DAY 7: Ultra .WAV Player
Moderators: Kent, infradead, __ag
bj_gzp
Post by bj_gzp » Fri Jul 26, 2013 4:27 am
The cv file pot doesn't affect teh expansion. They are hardcoded to file A to H. The CV file pot affects the sample it loads after a reset.
And yes, i would love a script for the file naming!
Paranormal Patroler
Post by Paranormal Patroler » Wed Sep 11, 2013 11:20 am
So come on already, we need reviews and demos!
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Sep 14, 2013 6:03 pm
Stupid question deleted it
Xxx
:tu:
Cant wait to get hold of one of these
My mind is exploding with the possibilities ....
The expansion mod is such a great idea
HIMA
Post by HIMA » Wed Sep 18, 2013 10:21 am
this module is perfect for my needs in every way except for the 22050 Khz quality, which is a deal killer. so sad... :ripbanana:
The Book of Bad Ideas - A compendium of knowledge from Muffs. Download it here: http://bit.ly/1oz2zaI
tiny333
SONIC WARRIOR
Post by tiny333 » Wed Sep 18, 2013 12:52 pm
Really ??? I bet its pretty much the same ...
HIMA
Post by HIMA » Wed Sep 18, 2013 9:42 pm
Hmm, ok looking into this. as i understand it you can never reproduce audio frequencies higher than half the sampling rate. 44100 Hz sample rate will give max audio frequency about 22050 Hz. With 22050 Hz sample rate, you will only have audio frequencies below 11025.
However... that seems only true of stereo. Mono looks to be ok.
Am i wrong? Can anyone school me on this?
bj_gzp
Post by bj_gzp » Thu Sep 19, 2013 4:09 am
Nyquist theory is applicable no matter if mono or stereo. You lose just one octave in bandwith. And in general music happens at frequencies well below 11 kHz.
If you just want to replay samples in high quality, i think you are better off with a ipod/smartphone/tablet using a 804 or other input module.
I use the 101 and 111 extensively and the 22kHz didn't cause me any trouble, as the sound is processed further in the modular chain. I like running it through a distortion and a fedback loop in a digital delay, which adds harmonics higher up.
tiny333
SONIC WARRIOR
Post by tiny333 » Sun Oct 20, 2013 4:52 am
Arrggggggg
:deadbanana:
digidandy
Post by digidandy » Fri Oct 25, 2013 8:44 am
You can easily hear the difference between 44 and 22 in any sample editor. Just load your 44 sample, convert to 22KHz, and hear the difference. Trivial, I know - but still.
I was thinking about going for the 111, but then I heard how much treble you lose in a sample when it only goes to 11(KHz - but I had to reference Spinal Tap), so I called it off.
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Oct 26, 2013 2:31 am
Still dont believe you
I will let you know once my ultra arrives
In fact i will post a drum loop
And you can tell me
:tu:
On a brighter note does anyone have any advice re the card working with a mac ?
I have just bought a card reader
Not sure which card or what size
I mostly plan to only have 8 samples on a card
:tu:
digidandy
Post by digidandy » Sat Oct 26, 2013 11:51 am
I have written confirmation from ADDAC that it only supports up to 22050Hz sample rate, so no need to post drum loops. ;)
And as far as the 44.1 vs. 22.05KHz sample difference, anyone can hear it in a sample editor, as I wrote above. It's pretty self explanatory that a drum+hihat sample will sound pretty different when the cutoff is at 11KHz and 22KHz. Tons of information in a hihat sound that extends above 11KHz.
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Oct 26, 2013 1:14 pm
We will see
abstraktor
Post by abstraktor » Mon Oct 28, 2013 3:49 pm
It's a bit convoluted to format the SD card on a mac, as it's FAT16. It has to be done via the Terminal:
To format the SD card, you will need the path to the SD card device and the SD card device number.
1. Insert the SD Card into a card reader.
2. If you don't know how to find the device number of the SD Card, here is one way to do it:
2b. Open Disk Utility
2c. Highlight the SD Card device (upper icon), not the SD Card volume (lower icon)
2d. Click Erase at the top of the window
2e. Select Volume Format: MS-DOS (FAT) Click Erase... > Click Erase
The SD Card Volume Name will change to the UNIX device number e.g. "disk5s1". Note this number as it will change by itself to "Untitled". It is now formatted in MS-DOS FAT 32. We need to reformat it in FAT 16.
Once you have the device number of the SD Card, you need the path to the SD card device.
3. For my Mac, the path to devices is "/dev". In a terminal window: type "cd /dev" and hit the "Return" key to go to the "dev" directory. Then type "ls" (with a lower case L) and "Return" key. You should see the SD Card device number listed.
Formatting the SD Card in FAT 16:
4. In Disk Utility, highlight the SD Card device and click Unmount at the top, not Eject. The desktop icon of the SD card will disappear.
5. Go to the Terminal window. Be careful to type the following command with the correct letter case and spacing. Again, make sure you type the correct device number and path as you can very easily erase your hard drive in UNIX.
Type the command:
newfs_msdos -F 16 (path to SD Card device)/(SD Card device number)
e.g. newfs_msdos -F 16 /dev/disk5s1
and hit the "Return" key.
6. If you get just a new prompt (or a prompt with some warnings, e.g. below), the command executed successfully. You can remove the SD Card; it is now formatted in FAT 16. You can verify this in Disk Utility after mounting the SD Card.
If you get some instructions on the newfs_msdos command with a new prompt, the command did not execute. Make sure you enter the command with the correct case and spacing. Hint: to re-enter a previous command you typed, hit the up arrow repeatedly. For more information, type: "man newfs_msdos". Scroll with arrow keys. Type "q" to quit and return to prompt.
Warnings Example
newfs_msdos: warning: /dev/disk5s1 is not a character device
/dev/disk5s1: 1998208 sectors in 62444 FAT16 clusters (16384 bytes/cluster)
bps=512 spc=32 res=1 nft=2 rde=512 mid=0xf0 spf=244 spt=32 hds=128 hid=0 bsec=1998738
Not exactly a no brainer. This has killed the Wav player for me I'm afraid, because it was looking a good alternative to the Phonogene.
tiny333
SONIC WARRIOR
Post by tiny333 » Tue Oct 29, 2013 6:08 am
Thank you very much for the detailed response
I have not recieved it yet so do not know quite how painful this will be
It cant be that bad....... Can it ?
I have a phonogene .... A very different beast
I have a go pro im hoping that formats to fat14 or whatever
Maybe andre could sell us some formatted cards ?
:hihi:
tiny333
SONIC WARRIOR
Post by tiny333 » Tue Oct 29, 2013 6:11 am
I have a computer shop up the road i will just buy a load of cards from them and make them format them
Da na !!
Job done i cant miss out on this it can sort my life out
The phonogene is my fav makenoise modual the one i wont ever sell
But u cant store recall or even get it back once u touched it
:sb:
ADDAC System
Post by ADDAC System » Tue Oct 29, 2013 3:45 pm
tiny333 wrote: Maybe andre could sell us some formatted cards ?
Soon formated SD cards will be avaliable at ADDAC's webstore. But it's already possible to order them.
Price is 7euros each unite.
All the best,
ADDAC Team
Questions? Assistance? Hit me up via PM or send us an email!
ADDAC System | [www.addacsystem.com]
tiny333
SONIC WARRIOR
Post by tiny333 » Tue Oct 29, 2013 6:56 pm
That is fantastic thank you
I need ten when u send the ultra
Xx
:tu:
gwpt
Post by gwpt » Sun Dec 15, 2013 6:48 am
Can anyone report size/brand of micro sd cards that worked?
ADDAC System
Post by ADDAC System » Mon Dec 16, 2013 5:32 pm
Hi!
Sizes below 1Gb work for sure, we also had good results with 2 and 4gb
cards, from our experience brands are not important.
And there's a new great app to format cards in the right manner, available
for windows and osx:
https://www.sdcard.org/downloads/formatter_4
All the best,
ADDAC Team
ADDAC System
Post by ADDAC System » Sat Feb 15, 2014 8:17 am
ADDAC111 Ultra .WAVplayer and ADDAC111b Ultra .WAVplayer Expansion now in stock.
http://www.addacsystem.com/product/adda ... s/addac111
http://www.addacsystem.com/product/adda ... /addac111b
All the best,
ADDAC System
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Feb 15, 2014 8:39 am
Booody wonderful box
I got sd cards ready formatted from addac
Dowloaded the cleaner app and its all as easy as ABC
Now i want another !
Thing sounds wonderful as well btw
:tu:
Drums sound good
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Feb 15, 2014 1:55 pm
https://soundcloud.com/jagged-lip-thein ... a-wav-drum
here is a drum sample as promised
sound ok to me
:tu:
tiny333
SONIC WARRIOR
Post by tiny333 » Sat Feb 15, 2014 1:56 pm
https://soundcloud.com/jagged-lip-thein ... wav-drum[s]
shit i have no idea how to inbed a soundcloud track sorry
:hmm:
mafouka
Post by mafouka » Sat Feb 15, 2014 2:21 pm
i <3 my 111 !!!
這一生中有多少人擦肩而過?而朋友是多麼可貴啊
Noisefan
Post by Noisefan » Mon Feb 24, 2014 9:45 pm
I want/need this.
So, for the most part, do most people address simple samples like drums/stabs or do you use more complex long-formsamples. Seems drums would not be too affected by the 22khz sample rate. Or does that crash loose too much sizzle?
Return to “ADDAC System”
