Muff's Modules & More cats and modular synths, but mostly cats
MIDI Beat Clock (Arduino-powered) |
snufkin Wiggling with Experience
Posted: Wed May 04, 2011 7:49 am Post subject: |
would totally be up for a workshop guys
I have quite a bit of diy soldering experience and even a scope I could bring (although I'm not sure its calibrated) however i lack some of the technical knowledge useful in debugging and more complex builds
always good to build stuff together and share skills _________________ http://videocircuits.blogspot.com/ |
synthomaniac Wiggling with Experience
  Posts: 391 Location: Portsmouth UK
Posted: Tue May 17, 2011 7:49 am Post subject: Workshops |
@Monobass, Tombola and snufkin
Workshops sounds like a great idea - I thought it might be neat to combine a workshop with a Modular Meet and have made an enquiry about doing that at the next London meet but that event is not looking too hopeful.
I have had some requests, in my DIY Prototyping Kit topic on Muffs, to take a design from concept through to build. One way is as an online project, a bit like an electronics mag project, but the other way is as a workshop.
I'd like to gauge the interest, location and content/format. So here are some questions:
How may people want to do this? Where are you located? What exactly do you want to get out of a workshop?
The options for the content/format are:-
Basic electronic theory - Ohm's law through to op-amps (simple arithmetic no heavy theory) - so you can work out the resistor values you need for an op-amp mixer for example or working out what value resistor you need for a LED running off 12V - that kind of thing. Signal parameters such as voltage, current, load and output impedance, frequency.
Basic synth building blocks - VCO, VCF, VCA, ADSR, LFO circuits - basic theory of voltage control, gates/triggers etc.
Basic skills - soldering, laying out a perf board, measurements with a scope and DMM.
A guided project - e.g. design a LFO, understand how it works, lay it out on a perf board, solder it together and test it. This could be done in a hardware agnostic way using a bunch of pots, components and perf board or could be done using a Synovatron prototyping kit with front panel for a more complete solution.
Please ping me your thoughts and contact any buddies who may be interested too. This will take some organising and commitment from everyone and I'm more than happy to present this if there is enough interest and we can accomodate everyone's needs.
Check out my blog for the CV Tools Project which is a bit ambitious for a one day workshop but gives you an idea of the design/development process (we could just do a build CV Tools Kit workshop if you fancy building one but need a bit of help).
http://synovatron.blogspot.com/p/cv-tools-project.html
Tony _________________ Synovatron Electronic Music
Eurorack DIY kits, modules (CV Tools, CVGT1), AS-Doepfer Adaptors, Ribbon cables
http://soundcloud.com/monakrome
Synths: Minimoog Voyager, Roland SH09, SH5, 100m modular, 2 Sequential Circuits Pro Ones, Eurorack modular, Novation K-Station, Novation KS4 |
