Happy Nerding Super Sawtor module |
whitewulfe Chaos beckons, I heed the call
  Posts: 1672 Location: C-YXD (Edmonton, Canada)
Posted: Thu Jul 19, 2012 10:26 pm Post subject: Re: I am still lusting |
| wsy wrote: | No news yet from Igorr. I hope he finds his new op amp supplier soon!
- Bill |
Not to mention word on a revised, slimmer (preferably under 3" deep!) module ^_^ |
igorrr Learning to Wiggle
   Posts: 41 Location: Ukraine
Posted: Fri Jul 20, 2012 2:12 am Post subject: |
Hello to everyone!
Tomorrow I hope to receive the first assembled boards for 3 units in SMT format.
The depth is limited only by the Switchraft 112A jacks, so every cabinet will be able to accommodate the new revision units.
Unfortunately I was delayed for two weeks by fake TL074 quad opams. Some "clever" people succeeded to make fakes of the already cheapest opam. These fakes work, but much slower than they should, you can’t even make a buffer with them – the signal fronts will be eaten.
I will contact all the interested fellows when the units will be prepared. _________________ http://www.happynerding.com/category/super-sawtor/ |
wsy Veteran Wiggler
 Posts: 671 Location: near Boston Massachusetts USA
Posted: Mon Jul 23, 2012 7:40 pm Post subject: PMed and paypalled! |
| igorrr wrote: | Hello to everyone!
I will contact all the interested fellows when the units will be prepared. |
One unit PMed !
- Bill _________________ "Life is short. But we can always buy longer patchcords." - Savage |
Dave Peck Wiggling with Experience
  Posts: 337 Location: SF bay area
Posted: Thu Jul 26, 2012 12:59 pm Post subject: |
I just found another cool trick with the Super Sawtor module and wanted to share it:
Using a Dotcom Q106 oscillator, which has simultaneous UP saw and DOWN saw outputs (or if your osc only has one of these, you can use a multiple and an inverter to create the missing one), patch the UP saw to the top half of the module and the DOWN saw to the bottom half and set the spread controls on the two sections to just slightly different settings. Try setting the spread control on the top section to "3" and the bottom section to "3.01". Now send these to separate VCAs to keep the signals separate and give them a slight stereo spread at the synth output or at the mixer. It's a massive detuned saw sound with an added hollow flange effect in stereo as the slightly different settings cause the positive & negative elements within the supersaws to partially cancel. Nice! |
JohnLRice Howl at the Moon
    Posts: 7716 Location: Western WA USA
Posted: Thu Jul 26, 2012 8:19 pm Post subject: |
| Dave Peck wrote: | I just found another cool trick with the Super Sawtor module and wanted to share it:
Using a Dotcom Q106 oscillator, which has simultaneous UP saw and DOWN saw outputs (or if your osc only has one of these, you can use a multiple and an inverter to create the missing one), patch the UP saw to the top half of the module and the DOWN saw to the bottom half and set the spread controls on the two sections to just slightly different settings. Try setting the spread control on the top section to "3" and the bottom section to "3.01". Now send these to separate VCAs to keep the signals separate and give them a slight stereo spread at the synth output or at the mixer. It's a massive detuned saw sound with an added hollow flange effect in stereo as the slightly different settings cause the positive & negative elements within the supersaws to partially cancel. Nice! | Cool Dave! I'll have to give it a try!  _________________ | My Facebook | My Soundcloud |My Vimeo | My YouTube | My GrooveShark | |
exwel Common Wiggler
 Posts: 142 Location: Near Amsterdam
Posted: Fri Jul 27, 2012 10:49 am Post subject: |
| Will try that also thanx! |
VinceL Veteran Wiggler
  Posts: 624 Location: North Carolina, US
Posted: Mon Jul 30, 2012 12:44 pm Post subject: |
Received an e-mail from Igor that the SMT versions of the Super Sawtor are in stock. Placed my order this morning.
Now all of you with modules from the original batch can go around talking about how you have the vintage Super Sawtors with a sound that the newer SMT version just can't replicate.  _________________ VinceL
FS: TASCAM 688 MIDI Studio, Korg A4 Bass Processor |
Posted: Mon Jul 30, 2012 1:13 pm Post subject: |
| VinceL wrote: | Received an e-mail from Igor that the SMT versions of the Super Sawtor are in stock. Placed my order this morning.
Now all of you with modules from the original batch can go around talking about how you have the vintage Super Sawtors with a sound that the newer SMT version just can't replicate.  |
Way ahead of you, Vince  |
wsy Veteran Wiggler
Posted: Mon Jul 30, 2012 6:18 pm Post subject: |
| Dave Peck wrote: | | VinceL wrote: | Received an e-mail from Igor that the SMT versions of the Super Sawtor are in stock. Placed my order this morning.
Way ahead of YOU, Dave.  _________________ "Life is short. But we can always buy longer patchcords." - Savage |
wsy Veteran Wiggler
Posted: Fri Aug 03, 2012 10:55 am Post subject: I got mine yesterday!!! |
I got my V2 Super Sawtor in the mail yesterday (but couldn't actually power it up till
today).
Sounds: GREAT! The closest thing to the Awesome Button yet. It's a very different
sound from either a wavefolder or a phaser (my other two favorite anti-filters).
The new design is REALLY shallow - most of the circuitry fits between the sidebends
of an MU-type front panel. The jacks are free-floating (short pigtails to the PCBs);
mine has the PCBs jumpered together with tie wires so it only uses up one Dotcom
power connector (I'm not sure if this one was made up this way special for me by
Igor or whether it's now Igor's standard).
And it sounds WONDERFUL. The new SMT units go from absolutely no
effect on the sound, up through Roland SuperSaw, to crazy detuned noise.
I'll try to get a Youtube video up. It's great.
Thanks, Igor!
bkbirge Ultra Wiggler
  Posts: 970 Location: Houston, TX
Posted: Mon Aug 06, 2012 5:35 pm Post subject: |
Where da euro at? _________________ "The person who says it cannot be done should not
interrupt the person doing it." ~ Chinese Proverb |
russma Super Deluxe Wiggler
    Posts: 1430 Location: Duvall, WA, USA
Posted: Thu Aug 16, 2012 11:44 am Post subject: |
I received my Super Sawtor module the other day and played with it today.
Outstanding.
Great price, fast shipping, excellent communication. Folks, this one's a no-brainer. Highly recommended.
Great work, Igor!
 _________________ Russ M. |
darwingrosse Wiggling with Experience
   Posts: 333 Location: Boulder, CO
Posted: Thu Aug 16, 2012 5:56 pm Post subject: |
| russma wrote: | | Folks, this one's a no-brainer. Highly recommended. |
My friend Andrew was in CO last week, and he brought his Super Sawtor along. The sound blew me away. Just amazing, and I'd agree it is a no-brainer. _________________ [ddg]
Modular stuff and more at:
http://darwingrosse.blogspot.com/ |
Posted: Thu Aug 16, 2012 8:28 pm Post subject: |
| JohnLRice wrote: | Good deal Russ! Is yours the newer surface mount one? |
Yes. _________________ Russ M. |
wintchil Wiggler Invader
  Posts: 535 Location: Nashville, TN
Posted: Thu Aug 16, 2012 10:29 pm Post subject: |
Is euro on it's way?  |
Posted: Fri Aug 17, 2012 1:42 am Post subject: |
The Euro version is in development. The board is 90% routed. It takes considerable amount of time for me to do SMT routing as no auto route function and 6 layer pcb are used.
The target date of Euro version release is late September. _________________ http://www.happynerding.com/category/super-sawtor/ |
wsy Veteran Wiggler
Posted: Fri Aug 17, 2012 4:42 am Post subject: |
| igorrr wrote: | The Euro version is in development. The board is 90% routed. It takes considerable amount of time for me to do SMT routing as no auto route function and 6 layer pcb are used.
The target date of Euro version release is late September. |
I'm surprised you can't just put one of the MU-sized boards edge-in.
Your board is *tiny*... and beautiful.
Tronketz exploring harmonically rich sine waves
Posted: Fri Aug 17, 2012 11:29 pm Post subject: |
| numan7 wrote: | | ping panic wrote: | | Wow I need one, I'm the supersaw (and trance) fanboy #1 |
i thought that Tronketz was the #1 supersaw fanboi!  |
Not fanboi, guru.
And here's something you can try with sawtor, try setting up a dry/wet patch with the sawtor so that you can have the dry single saw playing louder than the ensemble that sawtor creates. _________________ www.elanhickler.com |
Posted: Sat Aug 18, 2012 9:41 am Post subject: |
To add to the above patch:
Use keytracking so that low notes have less sawtor signal and high notes have more sawtor. _________________ www.elanhickler.com |
