How to get STG Graphic Seq to start on step 1?
MUFF WIGGLER Forum Index -> STG Soundlabs
Author How to get STG Graphic Seq to start on step 1?
intellijel
When I power up my case and feed a clock to the Graphic Sequencer it shows the led lit on step one but the first position played (after first clock pulse) is step 2.
I want to use an external device (i.e. a gate signal from my DAW via midi to Cv converter or even the Doepfer A190 as an example) to reset the sequence so that every time I press play on my DAW transport (or any other clock source) the sequence should start at step 1.
How can I do this with the graphic seq?
The MFB Seq-01 in comparison has a positive edge triggered reset in so the instant you reset it starts at step 1 and everything is nicely in sync.
intellijel
I got it to work now by triggering the reset on the first clock pulse and making sure the reset pulse was a very short trigger.
