A160 rythm issues |
Alwaysnew Wiggling with Experience
 Posts: 252 Location: Boston
Posted: Thu Jul 05, 2012 11:09 am Post subject: A160 rythm issues |
The Doepfer A160 divides the incoming signal but the divisions aren't firing at the same time, I know this is the way it's supposed to be but it's kind of frustrating.
For the 4ms divider there is a "spread mode" on the breakout panel that makes it's divisions fire at the same time so my question is: is there a way to make the A160 fire at the same time too?
Thanks! |
exper Super Deluxe Wiggler
  Posts: 4247 Location: Southern NJ
Posted: Thu Jul 05, 2012 11:17 am Post subject: |
In short. No. You wound need to use a trigger inverter on each output. _________________
| dodecabilly wrote: | | When I close my eyes, I see knobs and patch points. I'm thinking in patches. Connecting thoughts with mental cables. I'm going insane. Help me and warn others. |
My current system:
http://www.modulargrid.net/e/racks/view/5549 |
Posted: Thu Jul 05, 2012 11:41 am Post subject: |
| Ah, yeah that's right. Well, I'll try the 4ms way instead! Thanks! |
Count Edlington Ultra Wiggler
 Posts: 864 Location: France
Posted: Thu Jul 05, 2012 1:40 pm Post subject: |
| Can someone explain this problem a bit more? I'm in the process of buying a clock divider and would like to avoid any unpleasant surprises. For the record I'm probably going to get the 4ms..... |
Posted: Thu Jul 05, 2012 2:03 pm Post subject: |
I'll give it a shot. The problem is in the way that the modules count. With the A-160, It keeps adding from the base. There's no way around it without inverting each output so that they start high after a reset.
The 4ms RCD expander has a switch to do it both ways. (the arrow switch, not the spread...)
Hopefully any other companies that are designing modules with clock division (cough, danjel?, cough) will do it the 4ms way instead of the Doepfer way. I believe the Pittsburgh Timetable counts on the one also. I can't think of any other clock dividers other than those. With one, wonderful 14hp clocking mecca on the way hopefully.  _________________
My current system:
XidZeta custom text avatar
Posted: Thu Jul 05, 2012 2:12 pm Post subject: |
| dang, i have been wondering about that for a while... |
Posted: Thu Jul 05, 2012 2:18 pm Post subject: |
| I decided to get a 4ms scm with breakout and I hope it will help solve this problem for me. I know it's a multiplier and not a divider but my plan is to send slow triggers to it and make my rythms that way. Hope it works! Then I'll sell my a160! |
Posted: Thu Jul 05, 2012 2:24 pm Post subject: |
just remember, the scm doesn't reset... _________________
My current system:
Posted: Thu Jul 05, 2012 2:31 pm Post subject: |
Hm
Not even with breakout?
What does "resync" do? |
Posted: Thu Jul 05, 2012 3:19 pm Post subject: |
| exper wrote: | I'll give it a shot. The problem is in the way that the modules count. With the A-160, It keeps adding from the base. There's no way around it without inverting each output so that they start high after a reset.
Hopefully any other companies that are designing modules with clock division (cough, danjel?, cough) will do it the 4ms way instead of the Doepfer way. I believe the Pittsburgh Timetable counts on the one also. I can't think of any other clock dividers other than those. With one, wonderful 14hp clocking mecca on the way hopefully.  |
Ok so if I understand you correctly does that mean the Doepfer clock behaves like this?:
Clock signal---> 1 1 1 1 1 1 1 1 1 1 1 1
Divide by 2 ---> 0 1 0 1 0 1 0 1 0 1 0 1
Divide by 4 ---> 0 0 0 1 0 0 0 1 0 0 0 1
And the 4ms is more like this?:
Divide by 2 ---> 1 0 1 0 1 0 1 0 1 0 1 0
Divide by 4 ---> 1 0 0 0 1 0 0 0 1 0 0 0
Is that right or am I off? To me the 2nd one is how I was expecting a clock divider to work but I can see why the Doepfer one works the way it does. By the way i don't want the expander so does this mean I need to get it for normal clocks? |
fireclown Veteran Wiggler
Posted: Thu Jul 05, 2012 3:21 pm Post subject: |
If you abandon the original clock signal as a source for anything but the 160 you should be OK, just use the divisions for various sequencers etc. It works some nice tricks on the 150 VC Switch and so forth.
very worth having in a Doepfer setup.
163 is the real cure to the worlds pain. _________________ North American Modular/Boy Love Association |
Posted: Thu Jul 05, 2012 3:24 pm Post subject: |
| Count Edlington wrote: | | exper wrote: | I'll give it a shot. The problem is in the way that the modules count. With the A-160, It keeps adding from the base. There's no way around it without inverting each output so that they start high after a reset.
You got it. I'm there's uses for the way the doepfer works, but It irritated me when I had one. As for the expander, no, you don't need it to set it up properly. There's jumpers in place if there isn't a breakout, and the way you position the jumpers dtermines its behavior... _________________
My current system:
Posted: Thu Jul 05, 2012 3:30 pm Post subject: |
Cool, yeah I think both could be useful, having a switch could be fun to jam out on ......maybe I should get the breakout so I can have access to both, damn GAS has got me again! Thanks for clarifying that exper I hate when you buy a module expecting it to behave a certain way and it doesn't. |
Posted: Thu Jul 05, 2012 3:36 pm Post subject: |
I think the breakout is pretty necessary to be honest. I often go from long noodles with slow clock divisions, and then back to fast polyrhythmic patterns utilizing the odd divisions and reset. I'd hate to have to pull the module out every time I needed different divisions. Plus, the gate/trigger mode is very useful as well. I seriously can't wait to use a division gate for my incoming Echophon. I figure, sending the gate to the wet mix and freeze jack will create Ableton style beat repeat style stutters... I'm gonna get my euro glitchhop on! _________________
My current system:
Posted: Thu Jul 05, 2012 3:50 pm Post subject: |
| exper wrote: | | I think the breakout is pretty necessary to be honest. I often go from long noodles with slow clock divisions, and then back to fast polyrhythmic patterns utilizing the odd divisions and reset. I'd hate to have to pull the module out every time I needed different divisions. Plus, the gate/trigger mode is very useful as well. I seriously can't wait to use a division gate for my incoming Echophon. I figure, sending the gate to the wet mix and freeze jack will create Ableton style beat repeat style stutters... I'm gonna get my euro glitchhop on! |
All this sounds great! I really want to use it as a kind of event generator as well, kind of like how you described with the echophone to change CV parameters on certain modules in time. I plan on pairing it with the 166 logic module for even more rhythmic madness. |
Posted: Thu Jul 05, 2012 4:22 pm Post subject: |
Have you looked at the Plog? 2 Logic channels and 2 Flipflops. Incredible for rhytmic variation...
just saying...  _________________
My current system:
Posted: Thu Jul 05, 2012 4:45 pm Post subject: |
HOLY SHIT! just checking it out now, looks insane, way more than the Doepfer but also far deeper........Not exactly sure how the flip flop part works though whats flipping and whats flopping and whats the data jack for? |
Posted: Thu Jul 05, 2012 5:02 pm Post subject: |
Well, Flipflops can be consider toggled switches in the first section and 1 bit memory in the second. They can also be simple clock dividers (/2 and /4)
So, in the first section, a trigger flips it on, and then a second trigger flips it off. Very simple. The second one, with the data input, does similar, except that when there is data, it follows that. In that case, it sort of quantizes the data input to clocks. Check the manual for a better description as I'm probably not describing it all completely.
All of that is shorthand for "Its amazing for sequencing and rhythmic variation." _________________
My current system:
NV Super Deluxe Wiggler
Posted: Thu Jul 05, 2012 6:59 pm Post subject: |
That's not entirely correct. Your first example is the RCD on Up Beat counting, and your second is the RCD on Down Beat counting - both jumper selectable, or via a switch with the RCD Expander. Neither of those illustrate the sort of odd way the A-160 works.
It's worth mentioning that the Doepfer holds a gate rather than simply outputting a pulse. This gate signal transitions from high to low on the divisions. Also, the Doepfer doesn't put out divisions quite like you would expect. Because of that, the A-160 works like this:
In - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
/2 - 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0
/4 - 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0
/8 - 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0
/16 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0
/32 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0
/64 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
...with the rising edge occurring at the beginning of each high (1s) phase, or the underlined 1s on my hackjob text graph. This means that if you're looking for pulses with the /4 output you'll only get a rising edge trigger equivalent on the 2nd, 6th, 10th, and so on clocks.
The Doepfer approach can be great for some uses, not so much for others. For example, if you want a pulse on the ANDs in a typical 4/4 bar you're going to need to logically OR the /4, /8, /16, and /32 outputs - that's a small mess of patching for a rather basic division. With the RCD however, just select Up Beat counting and take the /2 output - bingo, AND pulses. However, let's say you want pulses on 2 and 6 of an 8-count measure - the Doepfer can do that by default out of /4, but with the RCD you'll need to run /2 and /4 into XOR logic to get those same counts.
Both up and own beat dividing have their uses. Likewise having pulses and having gates both have their uses as well. That being said, having the Up and Down beat options of the RCD expander with typical pulses rather than gates is probably the ideal solution for most people. |
Posted: Thu Jul 05, 2012 7:15 pm Post subject: |
Ah ok so the 4ms will output a pulse the size of the clock value and the Doepfer will put out a gate that is the size of the division value? I'm looking for one that puts out long gates so maybe doepfer's the one for me.... Only thing is I would like rotation and odd divisions so now I'm guessing I need both
Hmmmmm don't think I have the budget for both...... shit.
and exper that intellijel plog is very very cool, crazy combinations to be had, I'm checking out the manual this minute! |
Posted: Thu Jul 05, 2012 7:23 pm Post subject: |
| Count Edlington wrote: | | Ah ok so the 4ms will output a pulse the size of the clock value and the Doepfer will put out a gate that is the size of the division value? I'm looking for one that puts out long gates so maybe doepfer's the one for me.... |
Yes to the first question, "er, wait..." to the second half. With the RCD Expander, you can select Gate or Trigger mode. In trigger mode, the RCD just spits out pulses. In Gate mode, it holds a gate like the Doepfer. This also works in conjunction with Up or Down beat counting. There's a diagram explaining much of this in the RCD Manual - page 4 for Up/Down Beat counting, and page 7 for Gate/Trig mode. |
Posted: Thu Jul 05, 2012 7:29 pm Post subject: |
The RCD can do gates as well. Its really the hands down choice at this point. For me at least, until this:
Though I may still keep the RCD around for the Gates mode. _________________
My current system:
Posted: Thu Jul 05, 2012 7:36 pm Post subject: |
| NV wrote: | | Count Edlington wrote: | | Ah ok so the 4ms will output a pulse the size of the clock value and the Doepfer will put out a gate that is the size of the division value? I'm looking for one that puts out long gates so maybe doepfer's the one for me.... |
Ok well thats good news RCD it is then. That Pulse Tornado is a heavy piece of gear too! I can't wait to see someone rocking an all Intellijel modular, that would be something! |
Posted: Thu Jul 05, 2012 7:43 pm Post subject: |
Intellijel is definitely almost there. For me, I'd need to see a random cv generator ala Buchla 266 or Wogglebug, but, you know, different. Also, I couldn't imagine using any system without LPGs so, they'd need to make that as well. But, with their new modules, I could totally see using only their modules and being very, very happy. Same with MN. _________________
My current system:
chvad Super Deluxe Wiggler
 Posts: 1589 Location: Brooklyn, NY
Paranormal Patroler Super Deluxe Wiggler
 Posts: 3115 Location: (geography) a point in physical space
Posted: Sun Jul 15, 2012 10:15 am Post subject: |
So I guess that having the a-160, a-161, Plog, a-166 logic and planning on buying the RCD and SCM makes me a pulse/trigger freak?
I thought dedicating 3U for weird sequencing was standard procedure  _________________ • • • • • • • • • • • • • |
