Building a cabinet
Author Building a cabinet
synthetic
TASCAM Hero!
Last Visit: 17 Jun 2013
PostPosted: Fri Nov 30, 2007 3:54 pm    Post subject: Building a cabinet Reply with quote Add User to Ignore List
The first step in my Euro modular will be to build a rack. I'm going to start with the Doepfer DIY System 1, which has four HP84 rails. My idea is to build one wide cabinet to start with, two rails on top and two on the bottom. If (when) I fill this, I would build another slanted cabinet, and the two would fit together like a miniature Moog 55.
My question is, will a system that's one 34" wide (852mm) be simple enough to use? It doesn't seem that wide to me, but most systems I see use 19" rack sided widths.
I looked into the Vector T-struts, but the Doepfer DIY-1 system at Haven seems like a good deal for the whole package.
synthetic
TASCAM Hero!
PostPosted: Fri Nov 30, 2007 4:08 pm    Post subject: Reply with quote Add User to Ignore List
Another question, how deep does it need to be in the back? I read elsewhere that the Blacet Miniwave is too deep for some cases (Frac, I know). I don't want to wish I'd made it 3" deeper later on.
felix
Loves the manuals!
Last Visit: 08 May 2013
PostPosted: Fri Nov 30, 2007 4:58 pm    Post subject: Reply with quote Add User to Ignore List
Cool ideas. I'm starting on a case of my own since I'm about to run out of room with my 2 Doepfer A100P cases and it's too expensive to keep buying more.
I'll measure my A100P case when I get home, but I'm pretty sure it's less than 10" deep.
Personally I kinda dislike the ~19" 84HP Euro "standard" size. 84HP seems to narrow for a larger system and 168HP feels a little wide if you like to sit right in front of it. I think the Vector rails are 150HP which might feel just right. I'm not sure what the HP->inches scale is...anyone know?
Personally, I was going to skip the metal rails all together and just use wood. AFAIK, the only reason metal rails are used is so that all the modules share a common ground and that can be easily remedied in a wood case by using some copper tape along the mounting areas. It does mean that you have to screw in new holes to the wood when adding modules, but that isn't that difficult really.
Plus, the real added benefit is that you can make it any size and shape that you want, the only restriction is a minimum depth as you mentioned as well as the hight of each row. I'd really like to make something resembling the Buchla 200e layout.
I really want to finish my joystick project first, but I might get started on the case this weekend. Finishing the case before the joystick controller means I could sell one of my A100P cases and that means more money for modules! grin
dress yourself for the public. you now must exit your home and acquire a dental mirror and lubrication!
i recommend a hat, or a helmet. if a helmet, ensure that it is both convincing and unbiased. -citizen mori
http://felixinferious.blogspot.com
http://felixinferious.bandcamp.com
View user's profile Send private message Send e-mail AIM Address
The cake is a lie.
Last Visit: 18 Jun 2013
PostPosted: Fri Nov 30, 2007 5:06 pm    Post subject: Reply with quote Add User to Ignore List
Do the Euro modules actually need their rack for common ground?
What about those perspex synthbox cases?
I'm not a euro expert - but a common ground should be on the power connector and not the module panel. If it was you could ground it by touching a panel
I know that blacet modules don't use the rack for ground, they use the power harness. One reason I know this to be true, is that one of the desirable characteristcs of the blacet rack over the Paia one, is that the blacet rack is non-conductive.
"I'm gonna get my engineers to invent a combustible lemon that burns your house down."
sandyb
reap what you sow
Last Visit: 19 Jun 2013
here's a couple of pictures of the case i'm building for my euro system - it's not finished yet -still needs to be painted. i went with 4 x 84hp although i ended up using some alternative rails to the ones that came with the doepfer kit. afaik some Plan B modules are a bit fussy about their faceplate being grounded properly - particularly the model 15 osc.
Kwote
Voltage Controlled Crackpot
Last Visit: 14 May 2011
PostPosted: Fri Nov 30, 2007 5:23 pm    Post subject: Reply with quote Add User to Ignore List
nice! and shiny.
Self expression is as essential as breathing
kwotemusic.com
my other sites
felix
Loves the manuals!
PostPosted: Fri Nov 30, 2007 5:27 pm    Post subject: Reply with quote Add User to Ignore List
Very nice!
I like the curved shape...that's kinda what I was thinking of as a buchla like cabinet.
sandyb
reap what you sow
PostPosted: Fri Nov 30, 2007 5:42 pm    Post subject: Reply with quote Add User to Ignore List
felix wrote:
Very nice!
i was thinking of a cross between Buchla and EMS when i designed it.
J.w.M.
Analog Addict
Last Visit: 06 May 2011
PostPosted: Fri Nov 30, 2007 6:10 pm    Post subject: Reply with quote Add User to Ignore List
Wow-- that's a great-looking cabinet. The curved shape rocks.
Maybe (once I get settled down and don't have to worry about moving around something big and heavy), I'll use that as a jumping-off point for designing a case for my system
CTRLvoltage
synthetic
TASCAM Hero!
PostPosted: Fri Nov 30, 2007 6:14 pm    Post subject: Reply with quote Add User to Ignore List
Nice cabinet!
I was feeling the same way. I'll look into the Vector rail. Then again, I rarely hear users complain about too many open spaces in their racks. And we're only talking about a few inches difference, so it's probably fine either way.
From the Doepfer website:
HP / Calc Width (mm) / Actual Width (mm)
1 / 5,08 / 5,00
2 / 10,16 / 9,80
4 / 20,32 / 20,00
8 / 40,64 / 40,30
10 / 50,80 / 50,50
12 / 60,96 / 60,60
14 / 71,12 / 70,80
16 / 81,28 / 80,90
20 / 101,60 / 101,30
21 / 106,68 / 106,30
22 / 111,76 / 111,40
28 / 142,24 / 141,90
42 / 213,36 / 213,00
84HP = useable rack width = 426mm (16.77")
felix
Loves the manuals!
PostPosted: Fri Nov 30, 2007 7:37 pm    Post subject: Reply with quote Add User to Ignore List
Rad, thanks for those numbers.
felix
Loves the manuals!
PostPosted: Fri Nov 30, 2007 7:44 pm    Post subject: Reply with quote Add User to Ignore List
I don't know for sure, I'm just assuming. I don't even think there are any ground wires going from the rails on my A100P case.
The synthbox case does make some mention of grounding:
Your Space Case comes equipped with two Ground Boards which are attached to the back of each row and serve two important functions: they provide a visual indication of the DC power status (via separate LEDs for each of the three output voltages: -12, +5 and +12 VDC) and most important, they assure your faceplates are properly grounded. To use them, simply connect the power cable to their standard Plan B type power connector as if they were another module in your rack.
I'm not even a qualified electronic novice so I don't really understand how it should work in the first place lol
synthetic
TASCAM Hero!
PostPosted: Fri Nov 30, 2007 8:05 pm    Post subject: Reply with quote Add User to Ignore List
It looks like that case runs a power cable to the mounting rails to ground them. I could just run a wire from the rail to the system ground for the whole case. It's probably a good idea to star ground the whole case anyway.
tragedybysyntax
*lolweegi*
PostPosted: Fri Nov 30, 2007 11:25 pm    Post subject: Reply with quote Add User to Ignore List
HOlly shit... beautiful case man!!! Astounding!!!
I"m about to start building mine once I get the vector t rails in (diy kit rails dont line up to havestman and some of the livewire stuff)
But I did the DIY 2 kit which is just enough for 1 row of euro. Once I filler up... (eventually) I'll just build a second one and screw it to the first one, lol.
This is of course will be sitting ontop of my monster cabinet which holds 4 frac racks, a mobius, sherman filterbank 2 and a roland re-201 tape echo.
sandyb
reap what you sow
PostPosted: Sat Dec 01, 2007 12:34 pm    Post subject: Reply with quote Add User to Ignore List
i'm no expert on grounding. the doepfer power supply that comes with the diy kit has a connector for ground that the manual says you should use to the case if it's metal. i'm intending to connect it to one rail and then just run a wire through the back of the others. i figure it can't do any harm and i do remember there being a post from Peter on the Plan B list stating the importance of rail grounding for some of the modules, particularly if they are in a wooden case. i'll have a look in the archives and post what he said if i can find it.
sandy
edit: here's a posting by Peter on AH - not exactly the one i was thinking of but useful anyway:
"There are three types of grounds which need managing:
Earth Ground (primary side - comes from the wall socket)
System Analog Ground (secondary side - from the output of the PSU that's powering your analog modules)
System Digital Ground (secondary side from the PSU that's powering
any computer systems in the synth)
All should be connected together AT THE POWER SUPPLIES - meaning
separate lines to a central hub, not daisy chained from one to
another. This can make for a very noisy ground line. This hub
should be attached to the chassis if it's made from low resistance
conductive material (metal for instance) and to the faceplates as well.
Connecting to the faceplates is a safety consideration. If you just
happen to be touching your faceplates when your studio gets hit by
lightning, if the faceplates have a discharge path to Earth you'll be
able to tell people about the experience later. If you don't...then
they may be talking about it later without you (if you get my
drift). The lightning is going to find it's way to ground through
the path of least resistance - the ground line you provide, the
chassis, or you. Either way it's gonna get down there. One of those methods can be fatal.
Sometimes there's a problem with grounding faceplates as people make
cabinets in which the modules mount to a high resistance surface -
such as wood. You need to come up with a way to assure your
faceplates are grounded if you go this route. Your shielded
patchcords may indirectly do the job, but it's not the best bet. A
direct ground line is.
The faceplate and chassis grounds can be daisy-chained together to
the hub. All PSU's secondary system grounds should be routed
directly from each PSU to the same hub - each supply to it's own
path. This keep system noise to a minimum. Then that hub should also
connect to Earth Ground.
Hope this helps.
- P"
and there's this from Peter on the Plan B yahoo group - a couple of parts from a thread about tracking problems with some Model 15 oscs:
"Who's rack are you using?
Is it home built?
If so....does it have metal rails in which to mount the modules?
If not, have you provided a means to GROUND the faceplates when they are mounted in the system?
Make sure the ground wire from the PSU on the case is still bolted to it's side. The Model 15 needs a grounded faceplate or everything will be screwey."
felix
Loves the manuals!
PostPosted: Sat Dec 01, 2007 9:07 pm    Post subject: Reply with quote Add User to Ignore List
Sweet. Thanks for digging all that info up!
felix
Loves the manuals!
PostPosted: Tue Jan 29, 2008 7:04 pm    Post subject: More Vector Rails drama Reply with quote Add User to Ignore List
FYI, I've found out that the standard eurorack screws (the ones that come with all Doepfer/Plan B/etc modules) do not fit in the special Vector nuts that slide in the Vector T-Strut rails. The Vector nuts are 4-40 thread, which means the standard eurorack ones are not.
I'm thinking at this point the easiest route is to source a bunch of 4-40 screws; but I'm also looking out for nuts that would work in the Vector rails and are the same thread as the eurorack screws (I emailed Shawn @ AH to see if he knew what size they are).
Chuck E. Jesus
holier than thou
Last Visit: 30 Mar 2012
PostPosted: Tue Jan 29, 2008 7:14 pm    Post subject: Reply with quote Add User to Ignore List
i just went to the local Ace Hardware and bought a bunch of bolts that fit...the only drag about the Vector rails is you have to put the screws in from one side, so you can't simply pop a mod in between two existing mods...
felix
Loves the manuals!
PostPosted: Tue Jan 29, 2008 8:24 pm    Post subject: Reply with quote Add User to Ignore List
Ah that's a good idea, so the nuts go on the faceplate side and the bolts are in the rails. Clever!
The "big three" around me (Ace, OSH, and Home Depot) didn't have shit for selection of small fasteners. Actually, Home Depot had some, but they were in packs of 8 for like $2...they were also quite bit longer than necessary.
I'm going to Halted here in Santa Clara this weekend...it apparently has *everything* that has to do with electronics by the bin full. Like a big nerd pick-n-pull wink
The cake is a lie.
PostPosted: Tue Jan 29, 2008 8:30 pm    Post subject: Reply with quote Add User to Ignore List
http://www.microfasteners.com
They are great
felix
Loves the manuals!
PostPosted: Tue Jan 29, 2008 8:57 pm    Post subject: Reply with quote Add User to Ignore List
Holy god, it's screw heaven!!!
grin
The cake is a lie.
PostPosted: Tue Jan 29, 2008 9:02 pm    Post subject: Reply with quote Add User to Ignore List
yep, that's where i buy all my screws
the black ones for mounting frac modules are the best 8)
Kwote
PostPosted: Wed Jan 30, 2008 1:31 am    Post subject: Reply with quote Add User to Ignore List
don't get screwed. oops
kwotemusic.com
my other sites
tragedybysyntax
*lolweegi*
PostPosted: Thu Feb 07, 2008 12:16 pm    Post subject: Reply with quote Add User to Ignore List
I get to build my cabinet this weekend.... FUCKING FINALLY! I bought the DIY Doepfer kit #2 and it turned out to be the biggest piece of shit I've EVER touched. I bought Vector Trails and my order coming in is a PSU2, and BUS board.
I'm just trieng to decide on to make my cabinet a boring old 90 degree square cabinet like my main one or... to give it some slantyness to it. Also... I guess I'll build it with room to expand as this year I plan on owning LOTS of euro to go with my frac. Prolly 2 spaces tall and whatever the width is on the Vector T's.
MDF wood i guess.
felix
Loves the manuals!
PostPosted: Thu Feb 07, 2008 2:29 pm    Post subject: Reply with quote Add User to Ignore List
I'm been puttering along with my case unfortunately...Row 1 is finally racked in though.
http://felixinferious.blogspot.com/2008/02/modular-case-row-1-complete .html
felix
Loves the manuals!
PostPosted: Sat May 31, 2008 8:19 pm    Post subject: Reply with quote Add User to Ignore List
Still haven't finished the case...yet. I got the modules are all racked in though.
The big open space on the left is for the AFGs!!! Big space toward the bottom is for Plan B M14 and Livewire Chaos computer. Rest of the space is for Harvestman and modules yet to be acquired.
The cake is a lie.
PostPosted: Sat May 31, 2008 9:04 pm    Post subject: Reply with quote Add User to Ignore List
holy crap that's rad w00t
super nice mounting job, i LOVE how the modules are flush with the top of the desk
awesome
J.w.M.
Analog Addict
PostPosted: Sat May 31, 2008 10:27 pm    Post subject: Reply with quote Add User to Ignore List
Wow that looks great. Can't wait to see pictures of the whole thing.
CTRLvoltage
Kwote
PostPosted: Sat May 31, 2008 10:28 pm    Post subject: Reply with quote Add User to Ignore List
yup. gonna be a nice Euro monster once it's all filled up.
kwotemusic.com
my other sites
synthetic
TASCAM Hero!
PostPosted: Sun Jun 01, 2008 1:25 pm    Post subject: Reply with quote Add User to Ignore List
Nice work. I'm hoping to finish my cabinet this week. (Though I switched formats since I started this thread.)
http://www.jefflaity.com/studio
futuresoundsystems
<3 CMOS
PostPosted: Sun Jun 01, 2008 1:27 pm    Post subject: Reply with quote Add User to Ignore List
Haha nice cabinet. I built a 16U MOTM cabinet from an Ikea box. Nice wood. Nice nice wood. 8) I believe it's probably the only thing I've ever had from Ikea that I've ever really praised after it was chopped up and refit. I'll have to post some pics of it once I've got it out of storage (yes you read that right, it's been in storage for a few weeks. oh and yes, you thought that right too, I do have withdrawal symptoms help lol )
Unique designs and ideas in sound since 2005:
http://www.futuresoundsystems.co.uk
View user's profile Send private message Send e-mail MSN Messenger
ehdyn
Last Visit: 15 Jun 2013
PostPosted: Mon Jun 02, 2008 7:01 pm    Post subject: Reply with quote Add User to Ignore List
Something to recommend in it's stead?
felix
Loves the manuals!
PostPosted: Mon Jun 02, 2008 11:45 pm    Post subject: Reply with quote Add User to Ignore List
It's not totally obvious, but there is no cabinet. I just racked up the modules and stacked each row on top of one another. They aren't attached to anything...a good hard sneeze would certainly knock it all over.
It looks like it's in a cabinet because it's sitting on my "workbench" desk, which has a hutch where I shove all kinds of crap.
That color is what I'm shooting for though. wink
The IKEA cabinet is a great idea...I'm always checking out IKEA Hacker and various other IKEA product mods...I don't know why I didn't think about that before. I'll be perusing the catalog this weekend for sure!
futuresoundsystems
<3 CMOS
PostPosted: Tue Jun 03, 2008 1:20 am    Post subject: Reply with quote Add User to Ignore List
It sounds really stupid, but have a look at their "boxes". Buy some metal rails, cut the wood down a little and it's perfect, at least for what I wanted.
synthetic
TASCAM Hero!
PostPosted: Tue Jun 17, 2008 12:19 am    Post subject: Reply with quote Add User to Ignore List
Finally finished my cabinet:
http://www.jefflaity.com/gallery/motmcabinet
flts
PostPosted: Tue Jun 17, 2008 9:55 am    Post subject: Reply with quote Add User to Ignore List
Doepfer DIY kit #1 is very decent, the cheaper one (#2) isn't.
felix
Loves the manuals!
PostPosted: Wed Jun 18, 2008 12:24 am    Post subject: Reply with quote Add User to Ignore List
Whoa! That is wicked! we're not worthy
synthetic
TASCAM Hero!
PostPosted: Wed Jun 18, 2008 12:35 am    Post subject: Reply with quote Add User to Ignore List
Thanks. I purposefully made it on the small side so I don't go too nuts. We'll see how that works for me. smile
krisp14u
Oakley4All!
PostPosted: Wed Jun 18, 2008 5:33 pm    Post subject: Reply with quote Add User to Ignore List
Just go nuts I’ve almost filled 108U of MOTM
I think its time to build some Frac and Euro
we're not worthy Nice Cabinet by the way love the grain in the wood we're not worthy
I wish I had the wood working skills and confidence to build some nice Oak Cabinets
Kwote
PostPosted: Wed Jun 18, 2008 5:51 pm    Post subject: Reply with quote Add User to Ignore List
kinda ironic considering you make Oakley modules. 8)
kwotemusic.com
my other sites
felix
Loves the manuals!
PostPosted: Sun Jun 22, 2008 7:55 pm    Post subject: Reply with quote Add User to Ignore List
My DIY cabinet is an epic failure. sad banana
I've officially given up...something I really should have done a long time ago. Doepfer Monster Case will be obtained in the very near future.
If you feel like reading the gory details of this afternoon:
http://felixinferious.blogspot.com/2008/06/modular-cabinet-update-epic -fail.html
I've got DIY case stuff for sale if anyone wants it; Vector rails, PSU:
http://www.muffwiggler.com/forum/viewtopic.php?p=9719#9719
futuresoundsystems
<3 CMOS
PostPosted: Mon Jun 23, 2008 4:05 am    Post subject: Reply with quote Add User to Ignore List
:( Shame that, sounds like you had nice wood too. My cabinet's rails aren't totally level (one end of each row is either a little shorter or taller than the other) but I can live with them.
spbaker
PostPosted: Mon Jun 23, 2008 8:57 am    Post subject: Reply with quote Add User to Ignore List
i'm really really sorry it happened like that sad
it sounds like you had a super effort at it and have come to a good resolution with getting a monster case- so now you can get down to business and make more of those awesome vids!! hyper
make sure you share with pictures when its all in there!
new DVD out now HÄXAN
things to listen to and look at:
http://abreojos.net | twitter | facebook
The cake is a lie.
PostPosted: Wed Jun 25, 2008 2:18 am    Post subject: Reply with quote Add User to Ignore List
we need a drooling smiley
THAT IS SUPER SWEET
very inviting and warm n' cozy and so much synthy fun
we're not worthy
awesome
consumed
International Filter Conspiracy
PostPosted: Wed Jun 25, 2008 9:11 am    Post subject: Reply with quote Add User to Ignore List
congrats jeff! looks like you did a real nice job on that!
i like how you have the modules recessed pretty far back too, that looks classy.
i just noticed the original post was from november, and you finally made it happen.
now you know you'll be building a matching cabinet in about 9 months, right? lol
i did a "moog style" cabinet too, a 1u, after looking at .com cabinets.
but i routed the edge of the wood back 1/4" (1/8" for stooge rail and 1/8" for the panel thickness) so the panels would lay flush with the edges. i wish now that i had added another 1/8" so they would be slightly recessed under the lip. i had other problems with the cabinet, mostly warped wood which prevents anything from sitting flat on the top. Dead Banana
and some of my modules dont sit quite flush, like the thicker fpe panels.
soundcloud | bandcamp
synthetic
TASCAM Hero!
PostPosted: Wed Jun 25, 2008 5:11 pm    Post subject: Reply with quote Add User to Ignore List
Thanks. Yeah, I'll probably end up building another cabinet one day. But first I want a PCM96, and I'll need to save up quite a bit for that. hyper So I might not fill the 24u right away. (Plus MOTM can get expensive, almost as bad as Serge...)
Page 1 of 3
