Hexinverter Neinohnein Clap Control Issues
Author Hexinverter Neinohnein Clap Control Issues
toneburst
Hi,
I recently soldered up a Neinohnein Clap Euro module from Hexinverter.net. It's producing clap-like sounds, but I'm concerned the controls aren't behaving as they should, so it would be great if someone with a known-working module could take a listen to the brief example file attached, and tell me if this is expected behaviour.
In the example, I adjust the INTENS. parameter from it's minimum value to about 12:00 (half way round). Turning the knob any further than this just increases the volume of the white noise, and the noise is constant, rather than fading away after the last trigger pulse.
As you can hear, with the control at its minimum value, the sound is virtually inaudible. I have a suspicion the are meant to be two components to the sound- the initial clap sound, and the artificial reverb sound. The initial sound seems to be too quiet, though, but maybe this is how the control is supposed to work.
Thanks very much in advance, guys,
a|x
toneburst
Anyone?
a|x
juicepatrol
I have the exact same problem. I have been looking for a solution as well.
