New Serge style ASR and VCS for Euro! |
widgetoz Wiggling with Experience
    Posts: 314 Location: Sydney, Australia
Posted: Sun Mar 11, 2012 12:41 am Post subject: |
| gwaidan wrote: | | clarke68 wrote: | Mildly off-topic, but releated...is this a new module as well:
...? I don't recall seeing it before...obviously I need to start paying more attention to Elby. |
That one (and the Octave/Volts/Hertz) has been kicking around on Laurie's site as coming soon since about 2008. :)
| pulse_divider wrote: | | Veqtor wrote: | | pulse_divider wrote: | | the CGS one I have is not really usable for pitch. I guess it's possible that it has a technical problem, but it seems to be functioning (despite being sloppy on pitch) as intended and there don't appear to be any trimpots to calibrate. |
Did you build it yourself? Capacitor choice seems to be very important. |
Nope, it's a Metalbox build... Top notch quality.
I just google searched and found I'm not alone:
http://electro-music.com/forum/post-327227.html |
That thread seems to offer a solution-it's variable offsets in the hold amplifiers. Maybe National LF411As would be a good solution to that? |
Don't worry, this time it IS for real. |
gwaidan Super Deluxe Wiggler
    Posts: 1668 Location: Sydney
Posted: Sun Mar 11, 2012 7:46 am Post subject: |
| widgetoz wrote: | | gwaidan wrote: | | clarke68 wrote: | Mildly off-topic, but releated...is this a new module as well:
Yay!!! Great to see these two out in the wild at last!  _________________
| lordofthebored wrote: | | Any news on this yet? I just sold all my other modules of this type so I could replace it with this different implementation of the same thing! |
KNYST hiding in the forest
    Posts: 2300 Location: the Taiga, Sweden
Posted: Sun Mar 11, 2012 7:26 pm Post subject: |
| falafelbiels wrote: | So how deep will this VCS be then?
:hyper:
kits! |
7.3cm |
Posted: Tue Mar 13, 2012 11:25 pm Post subject: |
Have a look at the schematics on Laurie's site-looks like he's modded the circuit quite a bit including offset trimmers on all the hold amplifiers and using a modern low on-resistance DG409 instead of the original's generic CD4052 CMOS switch. It should be better-performing than the CGS original (or the Metalbox). _________________
Posted: Wed Mar 14, 2012 3:32 pm Post subject: |
| KNYST wrote: | | Depth of ASR? |
7.5cm |
Arcade Sinusoid Wiggling with Experience
  Posts: 387 Location: Chicago
Posted: Wed Mar 14, 2012 6:08 pm Post subject: |
These look great! May have to pop my kit cherry!  |
J Veteran Wiggler
   Posts: 540 Location: Yorkshire
Posted: Thu Mar 15, 2012 10:46 am Post subject: |
been looking at a few kits recently, and the VCS looks like the one to go for.
are these only available direct from elby?
cheers |
Isaiah Ultra Wiggler
Posted: Thu Mar 15, 2012 11:28 am Post subject: |
Does anybody know the depth of the VCS at all?
Thanks! |
flashheart Ultra Wiggler
Posted: Thu Mar 15, 2012 12:12 pm Post subject: |
| Isaiah wrote: | Does anybody know the depth of the VCS at all?
Thanks! |
| widgetoz wrote: |
PostPosted: Sun Mar 11, 2012 11:26 pm
kits! |
7.3cm |
Question to Widgetoz - can I just buy a panel? I've got the VCS CGS kit (note to self: finish it!) |
Posted: Thu Mar 15, 2012 1:06 pm Post subject: |
Oops!
Thanks! |
craque xenochronous wiggler
 Posts: 372 Location: SoCal / Fullerton
Posted: Thu Mar 15, 2012 1:39 pm Post subject: |
i am ALL OVER a serge VCS kit!!!! woot!  |
zanadar Common Wiggler
 Posts: 111 Location: San Francisco, CA
Posted: Mon Mar 26, 2012 1:01 pm Post subject: |
| Ooh! |
richard bananaphile
    Posts: 6260 Location: Berlin
Monobass thonk.co.uk
   Posts: 6523 Location: Brighton, UK
otherunicorn Santa
Posted: Sun Apr 01, 2012 3:48 am Post subject: |
| pulse_divider wrote: | | If that's the same CGS ASR that I have from Metalbox in frac format, it droops like a motherfucker and is useless for pitch |
Did you bother to contact Metalbox about it? You certainly didn't contact me.
It is a circuit that depends very much on the parts used. There is one type of caps that are guaranteed to fail. Personally, I have built a dozen of the things, and they ALL worked fine within reasonable limits. If you are expecting it to hold voltages for several minutes, you are dreaming. That is not it's purpose. None the less, I have had respected DIYers claiming their builds were as stable as the MOTM Sample and Hold. I've had the very occasional person who can't get it right make a lot of complaints to the public - but again not to me. You'd think that I would be the first person they asked.
I have sold hundreds of the thing, and there are only a handful of people who have complained. Each time dozens of others jumped to the design's defense, so I guess there must be other people who have successfully built them. As for the few failures I know about, only one contacted me about it, and it was built using the capacitors I mentioned above, which is how I know about them.
I discontinued it a couple years ago because of the suggested new design that came up during one of the online discussions, but people kept demanding I release it again, so there you have it. Laurie's new release the CGS734 is the NEW design I intended to replace my old CGS34 with, and is based on the experiments of one of the members here Dr. Sketch-n-Etch. It is a new design using a new set of chips. It is no longer restricted by the inadequacies of the 4052 chip, instead using a chip that can work directly across the voltage range. As such, none of the compression/decompression is needed in the new design, and that alone halves any possible droop rate, and removes several sources for possible inaccuracy. More modern op-amps are also used, so you don't have differences between the individual 3140 causing offsets.
The old thread discussing the new design is here: http://www.muffwiggler.com/forum/viewtopic.php?t=12080&postdays=0&post order=asc&highlight=asr&start=0
I hope that clears it all up. _________________ You got that resistor in backwards...
Last edited by otherunicorn on Sun Apr 01, 2012 4:07 am; edited 4 times in total |
otherunicorn Santa
Posted: Sun Apr 01, 2012 3:51 am Post subject: |
| J wrote: | been looking at a few kits recently, and the VCS looks like the one to go for.
Yes. _________________ You got that resistor in backwards... |
J Veteran Wiggler
Posted: Sun Apr 01, 2012 6:06 am Post subject: |
| otherunicorn wrote: | | J wrote: | been looking at a few kits recently, and the VCS looks like the one to go for.
Yes. |
cool, thanks.
will be keeping my eye on the VCS becoming available  |
Mood Organ Wiggling with Experience
    Posts: 484 Location: Seattle
Posted: Tue May 08, 2012 6:46 pm Post subject: |
Yeah, that was a real kick in the balls when I got mine. Very disappointing. |
