BUILD THREAD: MISS 10 VCO 2.0
Author BUILD THREAD: MISS 10 VCO 2.0
E.A.S.
Last Visit: 06 Jun 2013
PostPosted: Fri Jul 20, 2012 6:34 pm    Post subject: BUILD THREAD: MISS 10 VCO 2.0 Reply with quote Add User to Ignore List
The VCO pcbs are in and will be shipping very soon!
This VCO is different enough to justify starting a separate build thread for this version.
MISS 10 vco 2.0 w/panel by itsfatmike, on Flickr
MISS 10 VCO 2.0 by itsfatmike, on Flickr
E.A.S. 'Miss10' series PCB threads---ESP-mindreader, LFO, NOISE, S/H, HADSR ,VCO, and VCF/VCA
E.A.S.
PostPosted: Fri Jul 20, 2012 6:35 pm    Post subject: schematic. Reply with quote Add User to Ignore List
Schematic.
MISS TEN VCO rev 2.0 by itsfatmike, on Flickr
PW MIXER by itsfatmike, on Flickr
Wiring diagram.
IMG_7239 by itsfatmike, on Flickr
Notes:
An Error in my silkscreen! ALL transistors need to be installed "backwards" with regard to the silkscreen.
Vref output is a buffered voltage reference I included for connection to the Hz/v input. you can jumper it directly (as seen in the photograph and schematic) if you don't plan on using the Hz/v input. Or you can "normalize" the Vref to the "switching lug" on the Hz/v input. The Hz/v is not labeled on the wiring diagram, but it is on the pcb. Its between the octave switch and the wave outputs.
The PWM jack would probably be best served with attenuator pot, wired like the pitch cv inputs.
The square output resistors mounted to the jack are 22k (from the pcb to the tip) and 2.7k (from the tip to ground)
E.A.S.
PostPosted: Fri Jul 20, 2012 6:35 pm    Post subject: Bill of Materials. Reply with quote Add User to Ignore List
Bill of Materials.
Mouser part #'s included.
pre55ure
Last Visit: 20 Jun 2013
PostPosted: Fri Jul 20, 2012 9:56 pm    Post subject: Reply with quote Add User to Ignore List
I want one!
Is it too late to order?
ringstone
antipodean experimentalist
PostPosted: Sat Jul 21, 2012 1:56 am    Post subject: Reply with quote Add User to Ignore List
Hmmm... interesting! Good to see some extra room for the precision resistors. Are the two holes underneath Q6 to enable the use of a 2SC1583 if desired, or am I mistaken?
Also, I assume that the extra opamp on the ramp waveform is to invert it so that it ends up a saw? I still don't understand how it ends up a saw on the MS-20... does one of the filters have an inverted output and the other not?
Tossing up whether to get some of these as well...
Blair
Ecclesiastical Scaffolding Facebook
Mindless Eye * Soundcloud
some noise
steffensen
Last Visit: 19 Jun 2013
PostPosted: Sat Jul 28, 2012 1:19 pm    Post subject: Reply with quote Add User to Ignore List
There's just one thing from the BOM that im not sure on what to get. Perhaps someone could help me locate the right part? Its the SW1 - SCALE - SP4T
Not sure what to look for, never used a switch like this before. Is it a switch trimmer, controlled by VR11?
Edit: Nevermind, found the answer in another thread. meh
Are the shipping closing in btw? smile
E.A.S.
PostPosted: Sat Jul 28, 2012 4:09 pm    Post subject: Reply with quote Add User to Ignore List
Actually I've already started shipping some. For people waiting on VCFs Im shipping the boards out in about a week, hopefully sooner.
Re: the c1583, There aren't provisions for the 5 pin SIP package but with a little persuasion, it could be made to work. between the two expo transistors, I put pads for a thru hole tempco as well as the SMT tempco that mouser and places like that have. (see BOM for part #)
-Mike
steffensen
PostPosted: Sat Jul 28, 2012 4:28 pm    Post subject: Reply with quote Add User to Ignore List
-Mike
Great! I'll be making a component order for my VCO's very soon, cant wait!
E.A.S.
PostPosted: Tue Aug 07, 2012 7:57 pm    Post subject: Reply with quote Add User to Ignore List
wiring diagram added!
steffensen
PostPosted: Wed Aug 08, 2012 4:33 am    Post subject: Reply with quote Add User to Ignore List
Looking good. grin
simfonik
PostPosted: Wed Aug 08, 2012 10:47 am    Post subject: Reply with quote Add User to Ignore List
Are there still v2.0 PCBs available?
E.A.S.
PostPosted: Wed Aug 08, 2012 4:22 pm    Post subject: Reply with quote Add User to Ignore List
There are extras.
Anyone wanting to order the VCO, the VCF, HADSR, LFO/Noise/S&H, or the Mindreader (External signal processor, with pitch to Voltage convertor and a Hz/V to V/oct convertor)
Feel free to order. Instructions for ordering as well as pricing are located on first post, on each of the respective project threads, linked below in my signature.
Thanks for the interest! This is fun!
-Mike
Rod Serling Fan Club
aquatic hitchhiker
PostPosted: Sun Aug 12, 2012 10:39 pm    Post subject: Reply with quote Add User to Ignore List
Aside from checking the leg placement can I just swap the transistors shown on this schematic/bom on the first PCB?
I'm utterly frustrated with my vco build. It's such a simple PCB but I can't get it to make sound. I think all but 1 of my transistors were alternates as it is and I had to swap them around due to wrong leg placement and now I question datasheets as I'm not 100% certain who the manufacturer was on some I have.
I think I'm ready to replace all the transistors at this point.
DIY panels and PCBs for Buchla and Euro format: http://synthpanels.blogspot.de/
youtube channel: http://www.youtube.com/user/MrPalebluedot
E.A.S.
PostPosted: Sun Aug 12, 2012 11:10 pm    Post subject: Reply with quote Add User to Ignore List
Hi Cameron,
Just to make sure I don't give you bad advice, What transistors are you using? Also, Do you have VCO version 2? (Im guessing that why the post is here. Mr. Green )
-Mike
aquatic hitchhiker
PostPosted: Mon Aug 13, 2012 11:02 am    Post subject: Reply with quote Add User to Ignore List
Hi Cameron,
-Mike
Sorry, I had both threads open while I was troubleshooting last night. I am building from the previously released PCB, from the other thread, with all the obsolete transistors called out in the BOM. I think the only "correct" one I could get was a 2SK30A. Most of the rest are 2SC1685's (including the matched pair) with the exception of F3 where I used a 2N3819. I'm also building this into negativspace's panel and did those mods
Currently I get nothing out of the outputs save for hearing a little click when I turn the octave switch. I've played around with the trimmers, etc. I've swapped all 3 ICs to see if the problem was there. I found that I had mistaken the legs of the 2SC1685's and had remove and change position and solder back in. So now I'm concerned that maybe I damaged one or more of those transistors.
Looking at your new schematic vs the old, it looks like most or all of your transistor swaps are just straight swaps.
ringstone
PostPosted: Wed Aug 15, 2012 1:05 am    Post subject: Reply with quote Add User to Ignore List
Hi Cameron,
-Mike
Just out of interest, you do know about needing a voltage offset to the Hz/V CV in for the V1 PCB to get anything out of it?
Blair
some noise
asterisk
Last Visit: 15 Jun 2013
PostPosted: Fri Aug 24, 2012 7:48 pm    Post subject: Reply with quote Add User to Ignore List
where the hell is R1? i cant find it on the PCB.
is it where the unmarked SMT / through hole spot is? is that R1?
and is that an either / or situation? you can choose to have TH or SMT, not BOTH?
please let me know, im working on populating my 2.0 board.
thanks.
E.A.S.
PostPosted: Fri Aug 24, 2012 8:00 pm    Post subject: Reply with quote Add User to Ignore List
thanks.
Its directly above the HZ/v input pad. next to the SAW output pad.
its the resistor in the feedback loop of the saw buffer.
-Mike
aquatic hitchhiker
PostPosted: Fri Aug 24, 2012 8:05 pm    Post subject: Reply with quote Add User to Ignore List
Blair
No! What? Where do I pull offset from and how much? Fuck me, I knew it was something I was missing.
E.A.S.
PostPosted: Fri Aug 24, 2012 8:07 pm    Post subject: Reply with quote Add User to Ignore List
Oh, regarding the Tempco, its either/or. The tempco is R8 (unmarked on the pcb) but is the only spot for SMT. in the same area is pads for TH as well.
-M
asterisk
PostPosted: Fri Aug 24, 2012 8:11 pm    Post subject: Reply with quote Add User to Ignore List
ok duh, i was getting R and R1 confused.
thanks.
do you have a mouser part # for the TH version of R8?
i think the part # you have on the BOM is just for the SMT version.
never mind, SP4T switch mouser # is = 105-SR10010F-24NS
thanks!
E.A.S.
PostPosted: Fri Aug 24, 2012 8:30 pm    Post subject: Reply with quote Add User to Ignore List
thanks.
thanks!
Mouser doesn't have thru-hole tempco's.
you could get them from bride chamber or MFOS though.
the SMT is WAY cheaper. With a pair of tweezers and a fine tipped soldering iron its not that bad to solder either!
-Mike
E.A.S.
PostPosted: Fri Aug 24, 2012 8:35 pm    Post subject: Reply with quote Add User to Ignore List
RSFC, To keep the V1.0 and V2.0 note separate, I replied to you question Here.
-Mike
Lockheed
PostPosted: Sun Sep 23, 2012 3:48 pm    Post subject: Reply with quote Add User to Ignore List
I've built the Miss10 v2.0 and it mostly works. Two problems though: first, the triangle wave output is very low amplitude, and it looks like the other end of R76 is not connected to +V on the PCB like the schematic shows or do I read it wrong?
Second, the pulse width pot (1M lin) has a very short working range. The pulse width changes at first, but turning the pot a little more or so, the pulse output suddenly goes dead silent and stays silent for the rest of the range. Sound returns after turning back to low setting. Same happens with external voltage. Looks like the threshold is at 0.7 volts or so, going over that the pulse output goes silent.
I'll get back to testing in a couple of days when I got the time, but if anyone has some thoughts in the meantime, I'd appreciate it.
WTB: nothing right now, DIY has overflooded my cases!
ikkini
PostPosted: Fri Oct 05, 2012 2:04 pm    Post subject: Reply with quote Add User to Ignore List
I've started, but can't find R4 on the PCB !!!...
www.ikkini.net
www.soundcloud.com/amnesie1
www.soundcloud.com/wilfriedt
steffensen
PostPosted: Tue Oct 23, 2012 11:45 am    Post subject: Reply with quote Add User to Ignore List
Me either. I guess it have something to do with the PW "hack" that was used before?
Also, i went with the BOM for most parts, and it seems the C4 capacitor is a tad too big to fit. It will have to be a leaning tower for the time being. smile
ikkini
PostPosted: Sun Dec 02, 2012 1:43 pm    Post subject: Reply with quote Add User to Ignore List
Argh ! I soldered the transistors the wrong way !!!! very frustrating
www.ikkini.net
steffensen
PostPosted: Sun Dec 02, 2012 1:46 pm    Post subject: Reply with quote Add User to Ignore List
I feel the pain. I have to replace all my 3904's as the ones i used seems to not work properly. Never taking a chance on trannies again, no matter how cheap. razz
E.A.S.
PostPosted: Sun Dec 02, 2012 2:06 pm    Post subject: Reply with quote Add User to Ignore List
R4 isn't needed its for an extra input to the PWM mixer. Negitavspace's panel doesn't have space for another input so, its left off the PCB.
The C4 in the BOM is to large? This one is 1.5mm skinnier. you could also get away with a smaller Value. I actually have a 16v in mine. If you are building this for EURO, 16v is perfectly fine.
-Mike
steffensen
PostPosted: Sun Dec 02, 2012 2:17 pm    Post subject: Reply with quote Add User to Ignore List
-Mike
Thanks, ill have that one in mind.
At the moment ive made it fit by leaning it to the side a bit. Hoping that wont get in the way for the daughterboard-mounting later. In that case ill replace it tho.
ikkini
PostPosted: Sat Dec 22, 2012 9:30 am    Post subject: Reply with quote Add User to Ignore List
I've tried to remove my transistors, impossible. I've cut them all, but the PCB seem to be damaged now... I fear I will never finish this... cry
Why didn't you mention on the BOM that the transistors went the wrong way ??? cry
www.ikkini.net
negativspace
Manhattan Analog
PostPosted: Sun Apr 21, 2013 6:43 am    Post subject: Reply with quote Add User to Ignore List
Hey, did you ever find a solution to this? I just finished one (finally) and it's 100% good except for this exact same issue. I haven't started digging yet, curious if you ever did!
Analogue HavenCTRLEquinoxOZEFNFoxtone MusicPostModularSchneidersbüro
Lockheed
PostPosted: Sun Apr 21, 2013 5:36 pm    Post subject: Reply with quote Add User to Ignore List
Hi Jason, in the end I took the easy way out and just added resistors at both ends of the PW pot to narrow the range. I think they were 68k, but had I also tweaked the saw opamp gain higher so better to try for correct values.
negativspace
Manhattan Analog
PostPosted: Wed Apr 24, 2013 11:23 am    Post subject: Reply with quote Add User to Ignore List
Ok, so I finally had time this morning to poke at this. Looking at the two schematics side-by-side, I think what's happened is that the PWM opamp was switched to an inverting configuration to sum the panel pot + PWM CV but there is no second inverting stage to get the original polarity back. To confirm this I disconnected the WIDTH pot from the +12v rail and hooked it to the -12v. Bingo, PWM just as it should be.
To fix the range so that you get ~95% of the pot's rotation before sound cuts out, connect -12v to the CW lug of the WIDTH pot in series with a 680k resistor.
That'll fix the panel pot, but what about the CV input? Using 0->-5v to modulate it rather than 0->+5v should do the trick. (Mine seems to cut out at about -4v, but you get the idea.) Got enough CVPs? hihi
I can "fix" this on the daughterboard I have almost ready by adding an inverting stage to the PWM CV input with an SMT opamp. That plus the 680k resistor to -12v on the width pot will make it work as intended. I'm just not sure there's still interest in the daughterboard? Maybe I should re-open that thread.
steffensen
PostPosted: Wed Apr 24, 2013 11:54 am    Post subject: Reply with quote Add User to Ignore List
It's peanut butter jelly time!
This says it all.
But just in case, ill throw a wink in there too.
lombrose
PostPosted: Sat Apr 27, 2013 1:04 am    Post subject: Reply with quote Add User to Ignore List
there is still the v2 vco board to buy?
Mr. Green
Soundcloud: http://soundcloud.com/lombrose
YouTube: http://www.youtube.com/MrLombrose
E.A.S.
PostPosted: Sat Apr 27, 2013 12:53 pm    Post subject: Reply with quote Add User to Ignore List
Mr. Green
Actually, I have a good number of these in stock.
ordering info is here.
-Mike
E.A.S.
PostPosted: Sat Apr 27, 2013 2:21 pm    Post subject: Reply with quote Add User to Ignore List
Hey Jason, (and others)
I just poked around as well and found an even simpler fix. w00t
The feedback resistor in the mixer section just needs to be reduced to 30k to reduce the gain on the mixer. You'll also want to raise the initial PW pot input resistor to 240k. By changing the feedback resistor it also takes care of the other inputs at the same time, so no other changes need there. If you want to wire the initial PW pot between +12v and -12v it'll give you full sweep through the pulse width ratio. otherwise it'll only do pulse to square.
heres a quick drawing...
-Mike
Page 1 of 2
