Search is fixed!!! Apologies for the downtime.
L-1 2180 VCF Audio Demos *Updated*
Author L-1 2180 VCF Audio Demos *Updated*
radiokoala
8_) As there's not a lot of recordings of this (very nice I must note) filter, I went ahead and recorded these.
[s]http://soundcloud.com/modularsounds/crickets[/s]
[s]http://soundcloud.com/modularsounds/2180-vcf[/s]
 [s]http://soundcloud.com/modularsounds/2180-audiorate[/s]
PATCH:
oscillator Sputnik 258 1 core, square wave.
filter L-1 2180 VCF, low-pass mode. res in self-oscillation.
modulation SSF PTG + Cwejman PH-4 mixed together in vactrol crossfader module Thonk Spring Reverb. mix ratio controlled by Sputnik 258 2 core oscillator. Sequencer hexinverter sympleseq going to 1v/oct on VCO and 1v/oct input on 2180 VCF.
envelope/vca SSF PTG.
fx delay/reverb/chorus/phaser, but used subtly. core sound is not affected, they only add some depth and sense of space.
other notes in Hi-Pass demo there is 2180 high-pass output patched to second input. also bass boost setting is always on. in audiorate demo I turn on bass boost some time closer to the end. in both demos lfo frequency, fm amount, cutoff and resonance (one at a time) here and there are manually adjusted for variation in the timbre.
!! TRACKS ARE DOWNLOADABLE BY THE WAY !!
https://www.modulargrid.net/e/l-1-2180-vcf
LeftyLogic
Great demos! It's peanut butter jelly time!
radiokoala
w00t Thank you!
Listening to these as I was uploading them yesterday I thought they were a bit LPG sounding. Would you agree?
I didn't play before with actual LPGs, so that's why I ask. I used three vactrols in a patch though. razz
peripatitis
Well my impression is that the 'lpg' sound does not come from some of sort of effect to the sound the vactrols have, but from the effect to the way the filter responds.
Using the ptg in essence you are constructing an lpg.
L-1
radiokoalaThank you! Good samples. Will place them on my site.
radiokoala
Cheers Alex!
Something new and very cool demo of what this filter can do:
imitative nature sounds of crickets chirping!!
Enjoy guys! SlayerBadger!
hinterlands303
Sorry to bump this old thread, but I was wondering if anyone who uses this filter can compare it to others out there in terms of sound? I like the demos but because the filter is being so heavily modulated I have trouble getting a sense of its basic character. Thanks in advance!
