quick question about input voltages
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Volta
Author quick question about input voltages
slow_riot
Last Visit: 25 May 2013
PostPosted: Sat Jan 30, 2010 8:20 pm    Post subject: quick question about input voltages Reply with quote Add User to Ignore List
I have a motu 828 .
According to the output specification sheet, it outputs a voltage within -2.3 V and +2.3
Is it likely that this is the input range for CVs as well? I.e. do I need to use something to convert control voltages into this range to fit them into my computer?
thanks in advance
doctorvague
ole fuckity fuck
PostPosted: Sun Jan 31, 2010 9:52 am    Post subject: Re: quick question about input voltages Reply with quote Add User to Ignore List
slow_riot wrote:
I have a motu 828 .
thanks in advance
It appears you are misunderstanding some basic concepts of how Volta works. Volta sends CV (via your interface of course). The only thing that needs to get sent back IN to the computer is audio- specifically the audio output of the oscillator you're calibrating. MOTU recommends using a sine wave or barring that a triangle wave. If the specs are correct for your interface you should get around 4.5 octaves of 1V/Oct tracking as you have potentially 4.6Vp-p.
Phil
Happy New Nanosecond.
modular youtube videos|Soundcloud audio tracks|The Oversouls (live non-modular trio)
slow_riot
PostPosted: Sun Jan 31, 2010 10:29 am    Post subject: Reply with quote Add User to Ignore List
Hi Phil. thanks for your answer
I'm not actually using Volta but it seems like this forum is the best place for discussing issues about getting CV to and from computers. I'm gonna be using Max/msp and hopefully using translated CVs in a number of ways inside that.
Anyways I'm not really familiar with voltage, and this point is confusing me. I think maybe I need to research voltages generally a bit more. Starting with the difference between polarized and non polarized voltage and when both are used or not.
It seems logical that a soundcard that outputs within a certain range would take inputs within that same range though.
doctorvague
ole fuckity fuck
PostPosted: Sun Jan 31, 2010 11:37 am    Post subject: Reply with quote Add User to Ignore List
I suggest you ask this in the Silent Way forum. I believe he has done something more along the lines you're looking for and IIRC correctly figured out a way to get CV back in, but not really sure about that. That would probably be the place to ask - or maybe the software forum where there are people using Max/msp would be even better. Good luck!
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Volta All times are GMT - 5 Hours
