Bionic Lester: Sequenced HD DA (Updated)
MUFF WIGGLER Forum Index -> The Harvestman
Author Bionic Lester: Sequenced HD DA (Updated)
mt3
[soundcloud url="https://api.soundcloud.com/tracks/264346039" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/264346037" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/264346038" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Bionic Lester seems to tear apart and dismember the Hertz Donut perfectly.
Initial tests modulating the Bionic Lester with Kermit were mindblowing as well.
Also, Polivoks VCG is bloody nice thru BL, like a smooth burning.
The first track is all 6 outs of BL mixed together, the 2nd and 3rd tracks are the individual LP outputs of ch A and B provided for comparison purposes.
Patch Notes
Hertz Donut mk 1 is the oscillator
* into Bionic Lester ch A normalled into ch B
Bionic Lester
* all 6 outputs are used
* allpass mode
* clock B mode
* LO aliasing
Metropolis is main sequencer
* gate to Function (envelope to ch A of Bionic Lester)
* pitch is sent to CVP where it is distributed to all other modules
Triggerman synced to Metropolis
* sequence 2 to Double Andore mk2 ch A
* sequence 3 to Polivoks modulator gate in
Function to Bionic Lester chA cutoff
Double Andore mk2
* ch A envelope out to Bionic Lester chB cutoff
* ch A in RC discharge mode (perfect fit for the switching-capacitor Bionic Lester filter)
Manually twisted and turned everyfukcingthing that I could
GhostlyMostly
this is absolutely beautiful work SlayerBadger!
inspiring!
mt3
[soundcloud url="https://api.soundcloud.com/tracks/265646686" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/265646688" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Here are two more. I'll be adding as time permits.
Gracias GhostlyMostly.
Ras Thavas
Those are nice mt3, I had to come back and listen a second time. Wonderful snarling tones...
Only negative is you're making me jones for a HDII and I've already got a Cyclebox, DPO, and Rubicon/Dixie combo. I shouldn't need more, yet I want it. Curse of euro.
mt3
[soundcloud url="https://api.soundcloud.com/tracks/266310715" params="auto_play=false&hide_related=false&show_comments=true&show_use r=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Another one.
Ras Thavas, gracias. Would it reduce the jonesing if I mentioned I was using a mk1 HD?
w00t
Ras Thavas
mt3 wrote:
...Ras Thavas, gracias. Would it reduce the jonesing if I mentioned I was using a mk1 HD?
w00t
Not much, now I have to jones for a MKI as well... Dead Banana
d.thomas
Bionic Lester mkII and the Double Andore mkII expander are the two things I'm most excited about. Been tempted to pick up a mkI BL in the meantime.
mt3 Great tracks!
FatRocky
mt3
For those who believe the x-modulation knobs on the Double Andores should have been the biggest knobs, you'll love AB mode on Bionic Lester where ch B is affected by ch A frequency cutoff.
Other filters I'm digging for excessive character are Blue Lantern Steiner and Plague Bearer.
Want to check out Bi n Tic by Elby since it has same topology as Bionic Lester but with the safety removed.
