video integration |
tuj Super Deluxe Wiggler
   Posts: 1104 Location: Houston
Posted: Wed Oct 27, 2010 2:23 pm Post subject: video integration |
I want to integrate video to my work, very tightly coupled type stuff.
Can someone suggest to me a good way to go about this in terms of software? I use Live as my DAW and I know it can do a bit of video, not sure that it can handle what I'm thinking.
Ever see the 'We Have Explosives' video from FSOL? That's the type of thing I'm thinking. Or Coldcut's Natural Rhythm. Very tight integration of visual elements with timbre elements/rhythmic events.
And no, I don't want to do a eurorack video-scope type thing, even tho that stuff is cool too.
Also recommendations for a camera would be appreciated as well.
Wigglers thoughts appreciated! _________________ too i for your dm
http://www.renkucorp.com |
sandyb reap what you sow
Posted: Wed Oct 27, 2010 2:59 pm Post subject: |
if you're wanting to do video that is reactive to the sounds you produce things that spring to mind are quartz composer, max/msp/jitter or isadora maybe.
if it's to hand cut the video to your music then pretty much any video editing software will do the trick. it's more down to your skill editing it then. something like motion or after effects might be useful depending on exactly what you're doing. _________________ it does matter |
xpander Super Deluxe Wiggler
    Posts: 1045 Location: los gatos, california
ndkent Super Deluxe Wiggler
spbaker Veteran Wiggler
    Posts: 688 Location: melbourne australia
Posted: Wed Oct 27, 2010 7:55 pm Post subject: |
it's fantastic that the hardware and software we (the great unwashed masses) have access to now, that this kind of thing can be realised without custom hardware and a million dollar budget.
do you want to do this live or as a carefully crafted AV track?
if it's live then look at Quartz Composer (mac only but "free" as it comes with he developer tools) or Max/MSP/Jitter, or even the multipurpose VDMX is great, as it has lots of audio FFT stuff that can be sent to various video clips. If you want to record any of these then you'll need a screen recorder like iShowU HD.
if its a bit more control you are after the After Effects or Apple's motion will give you that capability. Just convert the audio into keyframe data and attach it to the parameters of whatever you want. check out this tutorial on videocopilot.net _________________ new DVD out now HÄXAN
things to listen to and look at:
http://abreojos.net | twitter | facebook |
dkcg I pity the fool w/o enough VCAs
    Posts: 7248 Location: LA
Posted: Wed Oct 27, 2010 8:46 pm Post subject: |
| xpander wrote: | | max/msp/jitter. i doubt there's anything better. |
I get more interesting things out of MaxMSP/Jitter, but Isadora is MUCH quicker to get going. Primarily since it's on a higher level than Max, less programming the basics. There's some interesting freeframe effects out there too.
You'd get more flexability with Max tho. I saw these objects a year or two ago, they weren't free then, but low and behold, now they are. Some interesting video effects for jitter. yay.
http://auvi-software.com/
Back to isadora, I made a patch that plays a long nuclear test movie file, analyzes audio levels to animate parameters synced to the live sound, very little noticable lag from audio to video, also synced with midi from Live, so it pulsates parameters on top of the audio analysis with the Live clock. But it's not free, and not super cheap.
VDMX, which is nice, but more like a fixed synth architecture in comparison to Isadora or Max. Actually, I think they used MaxMSP in the creation of VDMX. |
Bricks paper kettle
     Posts: 1956 Location: Hypermagic Mountain, USA
Posted: Wed Oct 27, 2010 11:28 pm Post subject: |
If you do any coding, Processing is all bees and knees _________________ paperkettle.com
illucia and Codebending updates:
twitter, facebook, Google+ |
amsonx Grey Man Patcher
   Posts: 1115 Location: Genova, Italy
Posted: Thu Oct 28, 2010 8:28 am Post subject: |
another choiche is Isadora, the Mac version has audio capabilities too and use the AU..
personally i own VDMx and Isadora and are two different animal but in common have a modular approach to workflow and good integration with quartz composer
BTW they are'nt free
Posted: Thu Oct 28, 2010 8:33 am Post subject: |
| dkcg wrote: | | xpander wrote: | | max/msp/jitter. i doubt there's anything better. |
in the prior version yes Vidvox has used max/msp to code but this is an all new version coded with xCode.
now Vdmx has a ton of routing capabilities and the QC integration that is really powerful, but yes is more "fixed" that Izzy |
Posted: Thu Oct 28, 2010 8:52 am Post subject: |
I guess I should add that I work on pc, so that's a limitation for me. I haven't worked with Max in well...probably a decade but I do remember it a little at least. Which is to say that the object-type environment programming isn't entirely foreign to me. I also used SuperCollider at one point as well.
So it seems to be starting to narrow down to Max/MSP, VDMX, and Isadora?
Edit: I guess VDMX is out because its mac-only? |
Posted: Thu Oct 28, 2010 2:18 pm Post subject: |
give isadora a try and see what you think. it works fine on a pc. i use it on macs now but had no problems with it on pc in the past. you can download it here:
http://www.troikatronix.com/izzy-download.html
the download is a completely working demo, except you can't save the projects. _________________ it does matter |
franzschuier fart box afficinado
Posted: Thu Oct 28, 2010 2:36 pm Post subject: |
| sandyb wrote: | give isadora a try and see what you think. it works fine on a pc. i use it on macs now but had no problems with it on pc in the past. you can download it here:
the download is a completely working demo, except you can't save the projects. |
Another Isadora User here. Love it, BUT one of the main aspects i like about it is the Core functionality which is only available on mac. - You can write your own plugins in Quartz composer and play very complex patches rigth of the GPU.(e.g. real time rendering/texturising of 3models while ableton is running on the same machine) I programmed my own Vj Setup in Isadora and did a gig on saturday 7 Hours stable.
Whats great for building a video/audio show is the stage paradigma in isadora. The standart features are pretty good allready and the licensing model allows to play patches on any demo machine. So you can build on one machine but run on several, even with one licence.
Be sure to download the latest beta, hidden well on the site:
http://www.troikatronix.com/izzy-prereleases.html
Posted: Thu Oct 28, 2010 2:45 pm Post subject: |
| franzschuier wrote: | ...
Whats great for building a videio/audio show is the stage paradigma in isadora... |
i love the ability to link and jump between the stages.
makes it easy to keep complex patches in easy to digest pieces too. _________________ it does matter |
Posted: Thu Oct 28, 2010 4:22 pm Post subject: |
check out VVVV too for PC, i've heard good things, and i think it's free? _________________ new DVD out now HÄXAN
laserpalace Super Deluxe Wiggler
   Posts: 1143 Location: Chicago
Posted: Thu Nov 04, 2010 3:59 pm Post subject: |
i'm currently working on circuit bending an old NES to take voltages from my modular during a live performance, so far it's been successful. I've added a couple LFO's to the NES to fluctuate different bends. I'll post some videos when I get it working properly. _________________ Wiard Love | Sounds | Laser Palace | Voltage Controlled Tumblr |
rastko Wiggling with Experience
   Posts: 295 Location: Yangon , Myanmar
Posted: Thu Nov 04, 2010 5:19 pm Post subject: |
Yes isadora is very good and not so hard to learn, but maybe I am wrong and I can not check the videos you mention now but you want something like a video sampler .
If yes and any was maybe you did not know but you can import directly video into able ton live.
So as you would play clips you play video with sound. Insect buzzing and then elephants farting in like the Tempo you play your clips . Or without sound.
Sorry if misunderstood what you want to do.
R |
lizlarsen Super Deluxe Wiggler
   Posts: 1970 Location: Denton, TX
Posted: Wed Nov 24, 2010 5:18 am Post subject: |
| Quote: | | And no, I don't want to do a eurorack video-scope type thing, even tho that stuff is cool too. |
I don't know if you're talking about the Videoscope module or all video modules, but if you haven't checked out my system:
http://www.lzxindustries.net
We'll be expanding into video clip player and frame buffer/digital processing modules for the system within a few months if the all analog stuff isn't your thing. Clip player will be fully MIDI controllable.
As far as DAWs go I use Ableton + Silent Way to send CV to video along with audio sequences, loads of fun.  _________________ LZX Industries | http://www.lzxindustries.net |
Posted: Wed Nov 24, 2010 5:20 am Post subject: |
Oh, and my vote for software would be Resolume Avenue. It's got extensive MIDI mapping, so you can loop it back from Ableton and have the DAW trigger all the sequences. _________________ LZX Industries | http://www.lzxindustries.net |
stk Super Deluxe Wiggler
  Posts: 3576 Location: rat city, vic au
Posted: Wed Nov 24, 2010 5:49 am Post subject: |
| ndkent wrote: | | The mention of relatively older acts like FSOL and Coldcut makes me think of something more like Arkaos, which was out then and now. |
I used to use Arkaos quite extensively. Pretty cool stuff like BPM detection, beats -> trigger, Freeframe filters, MIDI control and the like.
I'm sure Jitter / Quartz and the like could do all that and more these days. _________________ new terminal sound system 2xlp/cd/digital out now | soundcloud / antisound.net | my modular
"This place is a giant "fuck you" to that system, to that attitude, to that pedagogy. ... We are winning! And only by remaining free and open do we maintain that position. For you, and for me, and for the children. For the music." - Muff Wiggler |
