Kobol VCO Based starter system
psykx
Post by psykx » Wed Nov 26, 2014 3:15 pm
I really love the sound of the mos-lab kobal VCO, enough that it's changed my mind from starting with eurorack. From this video
I was planning to build a mos-lab system around it, but it turns out that the kobol VCO is 15+/- v and the rest of mos lab stuff is 12+/- v. My understanding is that makes it only compatible with synthesizers.com stuff, cluboftheknobs, moon modular and modcan B. Is that correct?
In the future I'd really like to be able to expand with the classic moog clones.
In the video I posted above the module is in a case with other mos-lab kit, I think that they just don't make the other modules any more? or is there an easy 15v-12v adaptor?
I have an analog four, so my plan is to use that for sequencing, lfo's and envelopes. I really just want some different oscillators and some filters for the time being.
DomMorley
Post by DomMorley » Wed Nov 26, 2014 3:46 pm
A fine idea!
Speak to Seb at Mos-Lab and I'm sure he will be able to supply what you need. I have several Mos-Lab modules running via a small adaptor that Seb shipped with them which is in turn plugged into my +15/-15V dotcom power supply.
If you buy a dotcom supply (for example) then you can run the Kobol VCOs direct from that, and the other Mos-Lab modules via the adaptor.
This means you're building a MU (also known as 'dotcom') set-up, compatible with synthesizers.com, COTK, Oakley, Moon, Corsynth, Macbeth, STG Soundlabs and many others. This link to Modular Grid shows a good range of the modules available in this format.
:yay:
How I fill my days: www.dommorley.com
"Your head will collapse, but there's nothing in it..."
Gringo Starr
Post by Gringo Starr » Wed Nov 26, 2014 4:47 pm
Did the Kobol Filter ever get released?
Weed only gives you the illusion that it’s enhancing your creativity.
DomMorley
Post by DomMorley » Wed Nov 26, 2014 5:08 pm
Gringo Starr wrote:Did the Kobol Filter ever get released?
I think Seb just jumped straight to the full Kobol synth instead.
http://www.mos-lab.com/#!kobol-project/c156d :drunkhomer:
Gringo Starr
Post by Gringo Starr » Wed Nov 26, 2014 5:15 pm
That kinda sucks. When I ordered the Kobol Oscillators Seb had said that the Filters were coming. That slightly influenced my purchase. But I probably would have bought them anyways. I hope he does do a batch at some point.
EMwhite
Post by EMwhite » Wed Nov 26, 2014 6:47 pm
They are coming... at least it's on his list as of my conversation from this past May.
"The 3x LFO module, the 981 multiband filter module and the future kobol VCF module will be produced on the future, it's sure !"
Having ordered 3 rounds of the 9xx series Moog clones from MOS-LAB, each 6-months goes by fairly quickly and that seems to be his backlog. Now that Kobol Expander pre-order period has closed, this may be happening along with the 984 Mixer that he's got on his 'news' feed. If I had to guess, it would be sometime in 2016 but what do I know ... It will warrant it's own case and I plan on going all-in on one.
With regard to your power dilemma, you should look to pickup one of the Mean Well supplies that synth.com sells, except do so through a local electronic distributor in Germany as you'll save $$ that way. The dotcom power standard is simple and well documented.
Beware of programmers with screwdrivers...
krainov
Have some kits of it
Post by krainov » Thu Sep 12, 2019 8:07 am
Net, C#, Synth DIY and Nitche
josaka
Post by josaka » Thu Sep 12, 2019 1:42 pm
also think Seb is toying with the idea of a new RSF line..
Return to “5U Format Modules”
