Volta freezing Logic 8 |
science Spending Spree!
Posted: Tue Sep 08, 2009 10:43 pm Post subject: Volta freezing Logic 8 |
I can't seem to get Volta to stop freezing Logic while it's scanning AUs during startup. Has anyone else had this happen?
Sitting here staring at a beachball of death with it trying to initialize Volta. _________________
| Classy Kent wrote: | | You actually put effort into being a tool? Classy. |
1nput0utput Common Wiggler
    Posts: 209 Location: USA
Posted: Wed Sep 09, 2009 11:31 am Post subject: |
Wasn't that... I had already made sure I had the latest version and re-installed just to be sure. It finally started working randomly. Who knows what the deal was. _________________
zerosum Modulation Maniac
      Posts: 3487 Location: Lakeport, CA
Posted: Wed Sep 09, 2009 9:50 pm Post subject: |
| Quote: | | It finally started working randomly. Who knows what the deal was. |
Damn computerthingamajigs......
I have had similar situations where something wont work, then i go to show someone its not working and it starts working....
Their response: "dude what the hell you talking about it works fine."  _________________ |zerosuminertia.com| |
bar|none Super Deluxe Wiggler
    Posts: 1775 Location: Undertucky, WA
Posted: Tue Jan 26, 2010 11:56 pm Post subject: |
I have the same issue in Ableton Live 8. In fact it's chronic. Basically I can reproduce it to the following.
If I use an aggregated audio interface on OSX I get freezes and lockups when opening a set that Volta is in. Unfortunatly my setup involves 2 MOTU interfaces, and ultralite mk3 and an ultralite 828mkiii. One dedicated to Volta and one my main interface.
I have a hunch about this. Basically, the audio channel that Volta listens for calibration on is chosen separately from audio settings in Live. In fact, it does not see aggregated audio or what live sees but provides a separate list of audio interfaces probably connected directly in Volta.
Anyway...this is just a developers hunch, but I'm betting there is a conflict there. |
doctorvague ole fuckity fuck
    Posts: 2466 Location: Silver City, NM
Posted: Thu Jan 28, 2010 8:05 am Post subject: |
| bar|none wrote: | I have the same issue in Ableton Live 8. In fact it's chronic. Basically I can reproduce it to the following.
I tried aggregate devices once. It was a nightmare. It eventually took down my whole system like a virus or something. This was on a G5 running Tiger. I had to wipe the machine and reinstall everything from the ground up. I've heard other stories besides mine. I use 2 interfaces but don't use aggregate devices and Live (and DP) can see both of them, but they are both on a PCI-424 card (a 2408 and a 24IO dedicated to Volta).
Can you try running them as separate devices, not using AD? _________________ Happy New Nanosecond.
modular youtube videos|Soundcloud audio tracks|The Oversouls (live non-modular trio) |
Posted: Thu Jan 28, 2010 11:30 am Post subject: |
You can only select one in Ableton though right?
Ableton can only use one device at a time. This is why if you are spread across multiple interfaces, aggregate devices are the only option.
In my case I have my main audio interface AND a separate one just for volta. Also, I use soundflower for inter app audio. So that's actually 3 devices at once sometimes. |
Posted: Fri Jan 29, 2010 10:52 am Post subject: |
| bar|none wrote: | >and Live (and DP) can see both of them
Live is seeing both of my interfaces but it must be because they're both on one PCI-424 card and Live sees that more like one big interface. One clue is that all the outputs of both are in one long list and also that you just select the 424 in the pulldown, you can't select the interfaces separately.
Gordon Cole Wiggling with Experience
Posted: Sun Feb 14, 2010 12:13 am Post subject: |
| ah never mind, got it |
