MOTM-995
Author MOTM-995
stevenclements
Hey folks... I have a MOTM-995 .COM to MOTM Adapter.
This very useful board allows you to either run a MOTM power supply and power some .COM modules or run a .COM power supply and power some MOTM modules (either or not both hihi ). I have a the QPS1 power supply and the Q137 Power Control & Interface Module
This is certainly a simple question for those of you that have them... what cable do I need to hook up the MOTM sytle modules... I'm guessing the PWR-20 4-conductor power cable?
I'm not completely certain where to hook up the power from the QPS1 harness (must be JP1 where it says power harness here). Looking at the PCB that then appears to power the entire board and I connect on to that the PWR-20 4-conductor power cables to power the MOTM stuff.
JP1-3 are all the same... 4 pin
JP4-8 are all the same and larger then JP1-3 also 4 pin
JP10-13 are all the same and 6 pin - MOTM power I believe.
.... SOoOOoOOoooo how do I hook this up? .COM PS to JP1 and PWR-20 4-conductor power cables from JP4-8 to my MOTM modules?
Seem spot on?
Any help would save me frying my gear Dead Banana
thanks
Steve
ach_gott
Seem spot on?
Yep, you've got it.
consumed
This is certainly a simple question for those of you that have them... what cable to I need to hook up the MOTM sytle modules... I'm guessing the PWR-20 4-conductor power cable.
yes
yes
stevenclements
Phew... Guinness ftw! <- Thanks consumed
stevenclements
Woah... $22 to ship those cables... it think I may have to make them.
appears to be 3.96mm (.156") Pitch... does anyone have a mouser reference number?
Steve
paults
Don't blame me for the cost of shipping: the postage is calculated directly from the USPS web server very frustrating
The AMP/Tyco MTA-156 connector used on the PWR-20/-30 cables needs a special tool to insert the wire into the insulation displacement "fittings". Also, you need to use 18ga stranded wire for a proper fit. There is no soldering needed.
These cable are made on pneumatic NC machines by a wire harness manufacturer. I have not had a field failure in 12 years.
stevenclements
No blame intended at all Paul. I know how the shipping works. They have a base and work up from there... I get dinged all the time with it sad banana should have taken that job in San Diego smile
Thanks for the reference on the parts - you da man!
Steve
stevenclements
Looks like the right one... 22 Gage wire but none the less, should work.
http://ca.mouser.com/ProductDetail/Tyco-Electronics-AMP/3-640433-4/?qs =sGAEpiMZZMt7ScBeCnc0e5ofU%252bkJVF%252bh
consumed
for making my own power cables ive always been happy with the blacet supercablekit (with crimp)
stevenclements
That's brilliant! I need to order a Blacet 19" Rack Mount System... this will cut down on shipping + get a crimper - bob's yer uncle!
http://www.blacet.com/misc.html
Cheers consumed thumbs up
