ADDAC System VC Stompboxes
Moderators: Kent, infradead, __ag
ADDAC System
Post by ADDAC System » Tue Jan 21, 2014 5:32 am
Introducing ADDAC System VC Stompboxes
We’re pleased to welcome the new year introducing the first two of a new line of ADDAC System Stompboxes.
(This is not a preview teaser, the first batch is finished and ready to ship!)
We’re making them available here first for muff’s early birds, they are not yet publicly available on our website.
These two are utility “Stompboxes” and were developed thinking in guitar pedal setups and engineered to allow flexibility and new ways to interconnect them while preserving all of the input tone. We guarantee no tone difference when plugging instruments through them.
Vactrol based VCA’s at instrument level allows CV control over the audio signal of any of your pedals without the need to change from line to synth levels.
Due to the linear behaviour of our VCA’s, both of them allow to turn most expression pedals into one the best volume pedals you’ll ever experience. When using expression pedals they will offer smoother and better control of volume. This also means you won’t have the typical drastic boost at the end of the pedal.
Active VC Splitter - 3 Way Splitter with selectable VCA
featuring:
1 input, 3 outputs
Vactrol based VCA with CV / Linear Expression Pedal input and Control Level Knob for initial volume level.
Attenuator push button changes between CV and Exp. Pedal levels
Powered by 9v battery (extremelly low power consumption)
This splitter allows one input to be splitted to 3 outputs while keeping all of the input tone.
When connected, CV or Expression Pedal directly controls the volume of Output 1.
Outputs 2 and 3 feature a jumper each to select between Pre or Post VCA Output.
Usage examples:
Distribute your instrument through several amps.
Send your instrument to an Amp and to a soundcard simultaneously.
Split you instument signal through diferent effect paths, allowing parallel effect chains.
Active VC Mixer - 3 Way Mixer with selectable VCA
featuring:
3 inputs, 1 output
This mixer allows 3 inputs to be mixed into 1 output while keeping all of the input tone.
When connected, CV or Expression Pedal directly control the volume of Input 1.
Inputs 2 and 3 feature a jumper each to select if their mix is done Pre or Post VCA.
Usage examples:
Mix several instruments into one Amp.
Mix several pedal effect chains into one output.
Tested with Moog EP2 expression pedals but any Exp. Pedal with a stereo jack will work.
Line 6 exp. pedals need to be hacked to be compatible.
This time we’re not announcing a future product, the first small batch of 10 units is now finished and ready to ship!
Splitter introduction price: 100€ (will be 120€ after these are gone)
Mixer introduction price: 75€ (will be 120€ after these are gone)*
* the price is lower due to a printing mistake, INPUT1 and OUTPUT are swapped.
If interested just drop us a line to our regular email:
addac at addacsystem dot com
All the very best and wishes of a great year*
ADDAC System
Questions? Assistance? Hit me up via PM or send us an email!
ADDAC System | [www.addacsystem.com]
Paranormal Patroler
Post by Paranormal Patroler » Thu Jan 23, 2014 12:40 pm
:eek:
Wow! You should make a post in the General Gear thread or the Guitars,Basses,Amps&FX thread. People will be interested there!
Return to “ADDAC System”
