LZX Industries 2012 Releases |
lizlarsen Super Deluxe Wiggler
   Posts: 1970 Location: Denton, TX
Posted: Fri Feb 10, 2012 9:05 pm Post subject: |
Photo from the workbench, we're very close on these.
 _________________ LZX Industries | http://www.lzxindustries.net |
Matos Modular masturbator
 Posts: 2236 Location: Brooklyn
jjr Common Wiggler
 Posts: 206 Location: Baltimore
Posted: Thu Feb 16, 2012 12:37 pm Post subject: question |
hey lars
will these modules :
LZX 2012 Production Cycle #3, Video Input
be for getting a second stable video signal into the LZX with out synch gen?
Like if I had two DVD players and these modules could I mix both DVD's together ?
thanks
jjr |
Posted: Thu Feb 16, 2012 1:26 pm Post subject: |
| Quote: | | be for getting a second stable video signal into the LZX with out synch gen? Like if I had two DVD players and these modules could I mix both DVD's together ? |
That's right, that's the "Frame Synchronizer" portion of "Color Video Decoder & Frame Synchronizer". It's a full-frame timebase corrector. With the CVD&FS module, video input is fully worry-free. You can get composite video in full color into the system without having to worry about things like genlock, external TBCs, etc. With two CVD&FS modules, TVFKG, and Color Encoder, you basically have a fully patchable traditional "video mixer" with luma and chromakey features. So you can get any two full color signals in, mix them, modulate them, output them, etc. _________________ LZX Industries | http://www.lzxindustries.net |
jjr Common Wiggler
Posted: Thu Feb 16, 2012 3:10 pm Post subject: question |
lars
if I was only interested in mixing two separate B/W dvd's would this still be the best way to go ( if I dont want to mess with synch gen out side of LZX modules) or would you suggest something else like 2 VSG? |
Posted: Thu Feb 16, 2012 3:16 pm Post subject: |
Well 2 VSGs won't really do anything for you. No time base correction occurs there, so the two VSGs would be out of sync with each other... and if one is sync'ed to the other, you still can only have one external "master" video source.
You could do one CVD&FS and one VSG if you want two black & white sources. It's just that the CVD&FS is going to have a ton of features you aren't using in this scenario.
Here's a trick that may work for you though... when you're preparing your DVD to be burned, mix up to three separate B&W video sources together using RGB channels (one image is red, one is green, one is blue, all mixed to one video output) and burn the DVD that way. Then when you play this DVD into CVD&FS, you can use the RGB outputs as three separate video sources! That way, with one CVD&FS and VSG, you could get up to four external source feeds to mix and manipulate inside the system. Does that make sense?
This works great when using VJ software as a source too, since you can usually easily manipulate the color channel information of each feed sent to the output. _________________ LZX Industries | http://www.lzxindustries.net |
johnnywoods Super Deluxe Wiggler
   Posts: 1101 Location: Los Angeles
Posted: Thu Feb 16, 2012 3:28 pm Post subject: Re: question |
you could also get a dvd player with external sync in, although they tend to be on the expensive side.
| jjr wrote: | lars
_________________ http://www.mathematicalpark.com |
jjr Common Wiggler
Posted: Thu Feb 16, 2012 3:34 pm Post subject: ok - one more |
so with CVD&FS and one VSG you can mix to B/w dvd's together - but you'd be way under utilizing the module ?
I think I just dont understand the CVD&FS or what it does. One function ( I think) is that it can take a color dvd and break it into three separate color channels that can then be patched into an LZX rig eventually finding there way back to the CVE ? OR is it ment to be a possible alternative to getting signals in and out of the lzx? do you still need a CVE and VSG if you own the CVD&FS?
thanks
lars |
Posted: Thu Feb 16, 2012 3:43 pm Post subject: |
| Quote: | | so with CVD&FS and one VSG you can mix to B/w dvd's together - but you'd be way under utilizing the module ? |
Not exactly. The technique I describe is kind of a "hack", using the color channel information to encode three separate black and white images into one color source. So all three B&W videos would be playing back simultaneously off of a single DVD player as color video. The CVD&FS then decodes the image into three color channels (which are the original 3x separate B&W videos) and you can patch them as separate signals inside the LZX system.
| Quote: | | One function ( I think) is that it can take a color dvd and break it into three separate color channels that can then be patched into an LZX rig eventually finding there way back to the CVE ? |
That is correct. This is the primary purpose -- an input module that's VERY feature-rich with all the proc-amp/geometric transformation controls.
| Quote: | | do you still need a CVE and VSG if you own the CVD&FS? |
If you want to use the full system, then yes -- you still need all these modules. But the CVD&FS has a "preview" output on a composite jack. Typically this goes to a preview monitor so you can preview that input before it goes into the rest of your patch (but after all the buffer/procamp effects.) But that also means you can also use CVD&FS standalone as a digital effects module without any other LZX modules, and then expand it later with the VSG & CVE, etc.
In other words: CVD&FS doesn't require Color Video Encoder & Video Sync Generator to operate. But it is not an alternative to using them in the context of a full video synthesizer system. _________________ LZX Industries | http://www.lzxindustries.net
jjr Common Wiggler
Posted: Thu Feb 16, 2012 3:47 pm Post subject: AH ! |
| I understand - thanks lars ! |
Posted: Thu Feb 16, 2012 3:48 pm Post subject: |
I'm sorry, I don't think I answered this question correctly:
| Quote: | | so with CVD&FS and one VSG you can mix two B/w dvd's together - but you'd be way under utilizing the module ? |
That is correct. Because you'd only be taking the "Y" output, and leaving the other decoded outputs alone. You just wouldn't be taking advantage of all the features involving color decoding, or the proc-amp controls related to color (Hue, Saturation.)
There's nothing wrong with using it this way at all, it's just not maxing out the module's potential. _________________ LZX Industries | http://www.lzxindustries.net |
daverj Vintage Video Wiggler
Posted: Fri Feb 17, 2012 1:04 am Post subject: Re: question |
| johnnywoods wrote: | you could also get a dvd player with external sync in, although they tend to be on the expensive side.
| jjr wrote: | lars
One cheap DVD player and one used Pioneer DVD-V7400 player (about $250 used on ebay) will get you two B&W videos locked together. The 7400 attempts to lock in color, but it will randomly be off 180 degrees half of the time. But the B&W parts are locked (if it's locking to something stable like a DVD) _________________ Dave Jones Design | http://www.jonesvideo.com |
Posted: Fri Feb 17, 2012 1:43 am Post subject: |
Interesting -- I hadn't even looked into genlocking DVD players before. I'll have to add that model to the wiki for sure. _________________ LZX Industries | http://www.lzxindustries.net |
jjr Common Wiggler
Posted: Fri Feb 17, 2012 10:39 am Post subject: dvd synch |
hey dave jones ( and all) ,
With the Pioneer DVD-V7400 player - after it is in synch - then would you patch the video RCA signal out directly into the LZX system?
OR do you have to separate the color parts of the image first - when would the 180 degree issue be a problem when working with the LZX ?
thanks
jjr |
Posted: Fri Feb 17, 2012 10:48 am Post subject: |
| Quote: | | With the Pioneer DVD-V7400 player - after it is in synch - then would you patch the video RCA signal out directly into the LZX system? |
In that case, you'd want the Triple Video Interface module to get the signal into the LZX system. This module is basically all the analog video input stuff -- DC restoration, blanking, scaling to 1V, etc. Patching the signal directly in (via RCA-to-1/8" cable adapter) would work but you'd see some fluctuating brightness levels since the video is not DC restored. Might not be an issue.
| Quote: | | OR do you have to separate the color parts of the image first |
If the DVD-V7400 has Component (YPrPb) outs, you can feed those directly into Triple Video Interface, which includes a YUV>RGB converter. If all it has is Composite or S-Video out, you will only be able to get B&W video into the system unless you have Color Video Decoder & Frame Synchronizer.
| Quote: | | OR do you have to separate the color parts of the image first - when would the 180 degree issue be a problem when working with the LZX ? |
It wouldn't be an issue for working with the LZX, since the subcarrier never goes into the system. In the case that you are dealing with decoding the subcarrier to color channels (ie, you have the Color Video Decoder & Frame Synchronizer) then you don't need to lock the external device anyway, so there is no phase problem and you can use a cheaper DVD player.
So two basic options...
Cheap DVD Player + Color Video Decoder & Frame Synchronizer
Genlockable DVD Player + Triple Video Interface
The first option has many more features. The second option may be cheaper by around a couple hundred bucks. Both let you get full color video into the system. _________________ LZX Industries | http://www.lzxindustries.net |
Posted: Fri Feb 17, 2012 2:29 pm Post subject: |
The DVD-V7400 (and the DVD-V7300D for those in Europe or Australia) has composite, S-Video, and Component outputs. The Y output of the component is already a B&W signal. Or you could feed the signals in to Lars' interface and convert the color to RGB. The subcarrier being off 180 degrees wouldn't matter there. It would matter if you tried mixing two color images directly without first converting to RGB.
The Y output of the component output is DC restored, but might be biased wrong for the LZX, so would need a constant DC added or subtracted to feed it directly without going through the interface. _________________ Dave Jones Design | http://www.jonesvideo.com |
gde anti-zarzutzki
Posted: Sat Feb 18, 2012 3:31 pm Post subject: |
I don't know if this has been mentioned in the thread yet, but you can use the amplitude classifier as a sequencer(not its best purpose, but fun nonetheless). The 8 bias knobs are the values of each "step". If you plug in a saw waveform and attenuate it right, it will cycle through the 8 values and attenuating it even more will shorten the step length... of course its more interesting to use other waveforms or inputs, but the saw makes it easy to explain.
Also, you can plug in 8 signals and once again throw a slow signal instead of a video signal into it and select between them. Like the function on the blacet scanner module I guess, but 8 signals.
It's been years since I touched the IP so maybe I didn't explain it right, but there sure is a lot of "easter eggs" to be had by using the modules for audio or CV rates. _________________ Flickr
YouTube |
jjr Common Wiggler
Posted: Mon Feb 20, 2012 11:25 pm Post subject: what does this do? |
what does the Sandin IP Differentiator do? can it be used if you dont own any of the other IP modules?
thanks
jjr |
Posted: Mon Feb 20, 2012 11:36 pm Post subject: |
| Quote: | | what does the Sandin IP Differentiator do? |
It's a high-pass filter. In video-land that means it extracts edges from a signal. Here it can be seen in a very straightforward example, both by itself and then again blended with the original input signal. In the latter case, it can achieve edge sharpening and blurring.
The Triple Video Multimode Filter can achieve similar effects (it has a high-pass output too) but is a an altogether different implementation.
| Quote: | | can it be used if you dont own any of the other IP modules? |
Yep, these are processing modules that live inside the LZX system same as the other LZX processing modules. Like the other LZX processing modules, they can't process video without the Video Sync Generator and Color Video Encoder. _________________ LZX Industries | http://www.lzxindustries.net |
jjr Common Wiggler
Posted: Tue Feb 21, 2012 12:04 am Post subject: one more question- for real last one ! |
This may be a dumb question but is the IP Differentiator function to help with video aliasing ? or is that something else ?
thanks lars |
