| View previous topic :: View next topic |
| Author |
Voice Controller with MOTU 1224 |
sine Learning to Wiggle
Posted: Mon Dec 07, 2009 10:23 pm Post subject: Voice Controller with MOTU 1224 |
I'm trying Silent Way Voice Controller with a MOTU 1224. The regular TRS outputs work fine, albeit with less than four octave tracking range. This was expected. The problem is, I can't get calibration it to work correctly using the Heaphone out or the Main XLR Outs. These outputs are preferable because they're much higher voltage--I can't remember the chart exactly, but around 6 octaves.
Here's audio of calibration using the regular TRS (low voltage) outputs:
The noises in the recording are artifacts from the mp3. It sounds clear at the source.
Calibration Good
Here's how calibration sounds with the Headphone or Main XLR Outs:
Calibration Fail
Notice how on the Fail version calibration tones start high and go down. Does this give any clue as to what the problem is? Playing the MIDI keyboard has no effect on pitch after the failed routine. I wonder if something is hooked up wrong inside the 1224. Has anyone tested a MOTU 1224?
Thanks. |
| Back to top |
os Ultra Wiggler
Posted: Tue Dec 08, 2009 3:48 am Post subject: Re: Voice Controller with MOTU 1224 |
| sine wrote: | | Notice how on the Fail version calibration tones start high and go down. |
That's probably the clue. Sounds like those outputs are connected with the opposite polarity to the other outputs.
Two things you could try:
- use an XLR cable with the other XLR pin connected to the tip of the jack plug
- use an inverter plug-in in your host, after Silent Way, to negate the voltage it's producing.
What synth/module are you testing here, by the way? _________________ http://www.expert-sleepers.co.uk/
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/ |
| Back to top |
Posted: Tue Dec 08, 2009 10:42 am Post subject: |
| Thanks for the reply. When I get home tonight I'll try DP's Trim plugin, which can do phase inversion. Synthesizers.com Q106 is the osc. |
| Back to top |
Posted: Tue Dec 08, 2009 7:06 pm Post subject: |
| Brilliant! I flipped phase and calibration worked like a charm. I'm getting 7 octaves. Thank you. |
| Back to top |
os Ultra Wiggler
| Back to top |
1nput0utput Common Wiggler
 Posts: 207 Location: USA
Posted: Wed Dec 09, 2009 6:53 pm Post subject: Re: Voice Controller with MOTU 1224 |
| os wrote: | | sine wrote: | | Notice how on the Fail version calibration tones start high and go down. |
That's probably the clue. Sounds like those outputs are connected with the opposite polarity to the other outputs. |
It could also be that the cables are wired wrong. _________________
| Charles Bukowski wrote: | | The difference between life and art is art is more bearable. |
| Back to top |
Bryan B Wiggling with Experience
Joined: 23 Sep 2009 Last Visit: 02 Sep 2010 Posts: 330 Location: Minneapolis, MN
Posted: Thu Dec 10, 2009 9:15 am Post subject: |
I had the same issue as described here, but I thought it was user error or a problem with my 1224's. The Din Sync wasn't working out of the 1224's headphone jack as well, this could explain things a bit.
Thanks for figuring this out! Now I have more tricks to try.
Any chance you could offer an "invert" checkbox on the voice controller in a future update? |
| Back to top |
os Ultra Wiggler
| Back to top |
Posted: Fri Dec 11, 2009 10:27 am Post subject: |
What would be the best way to invert the LFO Din 24 default so I can use my 1224 headphone out?
Does Ableton have an "inverter" plug-in? |
| Back to top |
os Ultra Wiggler
| Back to top |
Posted: Fri Dec 11, 2009 10:13 pm Post subject: |
I don't use plug-ins all that much, too many real knobs to keep me busy I guess. I will be using yours a whole lot more in the not too distant future. |
| Back to top |
lombrose Learning to Wiggle
Joined: 11 Nov 2009 Last Visit: 31 Aug 2010 Posts: 30 Location: Recife, PE, Brazil
Posted: Thu Mar 25, 2010 12:27 pm Post subject: |
Hello, I´m trying to use the voice controller and have a question, I alread have read the manual ok?
My question is abaout the output matrix, my gear is: windows vista ultimate, m-audio profire lightbridge using the dac output from my digimax fs to control my paia p9700s system, oscilator, filter and vca.
The daw I`m using is reaper, soon I`ll try to use silent way through pro tools with the vst adapter, but for now I`d like to now how to use the 6 outputs in the matrix to control one voice. How to adress each output of the voice controller to each different cv output to control the envs, gate, trigger etc?
Another thing is that the graphics of env 1 & 2 are not working, just a blue color in the place of each graphic, the third env graphic is ok.
Thaks in advance!!!! |
| Back to top |
os Ultra Wiggler
Posted: Thu Mar 25, 2010 1:32 pm Post subject: |
The graphics issue could well be a Vista problem. I've not heard anyone else report the same thing.
By default the six outputs of the plug-in carry pitch, gate, envs 1-3, and trigger. Are you asking how to set up the routing in Reaper, or do you have a question about the plug-in itself?
I can try to help you with Reaper but I'm no expert. _________________ http://www.expert-sleepers.co.uk/
| Back to top |
Posted: Fri Mar 26, 2010 9:47 pm Post subject: |
Hi!!!
Route in reaper is not a problem, I open the voice controller and put the ac adapter right after it, adress the output of the channel to the disired output in my interface, my question is: How to address each output in the voice controller to a specific output in the interface?
| Back to top |
os Ultra Wiggler
| Back to top |
