[BUILD] - CGS Euro Modules |
simfonik Wiggling with Experience
 Posts: 473 Location: Portland, OR
Posted: Sat Mar 24, 2012 7:49 pm Post subject: |
That looks amazing, Rico.  |
rico loverde Super Deluxe Wiggler
  Posts: 3516 Location: Portland, Oregon
Posted: Sat Mar 24, 2012 8:40 pm Post subject: |
Thanx guys! It wouldnt have happened if it wasnt for this amazing forum! _________________ works for Malekko Heavy Industry |
lessavyfav Veteran Wiggler
  Posts: 691 Location: Brooklyn, NY
Posted: Fri Apr 06, 2012 2:06 pm Post subject: |
Hello - can anyone explain which size LED's I should get to fit into the 3mm LED Lens I got. The BOM has 5mm LEDs, I had some of these at my space and they don't seem to fit. Should they, like, click in?
Thanks! |
negativspace Manhattan Analog
   Posts: 3750 Location: Manhattan, KS
clarke68 Making DIY modulars look cool since 2011
   Posts: 1083 Location: Bay Area, CA
Posted: Fri Apr 06, 2012 2:49 pm Post subject: |
| lessavyfav wrote: | | which size LED's I should get to fit into the 3mm LED Lens I got. |
3mm LED lenses are for T-1 size LEDs. T-1 is secret LED manufacturer talk for "3mm", but you won't find anything at mouser looking from 3mm LEDs. 5mm LEDs are called "T-3".
Assembly instructions on the LED lens data sheet are: "Insert lens through panel hole, and insert LED into lens." |
Posted: Fri Apr 06, 2012 3:20 pm Post subject: |
Great! T-1. Yeah that is the trick. I was searching 3mm and getting nothing...
Thanks everybody. Slow me keeping this thread alive! |
jbaken Common Wiggler
Posted: Wed Apr 11, 2012 10:14 pm Post subject: |
| So I finally finished the mini synth and it sounds great.. My one issue is with the vcas. When I plug my vco into into either of my vcas I get a bit of bleed through. I made sure the vca was outputting 0 dc and minimized cv bleed w the trims. I also gave every module it's own plug to the power supply so I'm stumped over this.. Any ideas would be great |
Posted: Wed Apr 11, 2012 10:48 pm Post subject: |
| jbaken wrote: | | So I finally finished the mini synth and it sounds great.. My one issue is with the vcas. When I plug my vco into into either of my vcas I get a bit of bleed through. I made sure the vca was outputting 0 dc and minimized cv bleed w the trims. I also gave every module it's own plug to the power supply so I'm stumped over this.. Any ideas would be great | i had this issue but it worked itself out when i redid the power on mine. there were a few issues i had so I'm not 100% sure the rewiring of the power is what solved it. i ended up getting a cps motm busboard and power each module off that. hopefully someone else will offer some better help _________________ works for Malekko Heavy Industry |
ringstone antipodean experimentalist
   Posts: 2693 Location: Trudging through the Capital Wasteland
Posted: Wed Apr 11, 2012 10:50 pm Post subject: |
I believe this can happen if the 3 BC548's are not well matched (think I saw a reference to this on the CGS mailing list). I have a bit of bleed on mine, but I didn't have a large stock to choose from. I will order up a bunch in the near future and do a better matching job...
Blair _________________ Ecclesiastical Scaffolding Facebook
Mindless Eye * Soundcloud
some noise |
Posted: Thu Apr 12, 2012 12:03 am Post subject: |
Hmm I guess I didn't match the 548s as close as the dual. I also don't recall having bleed on my test power supply. Feels like trannies or my mono rocket case are to blame.
Besides that, this thing is amazing. I gotta thank everyone here for posting their experiences/troubles w the build...It helped me a lot. |
regenbot Veteran Wiggler
  Posts: 536 Location: Finland
Posted: Sat Apr 14, 2012 3:40 pm Post subject: |
Question about the DUSG wiring. Is the VC IN pot just an attenuator. Can i put cv input to signal in of the pot and then out to F on the pcb? I thought could, but iam somewhat confused after lookin at the schematics and wiring documentation.
Another thing i notice that there are three different M marked inputs on the board. I'm assuming the trig out is on the two M's near the 5V6 diodes. What's that third M input for?
Cheers, Heikki _________________ sounds
drawings
free music |
Posted: Sat Apr 14, 2012 8:20 pm Post subject: |
| regenbot wrote: | Question about the DUSG wiring. Is the VC IN pot just an attenuator. Can i put cv input to signal in of the pot and then out to F on the pcb? I thought could, but iam somewhat confused after lookin at the schematics and wiring documentation.
Cheers, Heikki |
It's not "W" - which is just above one FC input? If so, it's the 0V power terminal.
some noise |
Posted: Sun Apr 15, 2012 1:55 am Post subject: |
| ringstone wrote: |
It is I now remember confusing it with an M earlier too, thanks for your help  _________________ sounds
drawings
free music |
Posted: Sun Apr 15, 2012 2:31 am Post subject: |
So can anyone tell if i can put the VC input as an passive attenuator? CV In > VC In pot > F on the pcb?
drawings
free music |
hv0190 Common Wiggler
  Posts: 187 Location: Munich
Posted: Sun Apr 15, 2012 2:36 am Post subject: |
Heikki, if I read the schematics of the DUSG right this wouldn't work as intended, as the CV In at the same time feeds the negative input of an op amp through a 470K resistor - the attenuator is designed to be a polarised attenuator - wiring it your way this wouldn't work I guess  _________________ If the journey is the reward I might as well sit down beside the road and have some beers right now. |
Posted: Sun Apr 15, 2012 2:52 am Post subject: |
Ok, i thought so too, but had to make sure before rewiring
| hv0190 wrote: | Heikki, if I read the schematics of the DUSG right this wouldn't work as intended, as the CV In at the same time feeds the negative input of an op amp through a 470K resistor - the attenuator is designed to be a polarised attenuator - wiring it your way this wouldn't work I guess  |
drawings
free music |
Emalot Common Wiggler
  Posts: 201 Location: Lyon---France
Posted: Sun Apr 15, 2012 3:45 am Post subject: |
Rico,
Can you tell us the list of modules in your case??
EDIT;I saw the list in the "gloat thread"  |
Posted: Mon Apr 16, 2012 2:36 pm Post subject: |
EDIT: I think i have wrong kind of power supply in my uzeus no ground
Ok got the quadslope all wired up now. It is working apart from one dead led.
There is one issue. The voltage it outputs is wobbly and shaky is it somekind of grounding issue?
I did put all the pot & jack grounds to onky one of the boards. Could that cause issues?
Please  _________________ sounds
drawings
free music
Monobass thonk.co.uk
   Posts: 6524 Location: Brighton, UK
Posted: Mon Apr 16, 2012 4:19 pm Post subject: |
Try Small Bear, I know he's out of the 50k Linear but I think he's got the rest in stock. (Incl. 25k.) If Banzai Music is easier for you since they're on your side of the Atlantic, they should have them as well. _________________ Analogue Haven ∙ CTRL ∙ EquinoxOZ ∙ EFN ∙ Foxtone Music ∙ PostModular ∙ Schneidersbüro |
