Set SAM to show
VCO PWM switch connections
Author VCO PWM switch connections
terjewinther
Since I originally intended the issue 4 versions of the VCOs for another format, I didnĀ“t bought the extra pot and sockets PCBs. Reading through all the brilliant documentation, it is still not 100% clear how to wire the PWM switch, because there is nowhere to be found the correlation between the front panel text and the internal connections. I do think I get it, though:
SAW on the PCB = EDGE on the front panel
TRI on the PCB = CENTERED on the front panel
Is this correct? At least that seems logical.
Synthbuilder
That's correct.
Tony
terjewinther
Thank you!
