DIY Modular Synth Power Supply (sorta)
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page Previous  1, 2, 3, 4 ... 12, 13, 14  Next [all]
Author DIY Modular Synth Power Supply (sorta)
fonik
Muff Wiggler wrote:
this makes way more sense now
grin
since the PSU outputs +15V AND -15V referenced to COM (or ground), it IS a dual output supply. if it would provide additional 5V we would call it triple output.
anyways, i am glad if i was helpful.
you are more and more helpful with every post! this is great info, thanks!!
very happy to have you here at the forum w00t
cheers
BugBrand
I've just been getting started with Power One supplies (HAA15s) and found this thread and Fonik's info to be darn useful!
Two things to note:
- I measured some resistances between the output posts which seem interesting given the Sensing hookup
---> roughly 7ohms measured (my continuity tester goes beeeep!)::::
-OUT to -S,
+OUT to +S,
Com to -SCom
Com to +SCom
So, I don't know what conclusion to draw... Does this perhaps negate the need of adding the extra jumpers? I'm still go to add then anyways I think..
Also just to note: on the HAA15s it says (on the case and in the docs) to cut cumpers VW1 and VW2 for 15v operation.
fonik
here is a quote from another PSU supplier concerning remote sensing (i think it applies to other brands as well, the used technique, whatever it is, will be the same) - it is just a kind of disclaimer, i guess:
THE SENSING TERMINALS MUST BE CONNECTED to the output terminals, either at the barrier strip on the power supply or at the load. Failure to have the sense terminals connected will affect the output voltage (usually causing it to be higher than the rating of the supply, and unadjustable), and may result in permanent damage to both the power supply and its load.
http://www.acopian.com/remote-sensing.html
miminashi
Hm, I don't have the sensing terminals connected to anything and the supply (an HAA15) seems to work just fine..
Anyway, does anyone know of a good way to supply power to the 5v rail? I wanna get my feet wet with some digital modules but I'm at a loss as to how to power them. Does anyone know about how many modules the Doepfer "low cost" 5v supply will power? Thanks!
Anyone,
I've wondered why if it's 'better' to have the sensing terminals connected together, why they even provide the terminals in the first place instead of just connecting the circuit points up by default? Is it so more sophisticated power monitoring/controling gear can be connected or???
miminashi,
For supplying +5 volts if you need less than 200ma you could try one of these little Synthesizers.com adapters (see bottom of page):
http://www.synthesizers.com/q101.html
They provide a schematic too if you want to roll yer own. Similar circuits can be found.
Be sure to check Ebay for PowerOne modules! Here's a nice looking new one for $18 + shipping buy-it-now:
http://cgi.ebay.com/Power-One-HB5-3-OVP-A-Power-Supply-5-VDC-NIB_W0QQi temZ220159366237
It's not mine and I don't know the seller so, you are on yer own! exclamation
fonik
it's just because real remote sensing would connect the sensing terminals not at the PSU but at the load. it's the voltagedrop caused by the resistance of the leads that needs to be corrected. in our case the leads to the load are not that long, so it doesn't seem to matter.
again, the quote above is a disclaimer, i think.
fonik
so it all depends on several circumstances: how long and/or thick are the leads from the PSU to the load (i.e. power distribution boards) and how much current is drawn?
the less current you draw and the lower the resistance of the leads, the less voltage drop we will see.
if you have a closed system which draws the same current all the time you could just use the trimmers to set the correct voltage.
in my case i start building a cabinet and then i add modules over the year, and i don't want to readjust the PSU again.
oh, and actually we don't know what we are talking about, since we did no measurements wink
maybe it's just a question of good practice...
Thanks matthias!
And sorry, I failed to go to the link you provided earlier. d'oh! Makes more 'sense' now that I read it!
consumed
fonik wrote:
hello guys,
my first post here, so be kind...
if you wanted to use a power one PSU (which is a good choice, i think), don't forget to wire the sensing terminals to provide (remote-)sensing of the PSU.
this will guarantee the same regulated voltage output, no matter how much current is drawn by your modules. otherwise the output voltage could drop, depending on how much current is drawn, each module that you add to you modular could influence the output voltage of the PSU (this may influence the tuning of the VCOs).
so connect the sensing terminals to the corresponding output terminals. connect your power bus/distribution board direct to the output terminals, not the sensing terminals.
hi matthias, welcome! good to have you show up over here and hang out. ive seen you recommend this PSU configuration over at E-M before. have you tested rail stability with both sensing and non sensing configured? the feature sounds nice but i wonder why this practice would not be more well known and used if it led only to higher voltage stability. at any rate, i know that paul/synthtech does not configure his PSUs this way. i cant remember if .com does or not.
easy!
fonik
thank you for the welcome grin
i did no measurements, i just followed the instructions given in the PSUs documentation i got.
as said before the voltagedrop depends on current drawn and resistance of the leads. the wiring in our synthesizers is very short, i'd say. so it won't matter much, i guess. if one experienced problems he could use larger gauge to lower the resistance.
consider that these PSUs are used in medicine and aviation as well. the wiring in an airplain might be a different thing!
maybe i will have enough time on weekend to do a measurement - just for fun!?
consumed wrote:
fonik wrote:
hello guys,
easy!
It looks like from the pictures on their site that synthesizers.com wires up the sensing terminals.
john
fonik
indeed, he does for the PSU on that picture at least...
however, i will try to measure the resistance of my leads to the bus and calculate the possible drop...
hey cool news!
I just took my PSU out to hookup the sense posts..
.. and it WAS done at the factory it appears. There are thin wires connecting the corrects sets of posts that appear to be original, not soldered after the fact.
and as far as the multimeter is concerned, they are definately joined.
just saved myself some soldering 8)
if you look closely at the pic i've posted you can actually see them...
fonik
i measured the resistance of the leads i use for connecting my PSUs to the power distribution boards.
so here we go (metric metrics wink ):
the gauge of the leads i am using is about 0.5mm². i measured 0,5R/m. say the leads are 20cm from PSU to bus. that would be 0,1R. if i power some modules with 500mA in sum on a rail this would be a drop of 0,05V (R*I=V). if i then added more modules that draw 1A in sum i would have a voltage drop of 0,1V.
the remote sensing should take care of this 0,05V difference. i could use shorter leads or leads with larger gauge alternatively.
the 0,05V change in supply voltage could influence the tracking of the VCOs or the tracking of the outputvoltage of a midi2CV module, i think (depends on, i know).
anyways, this all does not apply to a closed system. here you could set the output voltage by the trimmers and leave it as is.
just a quick note to say that I updated the initial post in this thread to include the information about auto-sensing and how to configure it. I want to keep all the information in that first post so that if anyone new comes across the thread they will get the whole story in one place
thanks again fonik for brining this up 8)
fonik
good read, mr muff wiggler 8)
just one comment, though. AFAIK and according to the documentations i read, the ground (coming from the AC mains connector) should be connected directly to the PSU chassis, as close to the transformer as possible (usualy there are holes for screws in this area). the PSUs chassis is mounted to the rackframe, so the cabinet is grounded as well (protection class I). it is a protective earth conductor that is not needed for your PSU working properly. in case something goes wrong inside the unit and lethal current would go to the cabinet/controls, the protective earth conductor leads away this current.
In case (and only then) the whole case is made of plastic and all controls (knobs, sockets) and the faceplates are made of plastic, if no conductive parts are reachable for the user, then and only then you can even leave the ground off (protection class II).
this will apply to our DIY very seldom, i guess.
good tip! thanks again... updated the first post to include this info, and I'll rewire my PSU next time I have the rack out 8)
numbertalk
Thanks so much for this informative posting! It is because of this posting I have joined this forum.
Also, I have a question. In this photo:
https://www.muffwiggler.com/forum/userpix/2_IMG_4498_1.jpg
What kind of connectors do you have for the individual wires connected to the DC posts (where you say OMG only pushed on!)? Anyone know a part number/manufacturer/Mouser #/etc?
thanks numbertalk! nice to have you here w00t
those are the connector cables that come with the Doepfer busboards, for connecting the busboards to each other, or to a PSU
unfortunately I do not know what the 'correct' technical name for the connectors is - 'slip on connector'? And I'm not sure of a part number.....they simply came along with my Doepfer busboards.
hope this helps!
cheers
consumed
muff, you were able to put the flat push-on connectors onto the round DC posts? i dont remember receiving round push-on connectors with my DIY kit, i cant imagine forcing the flat ones. i know that round push-on crimp connectors exist and *may* work with those posts, but ive always only soldered wires into them.
yeah I got the flat connectors on there
took a bit of work, but yeah.
they aren't going ANYWHERE
numbertalk
Thank you!
EDIT: Do you think one of these male pins would fit into the post -
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=863-0400&MPN=0 2-09-2103&R=863-0400&SEARCH=863-0400&DESC=02-09-2103?utm_source=Allied &utm_medium=merchandising&utm_campaign=Allied_Top_Sellers&utm_content= 863-0400
Then there's the housing for it:
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=5128980&MPN=77 0063-1&R=5128980&SEARCH=5128980&DESC=770063-1
If anyone happens to have any info on those and if/where they would be available in the U.S. please let me know. I could just solder wires there but would feel better if they were covered with connectors like they are on yours.
hope this helps!
cheers
numbertalk
Hi Muff,
Another question - what gauge wire did you use to connect the AC inlet/mains power to the primary side of the power supply transformer? Would it be ok for me to use stranded hook up 24 AWG wire, for example? Should I use something heavier on this side of the power supply?
consumed
you can also just apply some shrinkwrap over the DC posts if you dont want them exposed. this is a good idea when wiring your AC mains to the PSU too.
larger is better, i'd go for 16-20g. more importantly-- get wire rated for your AC mains voltage! do NOT use regular old hook up wire between the wall and your PSU. the danger is that the insulating layer could disintegrate and leave you with mains wiring exposed. most hook-up wire is not rated for higher voltages. i had a conversation with one of the guys at the local electronics store about this. i ended up buying a heavy duty three conductor power cord and chopping it up. it worked out nicely.
Page 3 of 14
