STG Time Modules
Goto page Previous  1, 2 [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> 5U Format Modules
Author STG Time Modules
Bryan B
Last Visit: 17 Jun 2013
PostPosted: Wed Apr 11, 2012 6:57 am    Post subject: Reply with quote Add User to Ignore List
This is a view from the back (wiring side, not pin side). The other pins (midi signal pins in the midi standard) do different things in DIN Sync based on the machine (reset, tap, continue).
You can wire up 1/4" plugs or jacks but make sure to also connect the ground to them or they won't carry a signal. If you do this, put a switch on the start/stop signal for a manual start/stop reset. If you put a NC push button on the clock signal it will pause when you push it.
It is important to note that while most Roland machines can handle the 10vPP of a modular into their DIN jack, the recommended voltages for the Time Suite are 0 to +5vDC.
doctorvague wrote:
I like hiding out at Muff's. Let's build a fort out of some chair cushions and a blanket.
JP wrote:
Hell I want to be able to turn my toaster on with a CV trigger.
Why Adapter
Tick Mark Legend
Last Visit: 18 Jun 2013
PostPosted: Wed Apr 11, 2012 10:36 am    Post subject: Reply with quote Add User to Ignore List
A very nice overview of DIN sync can be found on http://www.chd-el.cz/index.php?id=119. It's in Czech only (the rest of the site does have English available), but Google translate works fine.
All the diagrams are in English, though.
The STG system does not use the Continue or Reset pins, as only a couple of Roland units ever did.
Bryan B
PostPosted: Wed Apr 11, 2012 12:10 pm    Post subject: Reply with quote Add User to Ignore List
Correct. Thanks for adding that!
smith
Last Visit: 01 Dec 2012
PostPosted: Thu Apr 12, 2012 5:10 am    Post subject: Reply with quote Add User to Ignore List
This could be fixed by putting a diode in series with a small current limiting resistor on the input.
I am thinking about DIY my own 1/4" time buffer. Does anyone know what connectors erwill uses for the time buffer??
suitandtieguy
Hammond King
Last Visit: 19 Jun 2013
PostPosted: Thu Apr 12, 2012 5:53 am    Post subject: Reply with quote Add User to Ignore List
i'm sorry it took me so long to respond here. quite frankly i've been too busy soldering and answering email when i have a chance to get to the pooter.
this isn't going to be coherent, i don't have time to write an essay so i'm just going to blurt a bunch of stuff out.
a) i'm sorry i don't make it more clear you don't need the time buffalo to use my sequencers. one of the three jacks on the front panel is labelled "SHIFT" so i figured that would be obvious enough, and it's explained in the copy. the sync aspect of this system _is_ what sets it apart, and i stand by that statement.
b) the Time Buffer was only supposed to be the first entry point for sync signals. we intended all along to have a main master clock module called the Time Rotor, which would be a sync hub for MIDI, DIN, and tape/FSK sync. obviously this hasn't happened yet because i'm undercapitalised, but it's still going to happen. the Time Buffer isn't going away though i promise.
c) the choice of DIN sync was twofold: sync 24 is just better. period. it's better than MIDI sync. also at the time of this system's conception (2007) it really did seem like the most common modular systems for dance musicians was Moog format, so it didn't seem like using DIN sync would be a problem.
there are many modern devices that have DIN sync. the Novation Drumstation and Bassstation, the MAM SQ16, the Mobius/Revolution/777, the Kenton interfaces, the x0xb0x, the Cirklon, the Jomox stuff, etc. it's not a dead sync format. those Innerclock guys for example are really pushing the concept in directions Ikutaro might never have imagined.
later this year there will be changes. i only have 3 panels left for the Time Buffer the way it is now and i'm not reordering them.
http://suitandtieguy.com
http://stgsoundlabs.com
kindredlost
PostPosted: Fri Apr 13, 2012 7:34 pm    Post subject: Reply with quote Add User to Ignore List
This is great news. I hope to see the Time Rotor happen too. I love the small set of modules I have but am always wanting more "In The Modular" to control this suite.
OpenTape
noises4sale
soundcloud
videos
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> 5U Format Modules All times are GMT - 5 Hours
Page 2 of 2
