I'd like to build an inverter... |
daverj Vintage Video Wiggler
Posted: Wed Aug 12, 2009 9:16 pm Post subject: |
A few thoughts:
Inputs to op amps are more sensitive to noise and inductance than the outputs. If you are going to stand resistors up you should reverse the direction of R1, R3, R5, and R6 so their bodies are connected to the inputs of the chip and their leads that are up in the air are facing away from the inputs.
Move R1 and R3 closer to the chip so there isn't so much copper trace between the chip and the resistors. R2 and R4 placement is not critical. They can go wherever they fit.
The ceramic bypass caps should be as close as possible to the chip. The electrolytics and 10 ohms are not so critical placement. They can be further away than the ceramics and other parts.
The ground connection for the ceramic cap going to pin 8 should be short and direct to the ground connection of the ceramic cap going to pin 4. |
DGTom Super Deluxe Wiggler
    Posts: 2627 Location: Pt.Adelaide, Sth.Aust.
Posted: Wed Aug 12, 2009 9:26 pm Post subject: |
this thread keeps on giving!
Great tips thanks! I wasn't aware of the critical nature of placing upright resistors.
I always put the electro/10ohms right next to the power connector as every synth PCB I've seen does this.
Thanks again  |
Posted: Wed Aug 12, 2009 9:44 pm Post subject: |
The ceramic caps pass high frequencies much better than electrolytics, which is why the ceramics need to be as close as possible to the chips. They kill spikes and oscillations. The electrolytics pass the medium and low frequencies which the ceramics don't, so their placement is less critical. They kill ripple.
The resistor gives isolation from the power supply and helps the caps to act as low pass filters.
If there is only one 10 ohm and electrolytic for the whole board, and there are multiple chips, then the resistor and electrolytic would go by the power connector and each chip would have the ceramics right at the chips. If there's only one chip on the board, then might as well put them closer to the chip.
Another school of thought is to put a ceramic, electrolytic, and resistor at each chip. In that case they would all be near their chips. In general that is overkill, except on some really noisy chips or chips very sensitive to power noise. Most op amps aren't so sensitive to power supply noise, so one set of electrolytics and resistors for the whole board is usually fine (maybe more electrolytics if the board is large).
If a chip draws a lot of fluctuating current, then having it's own electrolytic (in addition to the ceramic) is a good idea. |
Funky40 Super Deluxe Wiggler
Posted: Thu Aug 13, 2009 11:46 am Post subject: |
it was just a first try with lochmaster, and the first try with a stripboard layout
| daverj wrote: | A few thoughts:
thank you, this all is very interesting !
must ask more in a own thread
For me it's time to know more, and i'm thankful for those tipps,
but for beginners who maybe just got the lust to solder something simple i guess it could be better to keep things as simple as possible.
it might make the difference if a beginner solder something or if not
my very first DIY module was a quad gainstage.
no decoupling nowwhere.
even the board is not attached to anything, just taped that no short can happen.
That module was in use till some Days ago.
This things work also in all unperfectness.......................
for very first DIy tests the simple is ok. |
Posted: Thu Aug 13, 2009 9:16 pm Post subject: |
yeah heaps of my DIY modules have no de-coupling & prob. break every rule daverj has outlined. To begin with its just fun to get something working & play around, I think its a good idea to know, even just in theory many of the rules, even if you don't understand them or always use them
vital knowledge when, at some point, things start misbehaving!
hey Funky, maybe we should have a Lochmaster thread to swap tips & tricks etc. I've found it very usefull in getting cleaner & faster protoboard builds up & running
very cool little app. |
Posted: Fri Aug 14, 2009 2:50 pm Post subject: |
I wasn't trying to say things won't work if you don't follow layout rules. Lots of circuits work great without any care for the rules.
But at least being aware of them removes some of the "black magic" that confuses people when they get noise or crosstalk they didn't want.
Understanding them even helps when you do want extra noise and crosstalk. |
Moog$FooL$ Broke Dick Dog
     Posts: 1238 Location: Vancouver, BC.
Posted: Fri Aug 14, 2009 3:52 pm Post subject: |
| daverj wrote: | I wasn't trying to say things won't work if you don't follow layout rules. Lots of circuits work great without any care for the rules.
for sure!!! this is true & valid.
like i said before this is a great thread for me. just like a lot of the info. on this site.
thank you to everyone involved in this thread; no need for anyone to defend his or her's input..... it's all valid & very useful.  |
wetterberg Super Deluxe Wiggler
    Posts: 7656 Location: Copenhagen, Denmark.
Posted: Fri Aug 14, 2009 6:54 pm Post subject: |
"I'd like to build an inverter..."
"Oh no you wouldn't!"
- ahem, sorry, lame joke  |
Posted: Sat Aug 15, 2009 12:39 pm Post subject: |
| DGTom wrote: |
yup.
But i wont do much, but i guess i must try to layout an LPG
but don't expect that i build any.
i was not that sucessfull with my protoboard builds
have also a 15V to 12V conversion, but i fear also without decoupling
in winter i can draw a bit |
SOFTWIRE Wiggling with Experience
   Posts: 311 Location: Salt Lake City
Posted: Tue Oct 06, 2009 8:17 pm Post subject: |
so can someone tell me the difference from the 4069 inverter and the 40106 schmitt trigger inverter or can they be used interchangably?(not the chip itself, just the function)
Thanks |
Posted: Tue Oct 06, 2009 8:34 pm Post subject: |
As I understand it.
The 4069 is *just* an inverter whereas the 40106 is a little 'smarter'
http://en.wikipedia.org/wiki/Schmitt_trigger
I think its actually 3 inverters + the schmitt, so the output is really, really square. I have read of people having problems with the 4069 as a standard inverter w/ less than clean input signals.
the 4069 makes a great fuzzbox tho & as I've found out, a great (albeit crunchy) low pass gate!! |
Posted: Tue Oct 06, 2009 9:23 pm Post subject: |
| thanks it makes alot more sense now. |
frijitz Super Deluxe Wiggler
Posted: Tue Oct 06, 2009 9:33 pm Post subject: |
Ooops! I'm going to have to redo every module I've ever built.
Ian |
