Frac modules in MFB 3U euro frame + JAG/CTL1-video
Author Frac modules in MFB 3U euro frame + JAG/CTL1-video
11ish
i started using an MFB 3U euro frame for Frac controller modules. Although you can screw them in only at the upper rail, they sit firm and tight.
The Blacet PSU can be mounted behind the JAG for example:
Unlike pictured here, I re-mounted the PSU a little bit further in, so that the frame
can be positioned like this:
At the top Frac modules are longer of course than euro ones, but at the bottom they fit exactly:
and here's what i've been doing with these lately:
http://vimeo.com/9492913
panda30y
sandyb
screaming goo yo
excellent sounds.
Roycie Roller
brilliant stuff!
did you have a new controller at one stage?
11ish
thank you guys! SlayerBadger! appreciate your feedback very much!
yes, i ordered one as soon as the wiard site was updated in June 2007, because i'd already loved my JAG to death.
i still have the new controller, but i'm using it with my frac case (having Miniwave, DAD and multiples on the way to fill the gaps):
BananaPlug
Interesting. Does it look as though one could just drill a couple new holes and reposition the other rail to make the MFB 3U euro frame into an MFB 3U frac frame?
11ish
should be possible, i guess. but my idea is to use it for both frac and euro - or at least to retain the possibility to do so.
Atticus
Lush, lush sounds and great vid. Thank you! thumbs up
KNYST
Nicely done.
Love the sounds!! SlayerBadger! we're not worthy Dead Banana
11ish
thank you all!
