Module Depths and Power Consumption
Discussion and support for STG Soundlabs modules of all formats.
Moderators: Kent, infradead, suitandtieguy
Henfield
Better Chemistry through Sound
Post by Henfield » Tue Jan 05, 2010 11:21 pm
I am currently looking at the MU format STG Modules for a portable system along with my Dotcom modules. As I will be either constructing or re-using a suitcase or briefcase style case, the depth and power requirements are critical. Can I get the pcb depth and power consumption for the STG filters, VCA, wave folder, and voltage and trigger store ( I just need the depth for the last two, as they just use the 5V power rail).
Thanks,
Henfield........................
suitandtieguy
Hammond King
Post by suitandtieguy » Wed Jan 06, 2010 2:06 am
filters, VCA, and sequencer modules are all 4.5" or so deep. i would budget 5" for comfort.
i'll get back to the thread about consumption. i think i might take those readings tonight.
http://suitandtieguy.com
http://stgsoundlabs.com
suboptimal wrote:... if it's music you want to make with your modular, STG should be in your system.
suitandtieguy
Hammond King
Post by suitandtieguy » Sun Jan 24, 2010 7:33 am
Post-Lawsuit Lowpass Filter: +16 mA, -15 mA
Voltage Mini-Store/Graphic Sequencer: 7 mA
Trigger Mini-Store/Trigger Sequencer: 8 mA
Time Buffer: 18 mA
i'll post more values as i get more modules measured. i need to build them first, though.
Henfield
Post by Henfield » Sun Jan 24, 2010 9:45 am
Thank you STG, I am mainly looking for the +/- 15V draw, as there always is a large excess of +5V in each power system.
It looks like your modules are very effecient and do not use much power!
tortug
Post by tortug » Fri Feb 05, 2010 1:50 pm
Hi,
I just ordered a wavefolder/Euro. What I didn´t knew, it's pretty deep.
I thought of building a rack in a suitcase, but the wavefolder wouldn't fit the way it is built.
Would it be a problem changing the angle of the board? Like putting it in a 90 degree angle, parallel to the plate (with an aluminium bracket or s.th. similar)? It would be wider than the plate, but I could put it beneath a very flat modul. Anything special to consider doing this?
Thanks for help.
suitandtieguy
Hammond King
Post by suitandtieguy » Fri Feb 05, 2010 2:09 pm
the construction of the Wave Folder, P-L/LPF, and (soon to be released) Sea Devils Filter is all totally modular, and very easy to modify.
if you are handy, you could build yourself new wiring harnesses and mount the card somewhere else even.
tortug
Post by tortug » Fri Feb 05, 2010 3:07 pm
Thanks,
great. I'll probably try mounting the card in a 90 degree angle then. 8_)
Jari Jokinen
Sensible Wiggler
Post by Jari Jokinen » Tue Feb 09, 2010 4:07 am
Is euro version of Post-Lawsuit filter 4.5" deep? Then it is too deep to Doepfer suitcase, which has usable depth of 100mm = 3.9".
suitandtieguy
Hammond King
Post by suitandtieguy » Tue Feb 09, 2010 5:02 am
i believe it fits. i shortened the wing on the euro versions.
theabsent
Post by theabsent » Thu Feb 25, 2010 3:14 am
suitandtieguy wrote:Post-Lawsuit Lowpass Filter: +16 mA, -15 mA
Time Buffer: 18 mA
Any idea how much euro-wave folder draws?
My releases: https://laitoshuoltaja.bandcamp.com/releases
My sound art & live gigs: https://www.facebook.com/Laitoshuoltaja/
Modular live gigs (our band): www.konekonekone.com
Modular Patch of The Week Channel on YouTube: https://www.youtube.com/channel/UCTYqCy ... pvEmilJScg
fac
wig MUffler
Post by fac » Fri Sep 17, 2010 11:40 am
Old thread, I know, but I didn't want to start a new thread.
I'm planning to expand my current dotcom rig and I'd like to know the power consumption specs of the STG Wavefolder, Sea Devils and Mankato filters (both in MU). I need to estimate the total consumption of my projected system to see if I need a new PS.
May I also suggest making this thread a sticky?
russma
Post by russma » Fri Sep 17, 2010 12:45 pm
I have added an "MU" data table on Suit's page on Muff's Wiki, and included the power and depth data in this thread.
Suit: if there's any errors, or anything else you'd like me to add to this page, PM me.
bleeps
Post by bleeps » Wed Dec 28, 2011 5:24 pm
Even older thread by now, but I figured I'd keep it all in one place. I'd also like to know the current draw for the Euro versions of the Wave Folder and Sea Devils. Any info?
EnricoGaruda
Post by EnricoGaruda » Fri Jun 13, 2014 4:16 pm
news on the info?
j_dowe
Post by j_dowe » Fri Jul 13, 2018 9:56 am
wow, this is an old thread, the question still remains ... does anyone know the current draw for the Euro version of the Wave Folder?
Return to “STG Soundlabs”
