Fac drums
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
satori
Fac drums
Post by satori » Wed Jul 08, 2015 2:10 am
I'm really keen to load the facdrum sketch but I'm having trouble.
Every other sketch I have tried is loading, but the facdrums folder doesn't have an ino file in it like all the other sketches I have, only a pde file when I click on it it says there is an error.
unknown type name 'prog_uint_32_t'
This is the same error as I was getting when I tried to load the file after changing the file extension to ino
Any ideas?
silversurfer
Post by silversurfer » Wed Jul 08, 2015 2:56 pm
Thats correct, unlike the other sketches the fac drums folder doesn't have an ino file, only a pde file. Why, I don't know tbh.
Clicking the pde file in the arduino loader launches the sketch.
Not sure what your error means but you are doing it correct.
Have you got all the H files, C files in that folder too?
satori
Post by satori » Wed Jul 08, 2015 5:24 pm
Yes all those files are in the master folder. I tried making my own sketch with facs drum sketch generator and the same error occurred
fac
wig MUffler
Post by fac » Wed Jul 08, 2015 7:14 pm
Old arduino sketches (pre v1.0) used the extension .pde (from Processing). Version 1.0 introduced .ino as the new extension.
I guess the .pde extension has been deprecated and newer IDE versions don't load it automatically. Simply rename the .pde to .ino and that should do it.
satori
Post by satori » Thu Jul 09, 2015 9:58 pm
unfortunately that doesn't work either :( Same error message occurs.
fac
wig MUffler
Re: Fac drums
Post by fac » Mon Jul 13, 2015 10:32 am
satori wrote: unknown type name 'prog_uint_32_t'
I'm reading the arduino reference and I see that most of the typedefs in avr/pgmspace.h are now deprecated.
I think there are two ways to fix this (I'm at work so I can't test them):
First (easy) way:
In fac_drums.pde (or fac_drums.ino), add this line:
#define PROG_TYPES_COMPAT
before the line
#include <avr/pgmspace.h>
Second (not so easy) way:
Go through all the source files (.pde, .ino, .c and .h) and replace every instance of prog_uint32_t with
uint32_t PROGMEM
and replace every instance of prog_uchar with
unsigned char PROGMEM
Let me know if it works.
eclectics
Post by eclectics » Mon Jul 20, 2015 7:02 am
Tried the simple way, but it didn't work.
It then complained about pitchtable.c, so I added the PROG_TYPES_COMPAT to pitchtable.h, then it whinges about progmem must be defined const ... That was with the arduino software 1.6.5
The arduino.cc download page still has a link for the Previous Releases, including what they call the classic 1.0.x.
Version 1.0.5 works without any fuss-- no changes to the code required. I didn't try 1.0.6 but it doesn't mention deprecating types in the release notes so it's probably good.
jonnosan
Post by jonnosan » Mon Jul 04, 2016 2:38 am
I have uploaded a version of the FAC drum sketch converted to work with Arduino IDE 1.6.4 to https://github.com/jonnosan/fac_drums
milkyjoe
Post by milkyjoe » Sat Sep 10, 2016 1:31 pm
muffs sells !!!
milkyjoe
Post by milkyjoe » Sat Sep 10, 2016 1:33 pm
muffs sells!!!
Return to “SNAZZY FX”
