Frac Sea Devils update? |
gnombient Common Wiggler
   Posts: 70 Location: HMB
Posted: Thu Mar 11, 2010 2:12 pm Post subject: Frac Sea Devils update? |
| The "Return of the Curse of Senrick" demo has me drooling over this bad boy. Is STG still planning to release a Frac version of the Sea Devils filter? Not that I'm opposed to 5U or mixed formats, but a Frac'ed Sea Devil would be mighty sweet! |
parasitk I Play Loco Gigs
     Posts: 4759 Location: Valley Village, CA
Posted: Thu Mar 11, 2010 2:15 pm Post subject: |
Somewhere it was said that this is not happening. A search will probably pull up the thread/post. Frac is dead to many manufacturers, unfortunately. _________________ I, Parasite | Synth fuckery on Soundcloud
| dkcg wrote: | | But in the end, it felt like I was playing WiiSoundMasterJedi. |
Posted: Thu Mar 11, 2010 2:19 pm Post subject: |
Ehhh I can't find it. Maybe it was an email or IM conversation. _________________ I, Parasite | Synth fuckery on Soundcloud
Posted: Thu Mar 11, 2010 3:20 pm Post subject: |
| parasitk wrote: | | Frac is dead to many manufacturers, unfortunately. |
I guess it's a good thing I still have some space in my 5U rack! |
indexofmetals Super Deluxe Wiggler
    Posts: 1296 Location: Isle of Man "Technically Canadian"
Posted: Thu Mar 11, 2010 4:18 pm Post subject: |
i agree that it's too bad - I'm putting all my synth money in bugbrand, metalbox & any wiard 1200 I can find - the sea devils filter in frac would be ideal
I wonder if he'd sell us populated pcb's - maybe metalbox could be convinced to do a frontpanel, just dreaming I guess |
Muff Wiggler The cake is a lie.
Posted: Thu Mar 11, 2010 4:44 pm Post subject: |
i would give just about anything for one in frac  |
Posted: Thu Mar 11, 2010 4:47 pm Post subject: |
I wonder if there's a minimum # we'd need to hit in order to make this worth STG's time?  _________________ I, Parasite | Synth fuckery on Soundcloud
suitandtieguy Hammond King
     Posts: 2950 Location: Chillicothe IL USA
Posted: Thu Mar 11, 2010 7:53 pm Post subject: |
| If the filter is in Euro format I assume I'd need a Euro power supply? |
Posted: Thu Mar 11, 2010 11:16 pm Post subject: |
_every_ module i sell has a Synthesisers.com power connector.
the only change i'd have to make is on this module there's a 12 volt regulator for when it's used on a 15 volt system. i'd have to set it up for 15 volts but it's not a big deal. in eurorack there's a jumper strap i have to add and the 12v regulation gets omitted. _________________ http://suitandtieguy.com
http://stgsoundlabs.com |
Posted: Thu Mar 11, 2010 11:22 pm Post subject: |
Man that's tough. STG Frac panels were the sexiest in the format.  _________________ I, Parasite | Synth fuckery on Soundcloud
Posted: Fri Mar 12, 2010 12:07 am Post subject: |
look Chris, i really appreciate your kind words but i just can't justify frac format any longer.
would it help if could make a eurorack rack frame for 50 bucks? _________________ http://suitandtieguy.com
Posted: Fri Mar 12, 2010 12:17 am Post subject: |
No no, I know the deal. Hell I said as much in the second post of this very thread.
I'm not interested in Euro. At all. But maybe I'd go for a Euro panel on a Sea Devils set up for 15v to put in my Frac cabinet. We'll see what happens when my tax return gets here. Or hell, if you'd sell a populated 15v board I'd make my own panel.
What I said stands though - I love the look of the STG Frac (and MU, actually) panels - even more than the Euro or MOTM ones!  _________________ I, Parasite | Synth fuckery on Soundcloud
Mr White always folding something...
    Posts: 1239 Location: Chianti hills
Posted: Sun Mar 14, 2010 10:58 am Post subject: |
[quote="parasitk"]if you'd sell a populated 15v board I'd make my own panel.[quote]
That's an awesome suggestion, can I second the request? |
Posted: Sun Mar 14, 2010 12:35 pm Post subject: |
I third Parasitk & gnombient - if you sell the populated 15v board I'll take several (probably 6 as I'm in process of building up a synthi100 size bugbrand). but I'll buy them anyway if their eurorack faceplate with frac holes & 15v modified. I'd just prefer them the populated board so I could mount them with the board parallel
I wish more manufactures would consider selling populated boards - I don't presume the faceplate is much of the selling price. But faceplates are a form of advertising as well. |
visible cow Super Deluxe Wiggler
   Posts: 1131 Location: Athens, GA
Posted: Sun Mar 14, 2010 1:56 pm Post subject: |
Oh man, a euro Sea Devils filter is coming....just when I thought I had my 9u all mapped out.
This will go very nicely with my Sem20 and z2040..... |
Posted: Mon Mar 15, 2010 5:49 am Post subject: |
i'm sorry, i won't sell populated boards, and if you just want the PCB you should buy the one from Mr Bridechamber because it's the same circuit, for the most part. if you want our PCB specifically (which you might, it's a Det3 board now) i can sell you that.
to the gentleman who would like 6 of them (most flattered): i can make you a eurorack frame which would hold all 6 perfectly in 3U just like a frac frame, each of them set up for 15V operation and with a Dotcom-MOTM cable supplied for each one. what would you do about the banana jacks? _________________ http://suitandtieguy.com
Posted: Mon Mar 15, 2010 9:24 am Post subject: |
| pm sent |
Posted: Mon Mar 15, 2010 10:34 am Post subject: |
| suitandtieguy wrote: | | i'm sorry, i won't sell populated boards, and if you just want the PCB you should buy the one from Mr Bridechamber because it's the same circuit, for the most part. |
Okay I guess I'll do that then.
