signal, that's mono through the headphones instead of a Line level signal that's balanced stereo, what can go wrong? :deadbanana:
disquiet
Post by disquiet » Fri Sep 21, 2018 3:21 pm
Summa wrote:You mean plugging a Hot Eurorack signal, that's mono through the headphones instead of a Line level signal that's balanced stereo, what can go wrong? :deadbanana:
Thanks for confirming. I figured.
I know I can get something like a Rosie to give me cue options. Alternately, I was wondering if there's a passive connector that could be put between a headphone and an ADDAC mixer out that would do the job.
Return to “ADDAC System”
