Can't the Minimoog Expression input be sent Velocity signals
Author Can't the Minimoog Expression input be sent Velocity signals
Peake
from your MIDI/CV converter?
Peake
I mean, it's a separate VCA. I'll ASSume that it's an interrupting jack sending 5V to it, and out to a pedal and back when one is plugged in.
It must be possible to wire up a converter's Velocity out for use at this input.
Peake
I am told that this will indeed work.
No Minimoog owners out there, eh?
CZ Rider
The external volume input on the back of the Mini has a switching jack that disconnects a fixed voltage going to the second VCA. The schematic shows +10v applied through a 33K resistor, giving it about a 0 to +6 volt working range. So any voltage source in that range will work. My test indicated +5 volts was not quite 100% volume.
Peake
Peake
I see that the Studio Electronics MIDIMoog has a velocity feature, but it's a switch for on/off for each, VCA and VCF. I don't know if this imparts "full" velocity or not, but evidently, these good folk knew about this possibility from the beginning. Cheers to Greg and the rest at Studio Electronics!
