Touchable Banana Plugs
MUFF WIGGLER Forum Index -> Ciat-Lonbarde
Author Touchable Banana Plugs
thresholdpeople
Just got these in the mail: http://www.mouser.com/ds/2/159/D72918%2007_25_06-72034.pdf.
Buy 10, they cost $1.14 here in the US on Mouser. Cheaper than getting non stacking Emersons or something. The threaded rod is about 1/2", so a good height when I plugged it into my Coco.
Mashmore
Great price. I haven't done this yet.. But bought some plasi dip for the tips. Going to dip a few of the tops for my Cercle inputs on the coco. I hate brushing up accidently on the cercles while wiggling. Banana is so fun. These, some aligators, some bare wire, a contact mic. long live the coco. nanners
pugix
The Mouser part I got is 565-3257. The plug has a small stub on the end. It's a bit hard on the fingers.
http://www.mouser.com/ProductDetail/Pomona/3257/?qs=%2fha2pyFaduj3ZZBM C%2fWB7d68Gj8IH8fSfRszNtVlQng%3d
thresholdpeople
Here's the part on mouser for the ones I've been using: http://www.mouser.com/ProductDetail/Pomona-Electronics/72918/?qs=sGAEp iMZZMv8kklI404QlQ32FBASdVjZ. It comes with a threaded section that's about .5" long. Hard to tell from the photo on mouser, because it also comes with two hex nuts, which I'm not using.
I've been liking the long stem, it allows from a variable amount of skin on it.
Probably not new to anyone that have used older CL pegged instruments, or other touchable instruments, but I've found that I'm able to get pretty wonderful vibrato like modulation effects by twisting at my wrist with my fingers on the connections.
I have ten of these and definitely I need some more!
jdev
Got those as well Pugix. Word of advice, I need to find something that's easier to grip! I guess the Pomona's with nuts you could technically put a washer in between for better grip. The PB2 seems to use Pomona's as far as I can tell, and they really hold onto the banana cables/plugs.
