[ORDER] Euclidean Circles - LEDs with rhythm
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3 ... 26, 27, 28  Next [all]
Author [ORDER] Euclidean Circles - LEDs with rhythm
av500
If you bought a v2 PCB set at Dutch Modular Fest, please contact me!
UPDATE 10: Euclidean Circles v2 replaces the original v1 also for DIY builds, see new guide below
PLEASE, if you email me, mention your MW nick, otherwise I have a hard time tracking who is who
see bottom of this post for prices
it's a panel! it's a PCB! it has rhythm! it's Euclidean Circles! - NOW VERSION 2
prototype PCBs finally came in, so here it my first *real* Eurorack module
it's a 3/6 channel 16 step Euclidean rhythm generator with an unique pattern visualization in 3U, 10hp Eurorack format. outputs 1-3 are the "on-beat" triggers and 4-6 are the "off-beat" trigger signals, all 5V. triggers 4-6 can also be used as a second set of 3 channels so 6 independent rhythm channels in total
the board and front panel is all SMT except for jacks and encoders - soldering the LEDs can be tricky, it's not a beginners SMT project.
The module runs from 5V only and depending on the adjustable LED brightness consumes between 60mA and 150mA. I run it at the lowest setting most of the time, at the highest level you attract passing alien space ships, so beware
see the linked video for a short demonstration of the basic features. on top of creating Euclidean Rhythms, the board is also a variable clock divider up to audio rates (tested up to 20kHz) and I'm working on more features like chaining and prescaling between 2 or 3 channels.
Euclidean Circles:
DIY PCB set: €55 + €7 shipping
(comes with CPU soldered and programmed, including JP1/JP2 to connect the PCBs and 3 plastic washers for the encoders and the LED button!)
NOTE: soldering the LEDs can be tricky, it's not a beginners SMT project!
Fully built module: €265 + shipping
SixSwitches:
PCB + panel: €10 + €5 shipping
full kit: €35 + €7 shipping
Fully built: €50 + €7 shipping
payment via PayPal in Euro please, email me for orders, email address is vp (at) vpme (dot) de
v1 Mouser cart: https://www.mouser.de/ProjectManager/ProjectDetail.aspx?AccessID=99414 397ee
v2 Mouser cart: https://www.mouser.de/ProjectManager/ProjectDetail.aspx?AccessID=40aaf 3e4fa
Euclidian Circles @ Modulargrid
BOMs and build guides:
(NOTE: in order to see the attached documents, you need to be logged in to muffwiggler.com - alterntatively these are avialable here: https://drive.google.com/drive/u/0/folders/0ByXqLcOF-aBUbmdKSjJGTEtwOU U)
v2:
- EuclideanCircles_v2_BOM_and_Build_Guide_v2.0.pdf
v1.9a:
- EuclideanCircles_BOM_and_Build_Guide_v1.9a.pdf
v1.8:
- EuclideanCircles_BOM_and_Build_Guide_v1.8.pdf
v1.7:
- EuclideanCircles_BOM_v1.5.pdf
- EuclideanCircles_Build_Guide_v1.7.pdf
v1.5:
- EuclideanCircles_Soldering_and_Assembly_v1.5.pdf
v1.2, v1.3, v1.4:
- EuclideanCircles_BOM_v1.3.pdf
- EuclideanCircles_Soldering_and_Wiring.pdf
SixSwitches:
- SixSwitches_build_guide_v1.0.pdf
Joe.
remove the 's' in 'https' in the video link.
I always hoped for something like this to be released with Dekatrons, but metasonix ruined all hope by explaining how unreliable they are waah
Great job implementing it thumbs up
av500
using the Euclidian Circles module as a clock divider at audio rates:
emeb
Amazing!
av500
thanks, fixed. Dekatrons are here on my desk, but no time yet smile
medbot
emeb wrote:
Amazing!
I agree!
That chip in the middle looks pretty scary. I've done ICs like the others, but I don't think I've tried anything that tight. I'd definitely be down to try though because that thing looks worth it just for the light show. Great sequencing options are just a bonus really.
PK808370
That's just fun to look at! I don't even like light shows on my modules, but I like this one. Oh, it also seems like it might be sonically useful smile not just a flashy dresser.
av500
medbot wrote:
emeb wrote:
Amazing!
I agree!
20pin TSSOP, solders easily under the stereo microscope here smile
PK808370
medbot... you snuck in in front of me and stole all my thoughts... I must have been too mesmerized by the ... ooh circles Dead Banana
limpmeat
Looks cool, I'd be keen
mikecameron
neat! I didn't see any mention of availability...
timpecter
That looks super cool, really pretty, useful, and novel! I've done a bit of SMD but I think that's just too extreme for me to tackle. How do you solder the LEDs? Seems like it would be hard to reach the contacts with the iron without melting the plastic edges of the LED...
av500
bear with me, this is the first time I think about making PCBs/modules available, so I need to find my way smile
av500
soldering the LEDs is not that hard for me, but then I have a stereo microscope that I can use smile I basically rotate the PCB after every two LEDs, so the iron is always in the same place when soldering and with a fine tip I can reach the contacts easily.
atte
av500 wrote:
the module runs from 5V only and depending on the adjustable LED brightness consumes between 60mA and 600mA.
Looks really nice, although it seems to be a hungry little fella.
However it too small for me ATM, maybe someone could build one for me... What's the price and availability? Full kits or is there a BOM (or mouser card) available?
TimoRozendal
wow, nice!
NS4W
I'm interested! But I would need some assistance on that SMD....
geecen
1:12 Finally, a Euro jump-step module cool
Seriously though, looks great.
Jarno
Looks great!
It does seem a bit fragile though, does it feel that way too, or not too bad?
oootini
looks really nice!
quick thought - flip the firmware to have only the active step lit on the leds? that would mean far less current consumption. just a thought...
gbiz
Fantastic. SMD and blinkenlights. screaming goo yo
Is that SMD power header up to taking repeated insertion/removal of the power cable, or a cable under strain in the cabinet ?. I appreciate using a PTH header would mean the pins show on the front & wouldn't look good. I ripped half the pads off a similar header that's used for the display board on Streams with nothing more than a accidental knock.
av500
oootini wrote:
looks really nice!
can add that to the firmware as a setting smile what's a digital module without settings after all! Rockin' Banana!
av500
Jarno wrote:
Looks great!
it definitely feels "not too bad to me" smile
av500
show me on the module where to put a 10/16 pin through hole header smile
av500
I'm thinking of offering it "prebuilt" with the SMD soldered and you only mount the jacks and encoders. would that be an option?
Page 1 of 28
