using Oakley EFG to interface guitar pedals?
Author using Oakley EFG to interface guitar pedals?
jonny_w
I'm looking for a way to interface guitar effect pedals with my modular. I was thinking about this:
Modular signal -> Attenuator -> Guitar pedals -> Oakley EFG Pre In -> Amplify signal -> Oakley EFG Pre Out -> Modular
Would this work? I know that CGS makes a circuit for this very purpose (CGS60), but I'd prefer to stick with Oakley.
Synthbuilder
Yep, that'll work.
The attenuator just needs to be a volume control of any sort - one channel of the Multimix or a VCA, for example. It could also be just a couple of resistors. I sometimes use a combination of a 10K resistor in series with the signal and a 1K resistor as a shunt (from end of 10K resistor to ground). If you use small resistors you can actually build this into a jack plug.
Tony
jonny_w
Synthbuilder wrote:
Yep, that'll work.
Tony
Perfect, thanks for the response! I made up a couple attenuator boxes with 100k linear pots - any reason why you'd use a shunt resistor in that application?
Synthbuilder
Pots are good because you can vary the level. I just use a resistor combination because it's small enough to fit in a jack plug. Two resistor attenuators are always better than just a series resistor. The shunt keeps the output impedance of the attenuator down to a low value which reduces the chance of noise pick up.
Tony
