Discontinuity Unity setting does nothing
Author Discontinuity Unity setting does nothing
whomper
Hi,
I have just completed building my Discontinuity module and gone through the setup instructions.
Setting up the 3 trimmers went smoothly, but the last one, Unity, has no affect. No matter how much I turn it this way or the other, it does not have an effect on the sound or on the waveform display in my software scope (alas, do not have a real scope).
What could be the source of trouble here?
Synthbuilder
My first thoughts are that the trimmer is of the wrong value or a small short between two of its pins. But assuming this is not the case...
Does altering the Discontinuity pot have the correct effect on the output of the module? If its making no effect at all you may have a problem in the circuitry around U3.
Tony
whomper
Just double checked and it is working now. I have calibrated late at night and that multi turn trimmer needed, hmmm, multiple turns to make a difference....
Thanks, its calibrated and operates well!
