powering a hex zone with a wall wart.
Author powering a hex zone with a wall wart.
johnnymad
is this possible? i've shrunk my blacet rig to 6U and have to sell two modules that i'd really like to keep if i can't find a way to power my hex zone. the load on my blacet psu couldn't handle a 6U plus the hex. i want to put the hex in its own case and possibly add the new makenoise pressure points to the setup. should i just pick up a cheap power one or is there some kind of wall wart that would do the trick?
rezzn8r
some good info here...
http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWART SUPPLY.php
hex zone consumption is around 150mA, so anything over 300mA should be good.
johnnymad
thanks! i forgot about that one. i built one of the paia wall warts before and i blew one of the rails out. if the hex is the only thing only the mfos, i should be ok. i'm pretty sure i overloaded the paia supply.
