YATMA - Yet Another Transistor MAtcher ( for lazybones )
Author YATMA - Yet Another Transistor MAtcher ( for lazybones )
elektrouwe
I did not like the known single DUT (device under test) transistor/diode matching methods for several reasons :
- they require precision resistors (0.1%) and/or precission DVMs (>=4.5 digit)
- I often need pairs, quads of matched diodes/transistors or even more for ladder filters and is a pain i.t.a to keep temperature constant in serial measurements
- I don't like writing down lots of mV - values and subtract them later (yes, I'm a lazybone)
here is a circuit that uses cheap standard parts to measure delta-Vbe of 2..8 DUT at a glance with an oscilloscope or a sound card based software scope.
Pic.1 shows the schematics:
Basic principle is to scan the forward voltages of all DUT with a CD4051 octal analog switch U3, amplify the resulting (sub-) mV step pattern with U4, a high gain (x1000) AC-amplifier and visualize the voltage steps with a scope.
U2, another CD4051, is used to switch a single reference current to each DUT while its voltage is scanned. U1, a CD4060, generates a 1.5KHz scanning clock , a 3 bit switch address and a narrow scope trigger spike which is added to the amplified output.
Screenshot Pic.2 shows a typical measurement :
a LM3046 transistor array containing 5 NPN transistors Q1..Q5 is connected as DUT1..DUT5. Because only 5 of 8 possible DUT are measured, unused DUT6,7,8 are connected to DUT5 to avoid fake delta-VBE steps for these unused channels.
note: scope Y-setting is 200mV/div and YATMA gain is 1000 : delta-Vbe resolution is 200uV/div !
The trigger spike indicates the begin of a scan sequence and ensures stable triggering even for (hopefully) small or zero delta VBE.
NPNs and PNPs can be compared even simultaneously. Schematics shows how to connect different types of DUT.
Pic.3 shows the breadboard prototype with another LM3046 connected to an oscilloscope and parallel to the microphone jack of a netbook running XOSCOPE under LUBUNTU:
If , for example, VBE of Q1 is definded as reference, the scope's Y-position knob can be used to move Q1's voltage level to the 0V scope base line.
Then you can see at a glance how much the other voltages differ from reference Q1 !
I made a PCB with a ZIF test socket and a patch field. ICs or discrete semiconductors can be patched with short DuPont female wires.
next picture shows 8 diodes with anodes patched to the 8 DUT pins (right sideof ZIF socket) and cathodes jumpered to GND (left side)
PCB design files to download / order: http://www.seeedstudio.com/service/RDOmfuY6
additional notes:
- Because only voltage differences between DUT are important, U4's amplified offset voltage does
not matter. A TL071 or similar opamp without offset trimming is good enough.
- C7 depends on how big the trigger spike must be to trigger your scope or soundcard-scope. 100p works in most cases
- for reference currents requiring Rref < 10k , delta-RON of switch U2 could introduce a reference
current modulation . This can easily be ruled out by connecting 1 DUT to all inputs DUT1..8 and
checking if the resulting delta-VBE pattern is flat.
- when measuring discrete semiconductors, keep the whole setup close in a small plastic box to keep all DUT at same temperature
- Rref1..3 can be selected by jumper or rotary switch or you can a pot to adjust the reference current
happy matching !
yan6
This looks really neat! I'm a little lost on how a transistor would mount on the ziff socket to match you DUT diagram. It looks like the ziff has 3 pins all connected together and the outermost is a common ground.
elektrouwe
yan6 wrote:
... how a transistor would mount on the ziff socket to match you DUT diagram...
like the diodes in the picture:
NPN : B and C together on the right ZIF side, E jumpered to ground on the left side.
PNP : E to the right side, B and C to left side and grounded.
it's also shown in schematics : all "anodes" = anode of a diode, emitter of a PNP, base of a NPN) are patched to the positive reference current, all "cathodes" = cathode of diode, emitter of NPN, base of PNP are connected to GND via jumpers
so 8 transistors would fit in a ZIF16 socket.
yan6 wrote:
... 3 pins all connected together...
1 is the ZIF socket, the 2 others are used for patching the reference current to DUT1..8.
In case of matching less than 8 DUTs, unused DUT lines should be patched together to the last used DUT; therefore I need 2 pins.
Outer GND lines are used for jumpers from "cathodes" to GND.
my english is not the best; hope I could explain it good enough
windspirit
Seems like a good idea. You might consider using a DIP switch instead of all of those jumpers as they can be a pain to change in such close quarters like that.
frijitz
Very nice!
Ian
klangbauer
build, tested and select transistors
diablojoy
interesting thumbs up
keninverse
any chance you can post the gerbers for this here? Seeed link is dead.
elektrouwe
can't find my YATMA data even after login @ Seed - strange...
here is the ZIP file with gerber data and docs
specialunderwear
Great work! I'm building one.
KSS
4051 has 8 matched channels? Doesn't this need per channel compensation to be accurate?
elektrouwe
as described above, you can check 4051 "quality" by measuring a single component connected to all 8 channels. Then you should see a straight line on the scope.
4051's R_on channel mismatch is <=5 Ohms which is about .1% of the DUT feeding resistor.
So, as long as you don't want to match delta Vbe to < 10uV you are fine ;-)
gabba@gabi
Just great idea!
elektrouwe
UPDATE ! there was some request for a tiny YATMA version, so YATMA2 was born: same principle, but only 2 chips required for a 2 transistor matcher.
My FB buddy Jim made a nice layout , built a prototype and now offers all design files here. Thanks a lot, Jim !
how it works:
both DUTs (NPNs,PNPs or diodes) have their anodes connected and share a pullup resistor (R10,R3 selected by jumper) that determines the measurement current. DUT cathodes are pulled down to GND alternately by a square wave oscillator with complementary open drain outputs (74HC125).
This generates a small square wave voltage with amplitude Vdut1 -Vdut2 which is AC-amplified by an opamp and watched on the scope.
A gain of ~500 shows Vbe differences of 100uV as 50mV signal on the scope.
The circuit ist powered by USB 5V.
Jim's pictures show a random selected transistor pair and a very well matched one:
picture of the prototype:
and attached Gerber & drill files.
Happy matching !
Veryfungi
I'm the Jim guy. smile This tester only needs a scope to work and I'm blown away at how precise it is. Thanks for allowing me to test and implement your smaller version tester. I hope it helps many people!
gabba@gabi
Allow me to ask:
how importand is it to have two different measurement currents?
wackelpeter
very neat, Uwe and Jim... much appreciated effort you made
elektrouwe
gabba@gabi wrote:
Allow me to ask:
depends on what you want to match. For transistors a measurement current between 10 and 100 uA is often used ( 68k => ~60uA).
For matching LEDs - I used them as VC-resistors in VCFs and VCAs - R10 was in the range 3k3..6k8, as far as I remember (1k is a just a place holder value). In general, measurement current value is not too important; keep it small enough to avoid self heating of the DUT and big enough to get a clean output signal.
cygmu
I just wanted to say how happy I am that you shared this device with us all. I built one today and I’m delighted with it. Everyone in my family enjoys watching the scope trace move when you put a finger on one of the transistors under test!
