cats and modular synths, but mostly cats
Artist Challenge #4 is now closed for new submissions! Thanks to everyone who entered, you guys are truly crazy. The official voting thread will be created shortly with the standard two weeks for the voting period. Enjoy the tunes!
AC Encoder active circuit prototype
Goto page 1, 2  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Silent Way
Author AC Encoder active circuit prototype
Last Visit: 02 Sep 2010
PostPosted: Sun Apr 25, 2010 7:51 am    Post subject: AC Encoder active circuit prototype Reply with quote Add User to Ignore List
I finally got around to building an active AC Encoder circuit:
http://www.flickr.com/photos/expertsleepers/sets/72157623926880008/
This is based on the MFOS design at http://www.musicfromouterspace.com/analogsynth/oddsandends.html#LEVELS HIFTER
and very similar to that built recently by PolishMilk (http://www.muffwiggler.com/forum/viewtopic.php?p=210351#210351).
The two trim pots give an adjustable gain from 1x to 6x and an adjustable DC offset. (If you just want positive voltages (e.g. for a gate) you can do away with the DC offset pot.)
I tested this with my Mobile I/O 2882 interface. In +4dB mode this outputs ±8V anyway to I put it into -10dB mode, which gives just over 2V output with the passive rectifier circuit. Using the active circuit I got a nice ±5V or 0-10V, and it was rock solid driving ASys and Doepfer VCOs. Calibration with Silent Way covered the full (audible) range of the oscillators.
The quoted component values give an RC time constant for the rectifier of 0.2ms. I certainly couldn't hear any slew when doing 5 octave jumps on the keyboard.
The circuit was powered from the ASys case bus.
Total component cost for one channel is about £2, about half of which is the trim pots.
Next step is to solder up a few of these channels into a module!
Edit - see below for a slightly updated version of this circuit.
Edit2 - see further below for a DC-coupled version of this circuit.
http://www.expert-sleepers.co.uk/
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/
Bryan B
PostPosted: Sun Apr 25, 2010 12:06 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for posting this!
What happens when you throw normal a normal audio signal into it?
My modular animal has awoken!
PostPosted: Mon Apr 26, 2010 3:01 am    Post subject: Reply with quote Add User to Ignore List
I guess you'd have a kind of envelope follower, but with a much faster response than would be useful.
Why would you want to do that?
bsmith
PostPosted: Mon Apr 26, 2010 7:28 am    Post subject: Reply with quote Add User to Ignore List
Really exciting os! Are the trim pots something that would ultimately brought out front of the panel on a pot or would they be a set and forget kind of thing? How does the different results that folks have with different capacitors for their interfaces get handled in this active model? Sorry if these are ignorant questions, am a simple cave man....
PostPosted: Mon Apr 26, 2010 7:38 am    Post subject: Reply with quote Add User to Ignore List
The trim pots ought to be 'set and forget'. You'd just need to set them up once to suit the output of your audio interface, and whether you want bipolar CVs or not.
The capacitor choice can be fixed because it depends only on the input impedance of the circuit, which is fixed. In the passive case, the input impedance is determined by whatever module you happen to have it plugged in to.
bsmith
PostPosted: Mon Apr 26, 2010 7:46 am    Post subject: Reply with quote Add User to Ignore List
Again excuse if this is a silly question - why wouldn't one want bipolar?
PostPosted: Mon Apr 26, 2010 7:59 am    Post subject: Reply with quote Add User to Ignore List
You might have a Buchla smile
It's possible that some modules really don't like negative CVs. I don't know of any myself though.
Arnoid
Last Visit: 20 Jul 2010
PostPosted: Mon Apr 26, 2010 8:34 am    Post subject: Reply with quote Add User to Ignore List
Nice one !
This may be the solution for me because with the passive AC encoder circuit the calibration was a bit unstable on certain oscillators...
Gonna check this out when I have some spare time does this circuit also work on 15V ?
www.myspace.com/arnoid l www.soundcloud.com/arnoid
PostPosted: Mon Apr 26, 2010 8:39 am    Post subject: Reply with quote Add User to Ignore List
Should work fine at 15V.
PostPosted: Mon Apr 26, 2010 2:52 pm    Post subject: Reply with quote Add User to Ignore List
A slight update:
- the output protection resistor (R7 in the first pic above) was redundant since the TL082 has this internally, so I've removed it.
- since the first op-amp is amplifying a +ve only signal, it has a max range of 0-12V. Therefore the DC-offset op-amp (the second one) in the original circuit was producing a max ±6V signal, since it had unity gain. I've therefore doubled the value of R2 to give 2x gain, allowing a bipolar signal which covers the whole possible output range (in theory - in practice slightly less).
Using these mods I've just got a nice ±10V and tracking of the oscillator over the whole MIDI note range.
Monobass
bonoMass
PostPosted: Mon Apr 26, 2010 5:36 pm    Post subject: Reply with quote Add User to Ignore List
This is really exciting.... I'm very keen to see if I can use a circuit like this to turn the audio outputs of my Nord Modular G2 into CV outs.. does it still definitely require a balanced output?
Monobass
bonoMass
PostPosted: Mon Apr 26, 2010 5:47 pm    Post subject: Reply with quote Add User to Ignore List
definitely a TL082P required? will any other TL082 also work?
edit: I have some TL082CN
Bryan B
People ask me that all the time smile
I figured it out before you answered though.
You could use a full volume loop (white noise?) and use Ableton's envelope editing to create CV outs maybe? I have to noodle on this some more, but it seems like you could do some fun experimenting with something like that.
A filter on the sound would probably slow the envelope follower response time...
PostPosted: Tue Apr 27, 2010 2:58 am    Post subject: Reply with quote Add User to Ignore List
@monobass - the prototype uses TLO82CN. Ignore TL082P - that's just what the schematic software brought in as default.
Probably does not need a balanced out, but I need to confirm that.
@Bryan B - that would probably work. You could use Silent Way DC and draw parameter curves to achieve the same thing though.
Bryan B
PostPosted: Tue Apr 27, 2010 7:26 am    Post subject: Reply with quote Add User to Ignore List
My cat gets skinned differently every day.
Arnoid
PostPosted: Tue Apr 27, 2010 7:52 am    Post subject: Reply with quote Add User to Ignore List
Is the Half-wave rectifier implented in this circuit ?
Because I only get good voltages if I use the voltage doubler or even tripler...or isn't this important for this circuit ?
PostPosted: Tue Apr 27, 2010 7:57 am    Post subject: Reply with quote Add User to Ignore List
This circuit is using the full-wave rectifier.
The op-amps as configured above provide up to 12x gain, so the passive voltage doubler isn't required.
Cryptowen
Last Visit: 28 Apr 2010
PostPosted: Wed Apr 28, 2010 12:23 pm    Post subject: Reply with quote Add User to Ignore List
Any plans to sell a pre-assembled version of this? I've been holding off buying Silent Way until I could get it working, & I can't seem to get any of the AC encoder circuits to work properly with my MS-10. I'm assuming it's just me not doing circuits right.
PostPosted: Wed Apr 28, 2010 1:02 pm    Post subject: Reply with quote Add User to Ignore List
Yes, there's a plan, though a fairly long-term one.
Stay tuned!
Cryptowen
PostPosted: Wed Apr 28, 2010 1:09 pm    Post subject: Reply with quote Add User to Ignore List
Awesome.
Out of curiosity, how long term might it be? I've got an album coming out in August & I need to record good versions of the synth parts some time before then. Depending on when Silent Way hardware is released I may or may not go ahead & buy a synth with midi in-cv out already included to use as a converter for now.
http://www.cryptowen.com/
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Silent Way All times are GMT - 5 Hours
