Neutron orgone accumulator preview and gauging interest
Neutron7
Oldschool bleeper
Post by Neutron7 » Thu Jun 26, 2014 2:12 pm
IT WORKS FINE!
ill be starting a build thread soon with ordering info.
there are some things that need to be soldered in order, and you need a fine point soldering tip and thin solder or you will have a bad time.
sammy123
Post by sammy123 » Thu Jun 26, 2014 2:21 pm
:guinness:
waggles
Post by waggles » Thu Jun 26, 2014 2:59 pm
:goo:
SymbioteK
Post by SymbioteK » Thu Jun 26, 2014 11:18 pm
I`ll take a set
Neutron7
Oldschool bleeper
Post by Neutron7 » Thu Jun 26, 2014 11:29 pm
SymbioteK wrote:I`ll take a set
viewtopic.php?t=116293
elmegil
Post by elmegil » Fri Jun 27, 2014 4:13 am
I just ordered one, thanks.
At one point you were talking about a generally programmable unit akin to an Ardcore; if one has the chops, is this usable in that way?
Neutron7
Oldschool bleeper
Post by Neutron7 » Fri Jun 27, 2014 6:00 am
You could do that, the code is free to do what you like with. All I ask is that you share your work. I have a place for alternative firmwares on github.
4285407da1d2a63820a3007c1
Post by 4285407da1d2a63820a3007c1 » Fri Jun 27, 2014 6:15 am
Didn't check in on this thread for ages, whatever happened to the amazing panel that was originally in the first post? The blue one. The new one looks much more practical not nearly as super cool.
Neutron7
Oldschool bleeper
Post by Neutron7 » Fri Jun 27, 2014 6:40 am
boringness excuse A:
It would have meant that the teensy and many of the components would be on a separate board, because there was no large enough spot on the board between the controls, So it would have been another $20 or so, plus between board headers.
OR
boringness excuse B:
the panel would be 24hp, (also more expensive, but not as much) and some people objected to the size.
Sorry i made it boring, i hope you will think otherwise when you hear one.
Post by 4285407da1d2a63820a3007c1 » Fri Jun 27, 2014 9:41 am
I quite like the new panel to be honest, I just thought the old one was really cool. Was really unique, but going for the cheaper and easier option certainly makes a lot of sense. Looking forward to the sounds!
elmegil
Post by elmegil » Fri Jun 27, 2014 11:40 am
Neutron7 wrote:You could do that, the code is free to do what you like with. All I ask is that you share your work. I have a place for alternative firmwares on github.
We've talked about this kind of work in PM too, definitely would be happy to share.
Main obstacle is utter noobness with github but that's surmountable :)
Neutron7
Oldschool bleeper
Post by Neutron7 » Fri Jun 27, 2014 11:44 am
That doesnt matter, just make the code how you like it and send it to me. ill include it on github, or, i think you can make your own github account and i can include a link to your fork.
elmegil
Post by elmegil » Fri Jun 27, 2014 11:51 am
We can discuss it further offline if it ever comes to fruition, there are many irons in the fire :) I did order the board and a Teensy 3 so we're off to the races at least.
Neutron7
Oldschool bleeper
Post by Neutron7 » Fri Jun 27, 2014 2:05 pm
I am finally happy with the FM alternative (X) mode. What i have done is changed the high position from a wave selector to a center-zero cube law variable pitch bender, the high position retains the mid positions selected wave. Then i tweaked the FM frequency to be Like an LFO when in fixed mode. Then i wasted a couple of hours playing with it, it is really fun.
I will do a video, hopefully this weekend.
Bakeneko
Post by Bakeneko » Sat Jun 28, 2014 5:06 am
I'm very interested in this , it sounds great.
cheers and regards
cane creek
Post by cane creek » Wed Jul 02, 2014 9:09 am
Ive ordered PCB/Panel
This is probably the most adventuras build i'll of took part in thus far so my questions may sound a wee bit silly :russian:
Would it be ok to program the Teensy 3.1 via USB first then cut the trace then install it into the module ?
elmegil
Post by elmegil » Wed Jul 02, 2014 9:42 am
cane creek wrote: Would it be ok to program the Teensy 3.1 via USB first then cut the trace then install it into the module ?
If you don't have any USB cable going to the front panel, why would you do that? Leaving it programmable would allow you to pull the module and flash firmware updates to it later, but it shouldn't be at any risk of being reprogrammed just by having a connector....
EDIT: I was misinterpreting which trace was being talked about, so yes, the power trace does need to be cut, see subsequent posts.
cane creek
Post by cane creek » Wed Jul 02, 2014 9:48 am
elmegil wrote: If you don't have any USB cable going to the front panel, why would you do that? Leaving it programmable would allow you to pull the module and flash firmware updates to it later, but it shouldn't be at any risk of being reprogrammed just by having a connector....
Like i stated I'm new to this and have no idea, so your saying don't cut the trace.
Neutron7
Oldschool bleeper
Post by Neutron7 » Wed Jul 02, 2014 10:44 am
cane creek wrote:Ive ordered PCB/Panel
Yes that is a good idea. You can check your teensy with the blink sketch to make sure it is working ok, and your computer detected it properly, then install the firmware and cut the trace before installing it.
You can still program it after but the module needs to be powered.
If you want to experiment while the module is in your system, you could get something like this bulkhead cable
http://www.datapro.net/products/usb-mic ... e-m-f.html
And mount it on the side of your case, or on a blank panel.
If you wanted to get really fancy, you can solder a diode across the cut trace, and use a diode instead of the power jumper on the orgone accumulator. Then it will take power from either source.
(Not tested, but shown here on pjrc site)
http://www.pjrc.com/teensy/external_power.html
(Thats for teensy 2, but paul says it will work with teensy 3/3.1 as well.
http://forum.pjrc.com/threads/19228-con ... Teensy-3-0
elmegil
Post by elmegil » Wed Jul 02, 2014 10:45 am
No problem, I didn't meant to sound aggressive.
Yes I'm saying don't cut the trace, there should be no reason to.
EDIT: No I was wrong, see the subsequent posts.
Neutron7
Oldschool bleeper
Post by Neutron7 » Wed Jul 02, 2014 10:50 am
If you do not cut the trace, the teensy will not work without USB power, and more importantly, if you power the module while also connected to USB, USB power from your computer will be shorted to your synths 5v power, which could potentially destroy something (computer usb power, maybe synth 5v regulator)
Neutron7
Oldschool bleeper
Post by Neutron7 » Wed Jul 02, 2014 10:52 am
Could people put questions about building in the build thread, please? :tu:
elmegil
Post by elmegil » Wed Jul 02, 2014 11:42 am
Neutron7 wrote:If you do not cut the trace, the teensy will not work without USB power, and more importantly, if you power the module while also connected to USB, USB power from your computer will be shorted to your synths 5v power, which could potentially destroy something (computer usb power, maybe synth 5v regulator)
Call me corrected :) And yeah, over to the build thread.
cane creek
Post by cane creek » Wed Jul 02, 2014 12:21 pm
Thanks for replys
mcop
Post by mcop » Fri Jul 04, 2014 11:34 am
Board and panel have arrived :banana:
