patching a sequencer w/ Eardrill modules - VID added |
djangosfire dimensionally transcendental
   Posts: 2756 Location: Oregon, USA
Posted: Mon Mar 19, 2012 12:56 pm Post subject: patching a sequencer w/ Eardrill modules - VID added |
One of my favorite pastimes is patching up analog sequencers without using a dedicated sequencer module.
One method I've been using alot:
1- Eardrilll 077 Pendulum Ratchet = clock and resets
2- Eardrill Source Selector = 4x stages/steps of the sequencer
3- Buchla 255 = a tunable voltage source
Really works great - loads of variation is possible. But I've been thinking about alternate tunable voltage sources. Here are a few that come to mind:
Buchla 256e
Buchla 255
Verbos 254v
But what would be really cool IMO, is to use 100% Eardrill. So here's what I'm thinking:
3- Eardrill Attenuators = used to split a single voltage source into 4x tunable stages
So..... what to use as a single, stable voltage source using only Eardrill? I've never used a Pulse Balloon or S&H . . . could one of these work? Or . . . . ?
Solution found: Eardrill Slew ModuleModule
The patch is a quick demo to show it's possible to use an Eardrill "Slew" ModuleModule as a basic voltage source. This was done by patching the the Slew Out into it's In - then "jump-start" the feedback loop using an outside voltage (in this case, I used the Dlfo).
_________________ Electronic: http://soundcloud.com/djangosfire
Acoustic: www.adamscramstad.com
7thDanSound Off patching
  Posts: 1769 Location: AWOL
Posted: Mon Mar 19, 2012 1:45 pm Post subject: |
Probably not the Pulse Balloon as the CV would drop to 0 in a certain time, right? I may be mistaken.
Sample and hold should be cool though as you could feed it just about anything and change it whenever you feel like it.
A 266e could do such service too.
Or how about any of the touch plate input modules 222e/223e in polyphonic mode? Then you'd get easily changeable arpeggios. |
batchas Switched on Buchla
Posted: Mon Mar 19, 2012 1:51 pm Post subject: |
| Challenge! |
weinglas Super Deluxe Wiggler
   Posts: 2555 Location: Germany
amnesia Super Deluxe Wiggler
    Posts: 5459 Location: 37 47 S 144 58 E
cbm Eardrill
    Posts: 2035 Location: Alameda, California
Posted: Mon Mar 19, 2012 10:53 pm Post subject: |
Not so stealthy. There's been a fair amount of discussion here about them.
As far as a voltage source goes, I bet either the Pulse Balloons or the slew would be ok for this when set for maximum decay time, and hit regularly from the p/r. Personally, I'm waiting for the Morphun. _________________ Chris Muir
Personal -http://www.xfade.com
My Jobby -http://www.eardrill.com (Jobby = less than a job, more than a hobby) |
Posted: Tue Mar 20, 2012 1:00 am Post subject: |
| cbm wrote: |
As far as a voltage source goes, I bet either the Pulse Balloons or the slew would be ok for this when set for maximum decay time, and hit regularly from the p/r. |
Actually, the Slew works perfect as a stable voltage source . . . . just patch the "out" into the "in", then jump start the feedback loop (as shown in vid )
| cbm wrote: | | Personally, I'm waiting for the Morphun. |
Me too - Oh man, it's gonna be awesome!! _________________ Electronic: http://soundcloud.com/djangosfire
Acoustic: www.adamscramstad.com |
cbm Eardrill
Posted: Tue Mar 20, 2012 1:33 am Post subject: |
Cool.
The ModuleModule has a 10 volt regulator, so it would be quite easy to DIY a jack with 10 volt out. _________________ Chris Muir
