Output to mixer?
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> 5U Format Modules
Author Output to mixer?
KnobHell
PostPosted: Sat Feb 18, 2012 10:50 am    Post subject: Output to mixer? Reply with quote Add User to Ignore List
HI,
I'm sure this has been covered before...
What are you guys using to connect the output of your synths to mixers/sound systems? i.e. The voltage output of a synth is 10 volts, standard audio 1v ptp. I assume an attenuator. Do standard modules exist?
Thanks for indulging a newbie.
len
dslocum
darwin's nemesis
PostPosted: Sat Feb 18, 2012 11:19 am    Post subject: Reply with quote Add User to Ignore List
I use a cheap off-the-shelf Alesis mixer, and the 1/4" line inputs seem to be fine with the higher levels.
Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
WTB: TipTop Z-DSP
"sounds like a scary and demented merry go round." - decaying.sine
schmidtc
PostPosted: Sat Feb 18, 2012 12:40 pm    Post subject: Reply with quote Add User to Ignore List
Line level audio is a bit more than that. In most applications, the MOTM mixers have a gain <1 and that's a good one to run into a mixer. I settled on using a few mixers with roughly x10, 1x and .4x gain, and it's simple to set these values by swapping the feedback resistors.
pugix
PostPosted: Sat Feb 18, 2012 5:14 pm    Post subject: Reply with quote Add User to Ignore List
I built my own output mixer.
http://pugix.com/synth/matrix-mixer/
It has a jumper to select between unity and 50% gain, which I leave at 50%. The audio taper pots do the work of reducing the nominal 10V p-p synthesizer levels down to line level. I usually have this module patched over to my Mackie mixer.
I also built a smaller version, using the same basic circuit, but with a different approach to the panel.
http://pugix.com/synth/dual-mixer/
Richard
http://www.pugix.com
KnobHell
PostPosted: Sat Feb 18, 2012 11:37 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for the replies, I think that helps me better know what to do.
Len
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> 5U Format Modules All times are GMT - 5 Hours
