VCLFO
Author VCLFO
jack multiple
which resistor on the pcb would i need to change to make the 'fine' pot behave more like the one on the VCO. i.e less range. what would be a good value roughly.? thx
Synthbuilder
R10. Doubling the value halves the range of the fine tune pot.
To get it similar to the one on the 2U VCO you'd need to make R10 10M. It probably won't do much when you are running the VC-LFO at the usual LFO frequencies though.
Tony
jack multiple
thanks Tony.
l i use it so much as a VCO as well as LFO i ve decided to connect it up to the buss via a switch named KYB/LFO, so i get the best of both worlds at the flick of a switch.
so the fine tune pot will only be useful in KBD mode. its hard to tune to the other ones quickly at the mo. But it does make an excellent VCO.
