Vocoders and compressors |
chamomileshark Super Deluxe Wiggler
    Posts: 1418 Location: UK
Posted: Sun Mar 25, 2012 8:12 am Post subject: Vocoders and compressors |
hi, I've had some problems with using vocoders in the past, both with speech and singing - I've seen the suggestion to use a compressor.
I got a cheap presonus one (thinking it is also useful when I do the traditional birthday and valentines day songs for the wife). I then read that will need a pre-mic if used with a mic - so I got the Pretube.
ok - just checking now - I have a Roland SVC 350 - I assume I now use the "guitar" input now instead of the Mic input on the vocoder when using the pre-mic and compressor? _________________ a bunch of stuff
http://www.soundclick.com/markgriffiths |
ndkent Super Deluxe Wiggler
Posted: Sun Mar 25, 2012 9:26 am Post subject: |
Well the overall dilemma is that real analog vocoders are pretty imperfect from the get go.
So the issue as I see it is how far are you from an optimum signal and is your vocoder capable of getting you what you want out of it.
You may have a weak signal issue which the mic pre and compressr would take care of. You may have a carrier signal that just doesn't have that many frequencies to vocode. Your vocoder might just not be accurate an effect enough for you.
After all many of the classic examples of vocoding are the (still) high end Sennheiser or aren't actually out of a vocoder. It's not the definitive answer but you may want to look around youtube or forums for demos that sound better than what you are getting. Also make note of what kind of signal is being vocoded. If you send the vocoder a fairly narrow frequency range carrier you may be modulating parts of the spectrum with little or nothing there in the carrier. The reverse of course holds true too
The compressor idea, which is a sound idea, is to compress your modulator to get more amplitude on the bands overall. Some people experiment further with a bit of distortion and even frequency shift. the idea there is to get some other bands moving that aren't as much yet use the existing signal to do that
Okay, I'm sure the manual is online somewhere, firstly I think you should check if it's a guitar in or a line in (which they might call instrument or something) because they are not the same though some units cover a wider range of inputs. What's coming out of your compressor is going to be line level. There has to be an unbalanced line in on the vocoder. _________________ http://nickkent.net
http://twitter.com/ndkent
http://www.myspace.com/ndkent
http://www.youtube.com/user/itisnick
http://soundcloud.com/nicholas-d-kent/ |
Posted: Sun Mar 25, 2012 10:44 am Post subject: |
ok, this may help what the nature of the guitar input is..
it says "100 k ohms - it also has an input level knob and indicator lights - I guess I can set it at a very low level on the vocoder and just turn it up. If I get the red light immediately I'll just ditch the idea. _________________ a bunch of stuff
Babaluma Manual Gain Rider
     Posts: 6758 Location: Milan
Posted: Sun Mar 25, 2012 11:12 am Post subject: |
yeah, i think the idea is to put the compressor just before the vocoder's "modulator" input, which will even out the vocal sound (if that's what you are using as the modulator), and increase intelligibility. _________________ Hermetech Mastering | Discogs | SoundCloud | Bandcamp | Facebook | Pathmusick |
Posted: Sun Mar 25, 2012 12:06 pm Post subject: |
yes, sounds fine, make sure you have an unbalanced out from the comp
and yes, Babaluma, that's the idea. More amplitude overall gets through making things more clear when vocoded because you are amplitude following the modulator.
If intelligibility is concerned you also have issues of how many bands and the voicced/unvoiced circuit, which you don't have control of unless you buy or build something else. Then next up is that the carrier actually contains significant material in the same frequency ranges as the modulator, which is something the average user can do. Next up, if not of equal importance is making sure the modulator is maximized without being too far messed up.. _________________ http://nickkent.net
home_listening Wiggling with Experience
 Posts: 383 Location: Melbourne.
Posted: Fri Mar 30, 2012 10:30 am Post subject: |
I also find that a strict high and low pass filter before the compressor before the vocoder helps focus the whole thing quite a bit too. A very quiet slap back echo is also much better than using reverb. _________________
| darenager wrote: | | Try soldering on a flux capacitor and take the tempo to 88 bpm |
drewtoothpaste married to the sea
    Posts: 2421 Location: Columbus, OH
Posted: Fri Mar 30, 2012 10:41 am Post subject: |
I get better intelligibility by using a dynamic mic straight into the vocoder and then compressing the output, rather than compressing it on the way in. You'd think that compressing the input would sound better, but I find that the vocoder tends to respond better to a more dynamic signal, and then you can control the dynamics on the way out to fit it into a mix.
Also worth noting that the new EHX vocoders (Voice Box / V256) sound better than the vintage ones. More bands and better controls. _________________ Do you wear nail polish?! Super Black Lacquers: Holographic, Glitter & Solid Nail Polish |
fiero Common Wiggler
  Posts: 144 Location: NEW YORK, NY
Posted: Tue Apr 03, 2012 7:09 pm Post subject: |
| is good to use distortion on the synth or guitar, i like the vokator as well, you have to articulate a lot in order to make it understandable. |
Posted: Wed Apr 04, 2012 8:38 am Post subject: |
thanks for your input guys.
I have in the past tried software compressors after the vocoder. I've also used Vokator, Electrix Warp Factory, Korg DVP-1 as well as the Roland SVC.
I did a test comparing the Warp Factory & Roland and the Roland was far clearer.
I suspect also because I was new to the whole idea, some of the intelligibilty issues where down to the carrier signal (both timbre and fiddling about with pitch mid word) and in the mixing with the synth elements.
I'm intending to re mix my previous attempts so it will be interesting to see how much I can improve them. _________________ a bunch of stuff
skkatter Common Wiggler
    Posts: 187 Location: Berlin via Dublin
Posted: Tue Apr 10, 2012 10:46 am Post subject: |
The Roland SVC350 is an amazing vocoder, it should be pretty easy to get intelligible sounds out of it. Maybe you should post up some examples you've recorded and people could give suggestions.
I'd definitely pick the 350 over any of those EHX ones. Check out some Midnight Star for some classic 80s vocoder action: http://youtu.be/Lz7nSkFhBP0 |
Posted: Wed Apr 11, 2012 7:53 pm Post subject: |
eq is important too 300 hz humans perceive the spech at 3k consonants , and at 5k makes it little clear, so play with those settings it might help as well.  |
