Noisy wow&flutter
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
HIMA
Noisy wow&flutter
Post by HIMA » Wed Oct 22, 2014 8:54 am
As the title says. There's a ton of noise from the module even with nothing jacked in and all dials set to 0. High frees and low.
Is this common? As it is the module is pretty unusable for recordings...
The Book of Bad Ideas - A compendium of knowledge from Muffs. Download it here: http://bit.ly/1oz2zaI
thorncore
Post by thorncore » Wed Oct 22, 2014 3:54 pm
defo sounds broken to me.
does it still have the jumper on the back?
i dont know if that being missing would cause those symptoms anyway.
Sinamsis
Post by Sinamsis » Wed Oct 22, 2014 4:22 pm
I recently heard someone say the same thing about the pedal version. Mine is as quiet as can be. I quite often keep it patched and turn down the mix to completely dry as it really induces no noise to the signal. It must be a bum unit.
HIMA
Post by HIMA » Thu Oct 23, 2014 12:43 am
Thanks guys, guess it's time to mail Dan
Ambriant
no noise on mine
Post by Ambriant » Wed Nov 05, 2014 10:12 pm
Mine is quiet. No noise issues.
HIMA
Post by HIMA » Wed Nov 05, 2014 10:16 pm
yeah, discussed this with Dan. he suggested it may be that one of my other modules is interfering with the power Setup on the wow. i've not had a chance to shift modules around but that seems pretty likely. Recently the addition of the QMMF necessitated a big move around of modules. I can't pin point when the problem arose but it's very possible it was from that time.
EDIT: yup, that was it. all solved. :yay:
Return to “SNAZZY FX”
