Best/any analog multitimbral gear that follows General midi?
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear
Author Best/any analog multitimbral gear that follows General midi?
Bath House
Last Visit: 23 May 2013
PostPosted: Fri May 25, 2012 12:35 pm    Post subject: Best/any analog multitimbral gear that follows General midi? Reply with quote Add User to Ignore List
I've been having fun with my MC-50 sequencer but it's got me thinking - was anything analog, multitimbral, and GM spec ever made?
Last Visit: 24 May 2013
PostPosted: Fri May 25, 2012 12:39 pm    Post subject: Reply with quote Add User to Ignore List
no -
edit: as far as i know general midi is rompler only for older roland stuff (though it still exists)
there are some multi timbral analogs but generally they split up as a couple monosynths or they're polysynths that allow you do separate the voices in some way but only a handful at most and not many voices.
general midi spec on an analog synth would be kind of a wasted implementation.
LABEL TWITTER FACEBOOOK SAMPLE LIBRARY
Think for a moment about what an amazingly obscure piece of commonality that is.
Bath House
PostPosted: Fri May 25, 2012 1:55 pm    Post subject: Reply with quote Add User to Ignore List
I guess that makes sense - opening up the category, then, to "are there multitimbral analogs with MIDI?"
Hanz
Analogue Avenger
PostPosted: Fri May 25, 2012 1:58 pm    Post subject: Reply with quote Add User to Ignore List
General Midi compliant analogues (hence: 24 voices, 16 part multitimbral, drum kit on channel 10, full midi) you will not find.
I think the closest ever realized was probably some crazy Casio, a bit in the vein of the HT-6000, which appears like a massively underrated synth btw.
Analog multitimbral synths (which implies MIDI, doesn't it?) are not too hard to find, really. If I recall corectly... from the top of my head (and a bit of Google to verify)
Modern analogs;
SE Omega 8 / Code
Alesis Andromeda
Dave Smith Instruments Tetra
Vintage analogs;
Oberheim Expander / Matrix 12
Sequential Six-track / Multitrack
Cheetah MS-6 (Oberheim Matrix 1000 lookalike)
If you decide to include bi-timbral synths, the list is even longer, as a number of synths have this using 'split / layer' functionality.
For instance, Roland JX-10 / MKS-70, Roland Jupiter-6 / MKS-80, Akai AX-60, Chroma Polaris, Crumar Bit-One, Siel DK-80, Prophet-08 etc.
...this music, it flows through me, like a kind of slippery jelly from heaven. I am merely a conduit, a kind of big hairy tool. I am just a plastic funnel connected to a Moog...
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear All times are GMT - 5 Hours
