Does this exist?
Author Does this exist?
dkcg
Last Visit: 25 May 2013
PostPosted: Sat Oct 04, 2008 3:06 pm    Post subject: Does this exist? Reply with quote Add User to Ignore List
A quadrature oscillator that will go from ultra low LFO rates (like 10-20 seconds) to beyond hearing maybe like 30-40kHz? If you could output a CV controllable phase offset in addition to the standard 90 degree offsets, that would be amazing. And near perfect for what I'm looking for if it's closer to being pitch accurate than not,but I'm not super picky, I love M15s. lol
If the M15 had quadrature outputs and went as slow as 10-20 seconds and had even more morph outputs, I think it would be exactly what I'm hoping exists.
Does this exist in euro format? In any format?
The cake is a lie.
Last Visit: 24 May 2013
PostPosted: Sat Oct 04, 2008 3:13 pm    Post subject: Reply with quote Add User to Ignore List
mankato. gives you 8 simultaneously-available phases of sinewave, from minutes-per-cycle up to beyond audio rates
cv controllable frequency
not cv controllable offset
also works as a very lovely sounding LPF, and a slew generator as well.
pretty damn amazing module all around.
"I'm gonna get my engineers to invent a combustible lemon that burns your house down."
dougcl
Number 6
Last Visit: 20 May 2013
PostPosted: Sat Oct 04, 2008 5:03 pm    Post subject: Reply with quote Add User to Ignore List
Seems to me the PH-4 gets up there if you crank the manual rate all the way up then max the CV input. Too lazy to check it at the moment. And then I read the rest of your post about phase shifting.
thermionicjunky
Thyratron Genius
PostPosted: Sat Oct 04, 2008 6:04 pm    Post subject: Reply with quote Add User to Ignore List
To obtain a controllable delay between LFOs (up to limited audio frequencies) one could use the multiple Elf LFOs, which will sync to a trigger, and multiple trigger delays. The LFO will cover the audio range, but the limitation is the minimum delay time of the trigger delay.
chimologic
Last Visit: 28 Oct 2012
PostPosted: Sat Oct 04, 2008 7:11 pm    Post subject: Reply with quote Add User to Ignore List
anyone heard anything about the mankato euro version? I know there was talk about it before but haven;t heard news in ages...
wetterberg
Last Visit: 16 Mar 2013
PostPosted: Sat Oct 04, 2008 7:18 pm    Post subject: Reply with quote Add User to Ignore List
Don't forget that Doepfer has a quadrature LFO too, I'm certain it can be tweaked to output supersonics...
http://www.doepfer.de/a1439.htm
best part: 65 euros.
View user's profile Send private message AIM Address MSN Messenger
dkcg
PostPosted: Sat Oct 04, 2008 8:07 pm    Post subject: Reply with quote Add User to Ignore List
I've got a PH-4, I love it, I was hoping there was something like a PH-4 Model 15 crossbred Frankenstein oscillator. I've been curious about the mankato, but haven't looked at it seriously since I'd rather stay euro, but have been thinking about starting a blacet rack.
I looked at the doepfer QLFO, but got the PH-4 instead. I just wish it had more waveforms and were made for a super high frequency range, or I wish the M15 went much lower in frequency and had quadrature outs..
Roycie Roller
Death Row Wiggler
Last Visit: 25 Apr 2013
PostPosted: Sat Oct 04, 2008 8:27 pm    Post subject: Reply with quote Add User to Ignore List
STG might be putting out the Mankato in euro, but i'm not sure.
Other than that, yeah, get a blacet rack & psu (in fact, the frac modules will fit in schroff racks, you just need to drill new screwholes in the faceplates). Then you can get all the great frac modules too- Wiard, STG, Blacet, the list goes on. And, since most DIY is at +/-15v, it'll open up all those possibilities as well.
Oh, and you can run Modcan off a Blacet psu.
thermionicjunky
Thyratron Genius
PostPosted: Sat Oct 04, 2008 10:00 pm    Post subject: Reply with quote Add User to Ignore List
The Zeroscillator is supposed to work as an LFO, but I can't find the minimum rate for it. I believe that STG is planning on offering the Mankato in Euro, but it needs a redesigned PC board. I'm planning on using the Mankato for this stuff. I'll obtain variable waveforms through FM.
dougcl
Number 6
PostPosted: Sat Oct 04, 2008 11:57 pm    Post subject: Reply with quote Add User to Ignore List
Just an FYI... I just measured 9.7kHz max from the PH-4.
dkcg
PostPosted: Sun Oct 05, 2008 3:01 am    Post subject: Reply with quote Add User to Ignore List
Not bad for a LFO. I love how crazy it sounds in that zone between LFO and phased AM driving a stereo pan.
