little lfo: are the 22uF electros critical (values)?
Author little lfo: are the 22uF electros critical (values)?
consumed
so i screwed up and ordered 22uf electros rated at 10v angry
can i substitute other similar values in there, like 10uF, or is 22uF the only 'right' value?
thanks!
EDIT: nevermind, i found a bag of 25v 22uF electros sitting around from another goofed up order long ago.
two wrongs do make a right.
Synthbuilder
Actually, you can use any value from 2.2uF to 47uF in those locations so long as the voltage is above 25V.
Tony
