Adding an additional PSU in M9 |
qu.one hypnotic and sanctified
   Posts: 3806 Location: Bronx, NY
Posted: Mon Oct 17, 2011 12:01 pm Post subject: Adding an additional PSU in M9 |
Hey Guys (or Steve),
I have an M9 that seems to be intermittently losing power with a guesstimate draw of around 800ma lately and I was wondering about adding an additional doepfer PSU into the case for an additional power source. I am pretty sure i have Monorocket 1 PSU (logo on the main PSU).
Has anyone else done anything similar? Is it possible?
Thx
Stephen _________________ www.pro-modular.com | MW OpenTape | Instagram
Josh has the proportions of a shaved Yeti, so if he sat on me I would be reduced to Quantum Foam. - Grant Richter |
Posted: Tue Oct 18, 2011 8:19 am Post subject: |
Posted: Sun Oct 23, 2011 6:39 pm Post subject: |
no one?
i havent had a chance to check inside my case yet - but i'm even wondering how i could chain the supplies together...
i am pretty sure i have this supply (image courtesy chinard):
Low-Gain Super Deluxe Wiggler
   Posts: 2627 Location: Minneapolis, MN
Posted: Sun Oct 23, 2011 8:40 pm Post subject: |
Totally possible. Got an M9 to do the same thing to myself..
I would toss a 2nd supply in there and just use the 2nd supply for 1 of the 3 rows.. by itself. just remove the 1 row from the other 2 rows.
Pretty straight forward.. I can try to explain in more details when i'm not hopped up on pain killers... just had surgery last wednesday so i'm a lil'f'd'up
 _________________ -]|- Low-Gain Electronics -|[-
twitter.facebook.bandcamp.flickr.vimeo.youtube. |
Posted: Tue Oct 25, 2011 7:58 am Post subject: |
Thanks Logan! And rest up.
A few questions when you're ready, but woulthreat method mean they would be powered separately? My intention was to double up the psu but still use only one 3 prong cable for power.
I need to email Steve I think before I do something stupid! _________________ www.pro-modular.com | MW OpenTape | Instagram
eef Cardiganed Beardy
  Posts: 108 Location: Santa Fe, NM
Posted: Wed Oct 26, 2011 10:10 pm Post subject: |
Logan, by coincidence I also had surgery last Wednesday! Mine was no cut, so not too much pain killer needed. Hope you are feeling better.
Back OT, perhaps your remoted heat sink solution might work. My M9 with orig psu couldn't handle an R-53, but modded it does. Or do you no longer feel that's a good solution? _________________ http://soundcloud.com/robert-efroymson/ |
consumed International Filter Conspiracy
     Posts: 3375 Location: nor cal
Posted: Thu Oct 27, 2011 9:20 pm Post subject: |
hey stephen, i'm not familiar with the monorocket case and power, but i would second that you install your own psu and power one or two busboards from it only. have you considered installing a power-one psu instead of a doepfer psu? _________________ soundcloud | bandcamp
Posted: Fri Nov 11, 2011 9:36 am Post subject: |
power is shutting off more frequently now - replacing the power seems like it is a must.
weird thing is that it was not happening when it was connected directly to a wall outlet in my office and i left it on practically all day. as soon as i brought it out, plugged it in to a strip, it would power down in 5 minutes or less. i have to test this out at home, so it might be a simple fix until I can get a replacement power supply.
most annoying is that the potential draw of the case is less than 750ma. _________________ www.pro-modular.com | MW OpenTape | Instagram
Posted: Fri Nov 11, 2011 8:22 pm Post subject: |
3 linear regulators to drop down & filter an external 15V switching supply.
MAX current handing per row... 1.2-3A though i wouldn't run more than 800ma-1A...
This case is now in beast mode!!
<3 me some Monorocket cases! _________________ -]|- Low-Gain Electronics -|[-
Posted: Sat Nov 12, 2011 5:22 am Post subject: |
Sick! _________________ www.pro-modular.com | MW OpenTape | Instagram
Posted: Sun Nov 13, 2011 10:45 pm Post subject: |
It took some module shuffling, but the case seems to be back working steady again. Figured to try that again before I took apart the power system. I had it on for over 3 hours with an issue. _________________ www.pro-modular.com | MW OpenTape | Instagram
evil wizards Common Wiggler
Posted: Mon Jan 30, 2012 11:00 pm Post subject: |
| Low-Gain wrote: |
<3 me some Monorocket cases! |
So i'm curious where you got the parts to do this and how much you spent on it. I'm now on my third monorocket case and again having power problems. top 2 rows are fine, bottom rows in the gemini are semi working... modules turn on and work, but a few modules buzz only on those rows, don't work properly and have LED's that won't turn on. I sent a couple modules back to their manufactures before realizing the modules weren't the problem. I have no idea how to do any of this myself, but if its affordable I want to GUT THE FUCKER and take it to someone who can hook up a system like that. So yeah.. any advice where to pick those parts up? would be much appreciated. I would love to turn this thing on and have everything work as it should. Several thousand dollars worth of shit it in and all...
Posted: Tue Jan 31, 2012 11:04 am Post subject: |
i wound up just adding a µZeus to mine after having intermittent power issues again. i plug all digital modules into it. _________________ www.pro-modular.com | MW OpenTape | Instagram
monorocket Common Wiggler
Posted: Thu Feb 02, 2012 12:10 am Post subject: |
| evil wizards wrote: | I want to GUT THE FUCKER and take it to someone who can hook up a system like that. So yeah.. any advice where to pick those parts up? would be much appreciated. I would love to turn this thing on and have everything work as it should. Several thousand dollars worth of shit it in and all...
Sam - I just offered to upgrade your case as a warranty repair via email.
Please reply to that message and let me know what you'd like to do. |
ThinLazy Veteran Wiggler
  Posts: 688 Location: Philadelphia, PA
Posted: Thu Feb 02, 2012 9:37 am Post subject: |
Great, thank you Steve! I'll reply to your email.
Awesome,
-Sam |
Posted: Thu Feb 02, 2012 3:34 pm Post subject: |
| ThinLazy wrote: | Great, thank you Steve! I'll reply to your email.
Awesome,
-Sam |
Sam - that was a different Sam I replied to.
Now that everyone's been contacted via mail - I'm going to close this thread |
