malekko JAG for vector synthesis |
matttech Super Deluxe Wiggler
  Posts: 5964 Location: uk
Monobass thonk.co.uk
   Posts: 6514 Location: Brighton, UK
Posted: Thu Mar 08, 2012 7:22 am Post subject: |
or a couple of Intellijel ufades maybe? maybe the Toppobrillo Mixiplexor?
you don't quite have a the flexibility of 4 vcas with those, but it's maybe a lot more compact/simple in terms of CV control. _________________ Thonk - Modular Synth DIY
258J Euro kit - Manhattan Analog Kits- 4ms Kits - Clarke68 Panels - Expert Sleepers Glow Cables - Banana Jacks |
READYdot controlled by voltage!
   Posts: 845 Location: Luxembourg, EUROPE
Posted: Thu Mar 08, 2012 8:04 am Post subject: |
Wow, never occured to me to try vector synthesis with my modular... now I know why i NEED a JAG!  _________________ WANT uATT, TTA BD808 CB808 HT909 |
mudlogger Ultra Wiggler
  Posts: 909 Location: UK + Thailand
Carci Wiggling with Experience
  Posts: 490 Location: Paris - France
cillianjohn Wiggling with Experience
Posted: Thu Mar 08, 2012 9:20 am Post subject: |
Good timing, I was trying out some vector synthesis for the first time last night using choices and my cwejman 4vca-mx. _________________ http://soundcloud.com/cillianjohn |
algorhythm Veteran Wiggler
 Posts: 592 Location: Canada
Posted: Thu Mar 08, 2012 9:40 am Post subject: |
| Yup, a Choices stick and the VCA Matrix or HexVCA work great for this... |
slow_riot Super Deluxe Wiggler
   Posts: 1904 Location: uk
Posted: Thu Mar 08, 2012 9:50 am Post subject: |
you might want to look into the Boogie filter as well. With that set up you can use the joystick to morph between all manner of filter types.
for me the perfect VCA for the JAG is the Blacet Super VCA which is basically like the Fonitronik Attenuverting Mixer but with voltage control (and no inversion). The main difference with this and the Doepfer VCAs is the addition of a built in mixer but you might already have that functionality somewhere else. |
Posted: Thu Mar 08, 2012 10:45 am Post subject: |
so do i not actually NEED the JAG to do this then?
god this confuses me for some reason....
i've got loads of VCAs and Choices already (and inverters)...maybe i can just do it with them then
if so, could someone describe the patch? (the more detail the better)
i don't see how you could go between 4 different oscs with simply a joystick, 4 vcas and inversion (of two of them)
because.....if you had Choices set up in unipolar mode and then sent say X to the CV input of OSC1, and the inverted version multed out to the CV of OSC2, you could then fade between those 2 oscs. you could then do the same with the Y axis to mix between OSCS3 and 4.
so....in the middle you would get an equal blend of all 4 oscs.
but if you took the joystick all the way to the left of the X axis to get only OSC1, you would be half the way up the Y axis, due to the circular nature of the joystick travel
is this why you need the JAG?
or am i hopelessly confused about this again??
what i want to be able to do is have any of the oscs on their own (soloed), and then blend gradually into the next one round the circle _________________ WTB: Focusrite Octopre/ Saffire PRO40, Rubicon/Dixie, modcan dual delay
EXPERIMENTAL MODULAR SYNTH MUSIC:
MODULAR DEMOS:
https://soundcloud.com/matttech-offcuts
NON-MODULAR MUSIC (mainly):
http://soundcloud.com/blue-light-fever
http://www.last.fm/music/Blue+Light+Fever
OLD COMMERCIAL RELEASE: http://www.saltrecords.com/recordings/discography/?id=2&cid=11 |
ersatzplanet Synthwerks Design
    Posts: 2363 Location: Seattle WA
Posted: Thu Mar 08, 2012 11:13 am Post subject: |
The need of the JAG is when you want to do quadraphonic panning that follows the stick movement. With the typical 4-VCAs and a joystick you get places where the +/- nature of the axis of the joystick don't align with the Quad sound field. You need six VCAs to do it without a JAG. Two sets of left and right (for front and rear sets of speakers) and another set of VCAs to do the front and back (feeding the other two sets). Think of the joystick axis as + and - so the four corners are ++(FL), +-(FR), --(BR),-+(BL) and the middle as 0,0 (if you have a bi-polar joystick which most are not - you will have to add bias voltages to get these results). Now think of what 4 VCAs in the corners need to see as control voltages to pan a sound around. What happens in the BR position for instance? The joystick is turning everything off at this point. This is what the JAG is for - turning a two CV system into a four CV system.
The JAG with a VCA Matrix would be a ton of fun since the jag has many simultaneous outputs that all can be used with the VCA matrix. _________________ -James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
james@synthwerks.com
synthwerks@me.com
"It takes about a week to learn how to play a synthesizer, but several years to learn how *not* to play it." - Brian Eno |
Posted: Thu Mar 08, 2012 2:33 pm Post subject: |
| ersatzplanet wrote: | The need of the JAG is when you want to do quadraphonic panning that follows the stick movement. With the typical 4-VCAs and a joystick you get places where the +/- nature of the axis of the joystick don't align with the Quad sound field. You need six VCAs to do it without a JAG. Two sets of left and right (for front and rear sets of speakers) and another set of VCAs to do the front and back (feeding the other two sets). Think of the joystick axis as + and - so the four corners are ++(FL), +-(FR), --(BR),-+(BL) and the middle as 0,0 (if you have a bi-polar joystick which most are not - you will have to add bias voltages to get these results). Now think of what 4 VCAs in the corners need to see as control voltages to pan a sound around. What happens in the BR position for instance? The joystick is turning everything off at this point. This is what the JAG is for - turning a two CV system into a four CV system.
The JAG with a VCA Matrix would be a ton of fun since the jag has many simultaneous outputs that all can be used with the VCA matrix. |
right....ok.....so the general gist is that i need a JAG (or, to be more precise.....would "like" a JAG)
by the way James, any word on when the faders will be available in the EU? (might PM you about this actually). may be getting a skiff soon, which i may dedicate to real-time control stuff, and a couple of faders would be sweet! _________________ WTB: Focusrite Octopre/ Saffire PRO40, Rubicon/Dixie, modcan dual delay
MODULAR DEMOS:
Posted: Thu Mar 08, 2012 2:43 pm Post subject: |
| matttech wrote: |
To mix with four sources and use a joystick like those on a typical vector synth, you will need something to do the conversion. The only other way may be to find a joystick with dual pots in it instead of singles and make two sets of CV outs and wire them opposite but I haven't really tried that yet. Hmmm... A mechanical project.
| matttech wrote: |
by the way James, any word on when the faders will be available in the EU? (might PM you about this actually). may be getting a skiff soon, which i may dedicate to real-time control stuff, and a couple of faders would be sweet! |
Basically it is totally up to the distributors over there - they have to ask for them to get them. I guess enough people have to ask them before some threshold is reached. I for sure am not refusing to ship anything! If shipping and customs wasn't such a hassle (usually the distributor handles all that) then I would ship direct. You are not the only one asking for stuff in the EU. _________________ -James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
synthwerks@me.com
Leoespejo Veteran Wiggler
  Posts: 610 Location: Barcelona
Posted: Fri Mar 09, 2012 4:38 am Post subject: |
Mmmmm ...... Great information in this topic
A most try patch..  |
flashheart Veteran Wiggler
Posted: Fri Mar 09, 2012 1:07 pm Post subject: |
You can do this with crossfaders, but you actually need more than you think....
1st Xfader is between Osc 1 / 2, let's say X-axis
2nd Xfader is between Osc 3 / 4, X-axis again
3rd X fader - Y-axis is between the outputs of the 1st 2 Xfaders
Assuming your corners are:
Osc 1: Osc 2
Osc 3: Osc 4
TL gives you Osc 1, TC = 1+2, TR = Osc 2
CL gives you 1+3, centre = 1+2+3+4, CR = 2+4
BL gives you Osc 3, BC = 3+4, BR = 4
If you've the Doepfer dual Xfader you're 1/2 way there. X CV to both, then a couple of VCAs & and inverter to mix between the outs using the Y CV.
Using 4 VCAs gets more complex, fading between 1+2 or 3+4 is easy but how do you mix between the pairs? You need to actually control the CVs themselves with the joystick before they get sent to the VCAs (I think ). See I'm confused now.
I suspect this kind of headscratching is exactly what the JAG was designed for, but shirley you don't need to buy something else?
do you?  |
Posted: Fri Mar 09, 2012 1:32 pm Post subject: |
| flashheart wrote: | You can do this with crossfaders, but you actually need more than you think....
Osc 1: Osc 2
Osc 3: Osc 4
do you?  |
cheers for that. am starting to think that patching it may be more hassle than it's worth. OBVIOUSLY i need to buy more modules!!
the main thing is: i've got a credit note to spend at Escape From Noise, birthday money coming (my 40th) to spend at schneiders in berlin in april....and i've just sold my Les Paul
so i've got £800-odd to spunk, should i choose to (which i will, obviously...)
luxury items, that's what i want. and a cv to midi converter (i think) _________________ WTB: Focusrite Octopre/ Saffire PRO40, Rubicon/Dixie, modcan dual delay
MODULAR DEMOS:
pulse_divider triangletooth
 Posts: 1242 Location: Akron, Ohio, USA
Posted: Fri Mar 09, 2012 2:05 pm Post subject: |
Yes, JAG with VCA Matrix =  |
Posted: Fri Mar 09, 2012 2:46 pm Post subject: |
Osc 1: Osc 2
Osc 3: Osc 4
do you?  |
Here is the layout to do it with 6 VCAs or 3 VC panniers or Segue/X-fader arrangements.
I just kind of whipped this out and haven't really tested it yet but they should work in theory.
EDIT - Opps- Forgot some inverters needed if VCAs are used - picture updated. _________________ -James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
synthwerks@me.com
30ohm Wiggling with Experience
  Posts: 313 Location: SF
Posted: Fri Mar 09, 2012 4:16 pm Post subject: |
Ok, here's my question that has been puzzling me:
Why the hell doesn't the JAG have a joystick built-in????  |
RubberCityNoise Wiggling with Experience
  Posts: 342 Location: Akron Ohio
Posted: Fri Mar 09, 2012 4:26 pm Post subject: |
| 30ohm wrote: | Ok, here's my question that has been puzzling me:
Because this works awesome with LFOs and envelopes. Using a joystick is too predictable. Feed any 2 VC into it and get 12 separate outs!  _________________ Life without synthesis has no meaning!
http://www.rubbercitynoise.com |
Floyd Pepper Wiggling with Experience
  Posts: 256 Location: Northumberland, UK
Posted: Fri Mar 09, 2012 4:33 pm Post subject: |
Malekko / Wiard Joystick Axis Generator (JAG)
"Here we are checking out the super-awesome Malekko / Wiard Joystick Axis Generator, or JAG. There are four different drone tones running into the four inputs of a 4ms VCA Matrix, using two outputs summed to our Eventide Space reverb pedal. We're opening the eight(!) VCA's with the JAG being controlled by an Analogue Systems rs220 joystick module." |
Posted: Fri Mar 09, 2012 6:41 pm Post subject: |
| RubberCityNoise wrote: | | 30ohm wrote: | Ok, here's my question that has been puzzling me:
Because this works awesome with LFOs and envelopes. Using a joystick is too predictable. Feed any 2 VC into it and get 12 separate outs!  |
you could do both! joystick with normalled inputs  |
Babaluma Manual Gain Rider
     Posts: 6757 Location: Milan
Posted: Sat Mar 10, 2012 4:15 am Post subject: |
| 30ohm wrote: | | RubberCityNoise wrote: | | 30ohm wrote: | Ok, here's my question that has been puzzling me:
my old 311 new controller did just that. 2 JAGs, 2 normalled joysticks, and two gate push buttons. why this is not still being made, i will never understand! _________________ Hermetech Mastering | Discogs | SoundCloud | Bandcamp | Facebook | Pathmusick |
